shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3803 Location: VA/TN
Posted: Mon Aug 27, 2018 9:58 am Post subject: CLK wheels [01-03] |
I decided to make a special thread regarding the specific year 01-03 CLK320 wheels. Same rim size 16x7.
No these are not the superior "CLK" wheels, aka "Fuchs" that are sought afterwards.
I scored my set from a vanagon owner, with fresh tires for $350.
I am running 225/55 R16 on a 01-03 CLK320 rims. 10mm spacers in front and back, with longer lug studs and lug bolts. The last picture shows T3's center caps on these wheels.
This post is simply to start a dedicated thread/information regarding the 01-03 CLK320 rims.
_________________ Brandon
Instagram @joannthevan |
Posted: Mon Aug 27, 2018 10:04 am Post subject: Re: CLK wheels [01-03] |
Plastidip black vs original silver
shagginwagon83 wrote: |
Aryana wrote: |
I prefer the 01-03 CLK wheels over the earlier ones.
10mm rear spacers and 5mm spacers up front from T3 Technique has my tintop sitting nice and handling awesome.
215/55-R16 Michelin Primacy mxm4 to keep the diameter as close to stock as possible. This way the gearing and suspension geometry is unchanged and the van still drives like it should.
Aryana wrote: |
We also put a set on my brother’s Flash Silver Syncro tintop with some BFG tires that are just perfect.
Aryana wrote: |
I’m getting a few PMs asking what tires I ran on my 01-03 CLK wheels so I wanted to post up the details.
I installed 215/55-R16 Michelin Primacy mxm4 to keep the overall diameter as close to stock as possible, with the goal of keeping the gearing and suspension geometry unchanged so the van still drives like it should. The one thing that did change was that it feels like it’s on rails compared to the 14” alloys and there was a huge improvement in controllability in crosswinds too.
A 10mm rear spacer left 5mm clearance to the sliding door when open. 5mm spacers on the front made the track front to rear look perfect on my 2wd tintop.
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9937 Location: Orbiting San Diego
Posted: Mon Aug 27, 2018 10:42 am Post subject: Re: CLK wheels [01-03] |
I have put those on 2 of our family vans.
No spacers, stock length studs, special nuts all around.
215/65R16 XL tires.
Slight clearance grinding needed up front for the rim lip and the tire width.
The lug bolt holes have been bored to match what VW 14" alloy rims have for thickness at the holes so stock studs can work.
Here is a photo from my recent trip along the Croatian coast. More scenic overall than PCH.
Mark |
