72VWSB Samba Member
Joined: August 06, 2018 Posts: 707 Location: New Mexico
Posted: Sun Aug 26, 2018 12:47 pm Post subject: 1972 Super Beetle restore...Fresh Air Box Help!? |
Pulled the fresh air box out of my 72 SB...the motor does not seem to function at all...had some nice mouse/rat nests inside of it! I put 12 volts to the wires, no nada! So, I am either looking for a good motor or a used box. Anyone know where I might look to find one?? |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
RichNJohn Samba Member
Joined: April 07, 2017 Posts: 91 Location: Palm Springs, CA
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Mon Aug 27, 2018 3:11 pm Post subject: Re: 1972 Super Beetle restore...Fresh Air Box Help!? |
A few years ago I bought a Super air box with working fan. I just want to pass on that this doesn't pass on much air, even on higher speed. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Tue Aug 28, 2018 4:57 pm Post subject: Re: 1972 Super Beetle restore...Fresh Air Box Help!? |
Cusser is correct. When I got my 72 Super Vert the air box fan was shot. I bought a new fan switch and found a box that does work but even with the fan on high it doesn't blow much more air than it does just moving down the road with the fan off. Unless you are in restoration mode and want everything to work there are probably more cost effective repairs you might want to tackle. |
vamram Samba Member
Posted: Tue Aug 28, 2018 5:03 pm Post subject: Re: 1972 Super Beetle restore...Fresh Air Box Help!? |
The vimeo videos are perfect for rebuilding the box and fan, I did that on my old '72. However, the others are also correct - the fan is not much more than a breeze, even on the "high" setting.
Now the curved windshield Super fans...those actually push a decent amount of air! _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Posted: Wed Aug 29, 2018 5:46 pm Post subject: Re: 1972 Super Beetle restore...Fresh Air Box Help!? |
I'm currently replacing many of the dash switches and have run into a situation where I need to find some of those really small female spade electrical wire connectors like the ones that go to the fresh air fan switch and the brake warning light on the dash. Does anyone know what size the connectors are and maybe a good source for them? |
AlmostHeavenWV_VW Samba Member
Posted: Wed Aug 29, 2018 7:41 pm Post subject: Re: 1972 Super Beetle restore...Fresh Air Box Help!? |
RichNJohn wrote: |
These, perhaps?
https://www.amazon.com/Uxcell-Connectors-Female-Spade-Terminals/dp/B00ACD9SQ2 _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9967 Location: Huntington Beach, CA
Posted: Wed Aug 29, 2018 7:55 pm Post subject: Re: 1972 Super Beetle restore...Fresh Air Box Help!? |
You will need to get the correct crimping tool for both parts of the connector. Give the crimper a small dab of dielectric grease. Makes for easy crimping and longer lasting connections! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Thu Aug 30, 2018 10:06 am Post subject: Re: 1972 Super Beetle restore...Fresh Air Box Help!? |
Thanks, the connectors on Amazon look like the correct size and I never thought about using dielectric grease. Good suggestion! |
72VWSB Samba Member
Posted: Sat Sep 01, 2018 4:13 pm Post subject: Re: 1972 Super Beetle restore...Fresh Air Box Help!? |
I think I have a rebuilt motor coming...we'll see when it gets here. Anyone know where to find the little rubber insulated bolt connectors? I think they're #12 or #11 on the air box diagram? Couldn't find them on McMaster-Carr... |
alaitken Samba Member
Joined: February 22, 2019 Posts: 10 Location: Virginia
Posted: Fri Jul 24, 2020 7:48 pm Post subject: Re: 1972 Super Beetle restore...Fresh Air Box Help!? |
I just rebuilt my '72 SB Fresh Air Box, including its fan motor, and it is working great. I've installed it and here's my question. On the '72 SB, did VW use the padded wrap that goes around the junction between the fresh air box outlet and the joining vent duct. I've seen the wrap on other Beetles, and have
been advised to put it on mine as well. But I want mine to be just like it was when I bought it new, so I'd like to know if VW put the wrap on the '72 SB model, and if so, what was the purpose of the wrap?
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4421 Location: Stuck in Ohio
Posted: Fri Jul 24, 2020 8:18 pm Post subject: Re: 1972 Super Beetle restore...Fresh Air Box Help!? |
alaitken wrote: |
...On the '72 SB, did VW use the padded wrap that goes around the junction between the fresh air box outlet and the joining vent duct... and if so, what was the purpose of the wrap? |
Yes, 72 SB did have the wrap, at least the yellow ones. Here are some pictures of the wrap on my Yellow 72 SB Vert after pulling back the cardboard cover over the dash area in the trunk. It looks like it is held on with some kind of rivet or button at each side of the wrap. I imagine the purpose is to seal and insulate the air flow. I did not know there was a cardboard tube inside as well so your pictures were informative that way. Looks like a beautiful build you have going there.
_________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
72 Super Duper http://www.thesamba.com/vw/forum/viewtopic.php?t=672387
(adopted out) 61 Turkis Pile https://www.thesamba.com/vw/forum/viewtopic.php?t=728764
SnowDaySyncro wrote: |
Every setback is an opportunity to learn stuff and to buy new tools. |
Posted: Fri Jul 24, 2020 8:27 pm Post subject: Re: 1972 Super Beetle restore...Fresh Air Box Help!? |
Okay then...thank you Buggeee |
Cusser Samba Member
Posted: Sat Jul 25, 2020 7:18 am Post subject: Re: 1972 Super Beetle restore...Fresh Air Box Help!? |
Buggeee wrote: |
I did not know there was a cardboard tube inside as well so your pictures were informative that way. |
I got my 1971 SB in 1976 and there were NO cardboard-type tubes inside those, just that snap-together padding. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Sat Jul 25, 2020 7:39 am Post subject: Re: 1972 Super Beetle restore...Fresh Air Box Help!? |
The cardboard type tube inside is listed in Wolfsburg West website as VW part #113819717B for the ‘71 to ‘79 Super Beetle. Wolfsburg does not have it in stock and says it is no longer made. So I instead used a corrugated paper tube of the correct size to just nicely fit into the fresh air box outlets and the vent duct...just to ensure the two remain aligned and to provide a pathway for the airflow across the open 1 1/4” space between the two openings. The “cardboard” tube does cover most of the little square holes in the box outlet and the vent duct...but not all of them.
I wonder what the little square holes are for. To keep the corrugated paper tube from migrating into the air box, I fashioned a couple of 2” long xx “pins” from a length of thin steel wire. I slipped the pins through the little square holes on the air box side of the paper tube...that keeps the paper tube from moving toward the air box. |
raydog Samba Member
Joined: February 09, 2006 Posts: 1163 Location: Cape Cod
Posted: Sat Jul 25, 2020 10:02 am Post subject: Re: 1972 Super Beetle restore...Fresh Air Box Help!? |
The info on Wolfsburg West website is also incorrect. part #113819717B is for a 68 and later Beetle, not Super. |
Posted: Sat Jul 25, 2020 10:47 am Post subject: Re: 1972 Super Beetle restore...Fresh Air Box Help!? |
Thanks for that info Raydog... but one of the many manuals I refer to in my restoration of this '72 Super is, "The Volkswagen Super Beetle Handbook"...A Restoration Guide For 1971-1974 Models, published by the Editors of VW Trends Magazine. On page 137 of that handbook is a photo of the corrugated plastic pipes known as "fresh air box hoses (113-819-717B)". And it makes sense to me to use something like that part number to keep the junction aligned. Mine had one of the two remaining when I took it apart during the restoration...don't know what happened to the other one of the two.
Posted: Thu Aug 06, 2020 7:32 pm Post subject: Re: 1972 Super Beetle restore...Fresh Air Box Help!? |
After several good suggestions found on thesamba.com, I fashioned a covering for the fresh air connections from the fresh air box to the dashboard vent ducts on each side...left and right.
Volkswagen had originally put covers on those connections, but I was not very pleased with their appearance. They were made out of some style of thick jute...but it looked more like wall batting insulation...and was kind of ugly I thought. One good suggestion I got was to cover the jute with a layer of black vinyl to dress it up.
Then I started researching what the real purpose of the coverings was...why did VW engineers put coverings on in the first place? Turns out the generally agreed-to reasons are insulation, absorption of moisture from humid air, and covering of the duct perforation holes to keep air from escaping.
As for the insulation reason, I see no actual use in that. The fresh air box pulls ambient air from above the hood, accelerates it and sends it to the vents in the dashboard. It neither cools nor heats the air in that process, so I see no need for the insulation. But the covering does prevent air from escaping through the perforation holes...and that’s important to providing more airflow through the dash vents.
And in preventing the loss of air through the perforation holes, it also allows the jute to absorb moisture from the air, minimizing humidity in the cabin. But if the jute is absorbing moisture, I want the moisture to have a place to go rather than staying in the jute and creating mold and mildew. So I figured a vinyl covering would not be good. I need something that would be black, look good and allow moisture to wick and evaporate through it and out of the jute. So I used a black cutaway backing material normally used for embroidery. It’s porous and sturdy. And together with the jute, it covers the perforated holes in the ducting and provides a significant increase in airflow to the dash vents...more than I remember getting some 48 years ago when the Bug was new. Here's some photos of the result:
mukluk Samba Member
Posted: Thu Aug 06, 2020 7:50 pm Post subject: Re: 1972 Super Beetle restore...Fresh Air Box Help!? |
Think about this for moment: why would VW put a bunch of small holes in the ductwork in the first place, and then wrap the whole thing with batting material? Your first clue is they used a similar holed duct and covering material for the heater ducting under the rear seat. Your next clue is to take a look inside a stock peashooter tailpipe. If those clues don't make things click into place, look up the official nomenclature for the wrap (part number 113 819 697). _________________ 1960 Ragtop w/Semaphores "Inga" |
