Joined: August 31, 2013 Posts: 12846 Location: North Carolina
Posted: Thu Aug 30, 2018 8:08 am Post subject: Re: What will happen if I put Berrymans B12 Chemtool in my fuel tank |
You're right, continue using whatever snake oil or witch's brew of your choice, I'll just continue dropping subframes, yanking oil pans, & replacing pick up tubes. Oh look, there's one now. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Zundfolge1432 Samba Member
Posted: Thu Aug 30, 2018 8:20 am Post subject: Re: What will happen if I put Berrymans B12 Chemtool in my fuel tank |
TDCTDI wrote: |
Immediate draining of the oil only gets rid of the particulate that is still in suspension (heavier particulate will settle much faster.) & it doesn't clear the screens or passages of particulate that has already been displaced & it doesn't do anything about the buildup that has been loosened that will be dislodged after the oil dump.
The product does exactly as it is designed, but it doesn't account for where all the byproduct ends up.
I have replace hundreds of oil pump pickup screens due to blockage, usually within 100 miles of a customer's visit to a chain lube shops upsell of their oil flush. |
I’ve seen aircooled VW engines ruined because of engine oil flush and have firsthand knowledge having ruined one myself. A properly maintained engine would seldom require a flush if you use name brand oil and change it on schedule. A better approach might be taking rockers and pushrods apart for thorough cleaning, a series of oil changes will be a more gentle way to clean ...An oldtimer taught me a trick for newer stuff using hydraulic lifters that are noisy. Use a small amount of automatic transmission fluid mixed with engine oil as a cleaner followed by refill of fresh oil and filter, I’ve seen it quiet things down. In the end there really is no substitute for not letting engine get gummy in the first place .......😀 |
Frodge Samba Member
Posted: Thu Aug 30, 2018 8:43 am Post subject: Re: What will happen if I put Berrymans B12 Chemtool in my fuel tank |
Zundfolge1432 wrote: |
TDCTDI wrote: |
I’ve never used any additives in my cars. I agree with this post. |
bluebus86 Banned
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Mon Jan 14, 2019 5:55 am Post subject: Re: What will happen if I put Berrymans B12 Chemtool in my fuel tank |
Could not agree more with your statement! I had a valve cover leak on my new-to-me 230k mile Ranger last year, and could hardly believe the coked up deposits I found with the valve covers off. My understanding is coked oil and sludge comes from using a cheap conventional oil and/or extended oil change intervals. However it gets there.. you definitely don't want those chunks to start breaking off and circulating. The filter is after the pump.. for those of us using filters, that is. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5994 Location: Brooklyn
Posted: Sat Jan 19, 2019 3:11 pm Post subject: Re: What will happen if I put Berrymans B12 Chemtool in my fuel tank |
Gasoline goes in the gas tank. Nothing else.
Oil goes in the crankcase. Nothing else. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Sat Jan 19, 2019 3:46 pm Post subject: Re: What will happen if I put Berrymans B12 Chemtool in my fuel tank |
Disagree, there are certain instances and conditions which warrant a chemical intervention. There is a sticky which covers this very topic and goes into much more detail. |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sat Jan 19, 2019 8:53 pm Post subject: Re: What will happen if I put Berrymans B12 Chemtool in my fuel tank |
Your thread reminded me of advice I got over 30 years ago. I had a carb-swapped '74 bus that seemed to always suck crap (this was only 10 years old at the time). But a neighborhood gas station mechanic poured a little of what sounds like this B12 product into my full tank of gas- and told me to drive it empty. I drove 240 miles round trip to a neighboring vacation town. Whatever magic and smoke was in there helped. The bus ran well and didn't cough at all once back at home. It ran great until the next Weber Progressive nightmare.
I think part of the good news lied in not having it stored in the tank- rather used up in a constant burn. ? I wonder what happens to it in an occasional-use tank. _________________
EverettB wrote: |
FU#5 |
mark tucker Samba Member
Posted: Sun Jan 20, 2019 11:31 am Post subject: Re: What will happen if I put Berrymans B12 Chemtool in my fuel tank |
Ive used lots of the berrymans.it's good stuff, never had any issues with it. I wont use seafoam. |
Posted: Sun Jan 20, 2019 12:17 pm Post subject: Re: What will happen if I put Berrymans B12 Chemtool in my fuel tank |
So what’s that mean? Last summer we got two vehicles from the estate of deceased relative. Neither had been driven much in last three years. Both needed fresh oil, batteries and even tires to be roadworthy, both ran rough and sluggish.
I thought fresh fuel and Seafoam might help and the Seafoam was on sale anyway. By the second tank of fuel and cleaner both cars ran better, much better in fact. So who can say? All I know is something positive happened and that’s really what matters. I’ve also seen BG brand cleaner which is harder to find retail and is applied direct injection to help clean dirty upper engine induction systems. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9754 Location: Oregon
Posted: Sun Jan 20, 2019 12:57 pm Post subject: Re: What will happen if I put Berrymans B12 Chemtool in my fuel tank |
My 09 Pontiac was burning a little oil on long (coast to coast) trips.
This vehicle/engine to date has less than 82K on it and seldom gets driven.
I read up on SeaFoam and gave it a shot. The oil consumption ceased.
Whatever magic snake oil it is. SeaFoam worked for my situation.
Now, will I try it in one of my ACVW engines? Not likely. They are a little less mysterious than a 6.0L GM SBV8.
EDIT: I do place an once of MMO in the gas tank occasionally. Does it make a difference? IDK! I figure it can't hurt keeping the carbs from corroding in the bowels. JMO. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4406 Location: Stuck in Ohio
Posted: Sun Jan 20, 2019 1:38 pm Post subject: Re: What will happen if I put Berrymans B12 Chemtool in my fuel tank |
I have been using Seafoam with success. I put the recommended ratio in the gas tank of my small engines and run them to operating temperature for a while at the end of the season to prepare them for winter, and have done that with my VWs as well because they don't get used in the winter. It's a gas preserver in that application.
As a cleaner, have used it in a Vanagon engine that sat for a decade. I had replaced the whole fuel system, tank, hoses, injectors etc. So all that was clean. Driving it around It was smoking burning oil like it had bad rings and the hydraulic lifters were not pumping up. The next tank I put Seafoam in the gas tank to get at the top of the combustion chamber and rings and some in the crankcase to get at the bottom of the rings, as well as inside the hydraulic lifters and whatever else is in there. By the time I had used up that tank of gas the engine was no longer smoking at all and the hydraulic lifters were pumping up. I had changed the oil a couple times but this change got alot of dirt out. I'm changing the oil every week or two with this one if I'm using ithe van as I'm just getting to know it. I wouldn't have believed it if I had not experienced it but it did seem to clean out the deposits from my piston rings and hydraulic lifters. _________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
72 Super Duper http://www.thesamba.com/vw/forum/viewtopic.php?t=672387
(adopted out) 61 Turkis Pile https://www.thesamba.com/vw/forum/viewtopic.php?t=728764
SnowDaySyncro wrote: |
Every setback is an opportunity to learn stuff and to buy new tools. |
Posted: Sun Jan 20, 2019 4:40 pm Post subject: Re: What will happen if I put Berrymans B12 Chemtool in my fuel tank |
Just for the record I like Berryman’s too. About 30 years ago they made a badass carburetor cleaner that would clean dirtiest old carbs spotless in about 15 minutes. Had a very distinctive smell probably shortened my life by a few years using it |
DeMinimis I Eat Glue
Joined: November 16, 2004 Posts: 1846 Location: Down in the pig mine
Posted: Sun Jan 20, 2019 9:50 pm Post subject: Re: What will happen if I put Berrymans B12 Chemtool in my fuel tank |
Chased a random misfire code in my daughter's CRV for years. Tried everything. Eventually, because I keep B12 around for cleaning parts, I went ahead and dumped some in the tank. Did it for a couple tanks. Cleaned the injectors and fixed the problem the random misfire. I used it on my '78 with FI after I sucked the shellac out of the tank. Ran fresh fuel with a high dose of B12 through the system, sucked that out, and refilled with fresh can and an appropriate mix. I can just reach in , hit the key, and my Beetle is running instantly. Never believed in mechanic-in-a-can snake oil BS, but I changed my tune with this. _________________ Yes Virginia, beer can make you smarter.
'78 SB CEII In Progress. |
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2659 Location: Long Island, NY
Posted: Mon Jan 21, 2019 10:27 am Post subject: Re: What will happen if I put Berrymans B12 Chemtool in my fuel tank |
I used to use Techron in my motorcycle's gas tanks on occasion, as in about twice a year. In between I used MMO every other tankful, so it wouldn't build up.
I use a little MMO in my Bug's gas, as well, again, every other tankful. IME, all engines have run a little smoother with it.
I never put additives in my oil. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
