1964 ruby red sun roof new addition to the family
Page: Previous  1, 2
Sloride
Sloride is offline
PostPosted: Mon Aug 27, 2018 4:12 am    Post subject: Re: 1964 ruby red sun roof new addition to the family Reply with quote
Been busy trying to get this thing running. I haven't checked the inspection covers too closely and it's back to work today after three weeks vacation so time on the bug will be limited.
I did sneak it out for a quick drive down the street. Idles fine and pulled well in first until I shifted to second and it just bucked and had no power. I think I'm going to have to pull the carb and rebuild it. Backing out the idle jet slightly allowed me to get a decent idle but obviously didn't help with this other issue. I think it is fuel related. Can anyone tell from this picture if something isn't hooked up correctly. This car ran oerfectly when parked six years ago. Should it have a fuel filter or is it built into fuel pump?
Also spent some time polishing the roof just to see if I can bring the paint back.
1972 Westfalia - 1.8 VW in-line h2o conversion
Ottawa, Ontario, Canada
Link to the engine swap:
http://www.thesamba.com/vw/forum/viewtopic.php?t=565304&highlight=
1964 Ruby Red Beetle
https://www.thesamba.com/vw/forum/viewtopic.php?t=705757&highlight=ruby+red
67 Florida Deluxe
Samba Purist
67 Florida Deluxe is online now
PostPosted: Mon Aug 27, 2018 7:06 am    Post subject: Re: 1964 ruby red sun roof new addition to the family Reply with quote
Sounds very much like debris in the fuel system. There is (should be) a copper filter screen in the tank. I don't think that fuel pump has a plastic screen in it; I can't tell if it has a hex on the side facing the drive belt. If so, there's a conical plastic screen in there (that's the way it is on a '67 FP, which looks very similar to yours, but with the hex filter screen cover). But I cannot see behind your vacuum line. If it doesn't have the hex cover, then yours likely doesn't have a screen. In '65 the pump is slightly different - at least on mine, and it has a flat plastic screen inside the FP. But you can still get fine particulates past them. May folks put an inline fuel filter between the fuel pump discharge and carb intake but it hangs directly over the distributor. Not good. Before rebuilding the carb, you should clean out the fuel system. Pull the tank and clean it. Replace the copper filter screen. Remove the fuel pump, disassemble and thoroughly clean it. Install new diaphragm and screen from WW. Before reinstalling the FP, flush out the fuel line from the front of the car to the back. I have used a jar to collect the fuel as it comes out to see any debris that may be discharging. Do this until it runs out free of particulates. Then find a suitable place under the car to install an inline fuel filter. Now you're ready to attack the carb because you have eliminated any contaminant issue PRIOR to the carb Wink
OG member of the '67 Posse
A few of my toys, past and present
'66 KG Conv't, '67 21-Window, '67 Bug, '79 SuperVert
67 Florida Deluxe
Samba Purist
PostPosted: Mon Aug 27, 2018 7:24 am    Post subject: Re: 1964 ruby red sun roof new addition to the family Reply with quote
Here's a pic of my FP with the hex cover screw. There's a plastic conical filter behind it. WW sells rebuild kits that come with the filter.
Sloride
Sloride is offline
PostPosted: Mon Aug 27, 2018 6:20 pm    Post subject: Re: 1964 ruby red sun roof new addition to the family Reply with quote
Thanks 67 Florida deluxe. I won't get back out in the garage until probably this weekend. Appreciate the advice its the same advice I'd have given someone else. I guess I was just too anxious and wanted to see if it would start after sitting so long.
Sloride
Sloride is offline
PostPosted: Sat Sep 08, 2018 6:30 pm    Post subject: Re: 1964 ruby red sun roof new addition to the family Reply with quote
Finally got around to pulling the tank. It's unfortunately got some surface rust inside. I'm working on cleaning that up now. Have a gallon of evaporust in the tank. Swishing it around every hour or so. Cleaning it up well.
Also got the horn working again. Why the vw horns have to be so complicated I'll never understand. Turns out I spent an hour or so cleaning grounds checking the horn button, the horn itself and finally realized that while the tab at bottom of steering column was clean between it and the coloumn itself was rusty. Cleaned that up. Added some solder to help and all is well.
67 Florida Deluxe
Samba Purist
PostPosted: Sat Sep 08, 2018 6:36 pm    Post subject: Re: 1964 ruby red sun roof new addition to the family Reply with quote
By '64, VW made the horn system much less complicated. Try diagnosing a 1960! Very Happy
Nice to see you making progress! A concern though... depending on how much rust is in the tank. It may be best to go ahead and reline the tank to ensure that no bits will continue to flake off and goober up you fuel system. There are a few very good products to accomplish this.
Sloride
Sloride is offline
PostPosted: Sat Sep 08, 2018 7:19 pm    Post subject: Re: 1964 ruby red sun roof new addition to the family Reply with quote
I hear you on the tank. I cleaned out the old varnish and have been soaking it for a day or so now. I've had really good luck with the evaporust in the past.
I spent the day cleaning and rebuilding the carb so that isn't going back on there unless I know the system is clean.
Craig
Sloride
Sloride is offline
PostPosted: Sun Sep 09, 2018 1:51 pm    Post subject: Re: 1964 ruby red sun roof new addition to the family Reply with quote
Here is a picture of the cleaned and rebuilt carb. Hoping it runs as well as it looks. I also removed that funky what i am assuming is a pollution piece on front of carb.
I noticed the fuel cut off solenoid had the end cut off. Is that because this carb and motor is from a 12 volt car? Will the electric choke still work on six volts?
Q-Dog
Q-Dog is offline
PostPosted: Sun Sep 09, 2018 3:43 pm    Post subject: Re: 1964 ruby red sun roof new addition to the family Reply with quote
6V and 12V use different choke heaters.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
Sloride
Sloride is offline
PostPosted: Sun Sep 09, 2018 3:53 pm    Post subject: Re: 1964 ruby red sun roof new addition to the family Reply with quote
That's what i figured. Are they at least the same size to fit into this carb?
PostPosted: Sun Sep 09, 2018 4:23 pm    Post subject: Re: 1964 ruby red sun roof new addition to the family Reply with quote
The electric solenoid probably failed so they cut the end off so the car would still run.
If it's 6v maybe it burned up...
It should "click" when it gets power.
Turn the key on and unhook the wire to it, then re-attach it.
No click = it's bad
If you have a 12v choke you want to find a 6v one.
You are correct they are the same size for that carb.
Sloride
Sloride is offline
PostPosted: Mon Sep 10, 2018 4:18 am    Post subject: Re: 1964 ruby red sun roof new addition to the family Reply with quote
Thanks
Ericfb
Ericfb is offline
PostPosted: Fri May 10, 2019 7:24 am    Post subject: Re: 1964 ruby red sun roof new addition to the family Reply with quote
Starting to warm up out, get any work done to this beauty over the winter?
Sloride
Sloride is offline
PostPosted: Fri May 10, 2019 11:56 am    Post subject: Re: 1964 ruby red sun roof new addition to the family Reply with quote
Thanks for checking in. I've been meaning to post an update. Was a busy and long winter as you know. After rebuilding the carburetor it was still down on power. I did a compression test and the number 1 cylinder was at 50 psi. I pulled the motor and have been slowly doing a top end rebuild with new heads, pistons and cylinders. It has taken a couple of months of one hour here and one hour there. I figure another weekend or two and I'll have it back in the car. Both my boys play competitive basketball and I coach so I had little to no time in the garage over the winter. I'll post pictures later.
Sloride
Sloride is offline
PostPosted: Sun May 26, 2019 6:35 pm    Post subject: Re: 1964 ruby red sun roof new addition to the family Reply with quote
Got the motor back in. Still not running right. Flat spot hesitation. Timing, valves and points are good. Fuel filter is clean. Had to step away from it so decided to some welding. Been a year or two since I had the welder out so took some practice. Welds are not the prettiest but solid. Also canít find a rear drivers fender. Been watching the classifieds and nothing has come up in ruby red. May have to get one and paint it. Does anyone have any leads? Will pay extra for ruby red.
Page: Previous  1, 2
Page 2 of 2
