1946 front access?
ZENVWDRIVER
ZENVWDRIVER is offline
PostPosted: Fri Aug 24, 2018 2:50 pm    Post subject: 1946 front access? Reply with quote
... saw this in a gallery and want to know if the access on the top of the tunnel, over the pedal mechanism was a stock - from the factory access in 1946?
And if so, When was it discontinued?
1/54, black 11C Beetle
3/55 never hit, no rust, 113 Beetle, stratos silver
9/63 Pacific blue, Ghia
'87 Toyota MR2
German sausage are the wurst.
RareAir
RareAir is offline
PostPosted: Fri Aug 24, 2018 4:45 pm    Post subject: Re: 1946 front access? Reply with quote
Not factory.
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
fazeka
fazeka is offline
PostPosted: Fri Aug 24, 2018 11:52 pm    Post subject: Re: 1946 front access? Reply with quote
The hole on the right side of the tunnel... assuming it is for a pedal cluster? If so, didn't think they made RHD in '46?
originalo
originalo is offline
PostPosted: Sat Aug 25, 2018 2:21 am    Post subject: Re: 1946 front access? Reply with quote
The access cover on the tunnel is not factory. You find those homemade openings often on bugs, they allow f. ex. to change the clutch wire without having to disassemble the pedal cluster.
Evidently there were RHD bugs in 1946 already. Attached fotos of such a car, believed to be built in February 1946, that a friend of mine photographed some years ago in an Australian museum.
Here´s the story of this CCG bug as exposed in that museum:
ZENVWDRIVER
PostPosted: Sat Aug 25, 2018 10:21 am    Post subject: Re: 1946 front access? Reply with quote
[quote="originalo"]The access cover on the tunnel is not factory. You find those homemade openings often on bugs, they allow f. ex. to change the clutch wire without having to disassemble the pedal cluster.
yes, I like working in that area without removing the pedal assembly - I always refer it as the access VW forgot to make,.
'87 Toyota MR2
rod_vw
rod_vw is offline
PostPosted: Sat Aug 25, 2018 3:30 pm    Post subject: Re: 1946 front access? Reply with quote
The picture that you have is our '46. The front of the tunnel was badly butchered when the restoration began. Some previous owner had simply hacked a hole!
The restorer asked if I wanted it restored to factory or have a reinforced surround welded below a cleaned up hole and a flush fitted almost hidden access plate fitted, it is retained by countersunk set screws. My choice was the latter having experience of changing a clutch cable on these cars in the past.
The result is access available to the cable area and with the tunnel as strong as the original.
Rod,
www.vwbooks.co.uk -- www.historicvws.co.uk -- www.vintage-volkswagens-lavenham.co.uk
1946 Beetle (Back on the road after over 50 years! Drove from England to Bad Camberg 2019, interesting 1200 mile round trip)
2013 T5 Selfbuild Camper.
2016 T6 Selfbuild Camper completed.
KTPhil Premium Member
KTPhil is offline
PostPosted: Sat Aug 25, 2018 4:29 pm    Post subject: Re: 1946 front access? Reply with quote
This part is critical.
ZENVWDRIVER
PostPosted: Sun Aug 26, 2018 5:14 pm    Post subject: Re: 1946 front access? Reply with quote
that access was well thought out, with a real craftsmanship-like installation...looks factory, to me... your body guy is awesome... is the access VW forgot to include.
'87 Toyota MR2
splitjunkie
splitjunkie is offline
PostPosted: Sun Aug 26, 2018 5:16 pm    Post subject: Re: 1946 front access? Reply with quote
The beetle was designed with the details to build them left or right handed from the very beginning. I don't know if they were thinking of being able to export the cars or if the nazi's plans to take over the world had something to do with it.
A '46 dash
Chris
rod_vw
rod_vw is offline
PostPosted: Mon Aug 27, 2018 12:39 am    Post subject: Re: 1946 front access? Reply with quote
My body man is Steve Hook of Hooky's Panel Shop ( http://www.hookyspanelshop.com/ ) , one of the best in the UK.
Rod,
56Cabrio
56Cabrio is offline
PostPosted: Mon Aug 27, 2018 12:57 am    Post subject: Re: 1946 front access? Reply with quote
Would you mind taking the plate off and posting some detailed pics of the reinforcements done?
(WTB) San Fernando Vokes Motors plate frame & San Fernando Mission VW plate frame
[WTB] Oval era Dehne fuel gauge face US or European version
F#ck Cancer !
https://shop.stjude.org/GiftCatalog/donation.do?cID=14262&pID=24671
Stop dead photo links! Post your photos to The Samba Gallery
rod_vw
rod_vw is offline
PostPosted: Mon Aug 27, 2018 2:38 am    Post subject: Re: 1946 front access? Reply with quote
Here you go...
Don't take any notice of the left floor plate, its presence is a long story. Both floors were eventually replaced like this with new floors supplied by Kdf Osnice ( https://en.kdf.cz/inpage/catalogue-kdf-82/ ) suitably created by Ivo for a saloon.
And now the car is on the road...
Rod,
ZENVWDRIVER
PostPosted: Mon Aug 27, 2018 8:20 am    Post subject: Re: 1946 front access? Reply with quote
.. thank you Rod - that is a beautiful '46 - that access is a well executed upgrade - a great part of VW history.
'87 Toyota MR2
René R. Premium Member
René R. is offline
PostPosted: Mon Aug 27, 2018 8:27 am    Post subject: Re: 1946 front access? Reply with quote
What a beautiful car! Wow.
My current ride: 1954 Riviera Motors Oval Deluxe
