Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
Posted: Mon Sep 03, 2018 8:24 pm Post subject: Re: New 79 Vert bought today |
HippyTom wrote: |
You never know what you’ll find. |
Maybe real good that I've never bought a vehicle over 7 years old; 2nd owner of both my VWs.
Congrats on joining the convertible club. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
HippyTom Samba Member
Joined: December 18, 2013 Posts: 676 Location: Florida, West Pasco
Posted: Mon Sep 03, 2018 8:38 pm Post subject: Re: New 79 Vert bought today |
Officially, I’m BACK in it. This was my last one. Shoulda kept it. 71 Super Vert.
Posted: Mon Sep 03, 2018 8:55 pm Post subject: Re: New 79 Vert bought today |
So after jacking it up and crawling around under the car today, I’m thoroughly impressed how nice the undercarriage is. Pans done and pristine. Vert rails perfect. Factory undercoat in fender wells. Inner fenders and heat channels look factory fresh. No rust at all. Underside on luggage shelf pristine. Just doing a little cleaning under there for now but will detail paint it under there like I did my others.
Gotta replace shocks/struts all the way around. I think it has the originals from 79. Worn out is an understatement.
Cusser Samba Member
Posted: Tue Sep 04, 2018 7:55 am Post subject: Re: New 79 Vert bought today |
HippyTom wrote: |
Officially, I’m BACK in it. This was my last one. Shoulda kept it. 71 Super Vert. |
Ooooh - that's a lot nicer than my own 1971 convertible EVER was. But I still have mine, so no seller's remorse. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed Sep 05, 2018 10:25 pm Post subject: Re: New 79 Vert bought today |
Well, adjusted the valves and changed the oil this evening.
The valves were all really tight. I mean waaay tight. But got that resolved easily.
Changed the oil and it was bad. Some thick oil on the sump plate and in the screen. Luckily I had a new screen. That one will clean up fine but having extras means I don’t have to clean it right then.
So as I anticipated, there’s been some lack of routine stuff done. But the car hasn’t been used much for a long time either.
But after a test drive all is well. I’m runnung non ethanol gas and some heet gas treatment to get any water out of the fuel system.
Next is diff fluid change, carb rebuild, new distributor and related ignition system components. And new shocks / struts all around. |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9969 Location: Huntington Beach, CA
Posted: Wed Sep 05, 2018 10:35 pm Post subject: Re: New 79 Vert bought today |
AWESOME!!!!
Sounds great! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Sun Sep 09, 2018 6:38 pm Post subject: Re: New 79 Vert bought today |
So I took the interior out and cleaned up the floor pans. Then POR15’d the pans. Below is a before and after. I don’t believe the carpet was original. It was rough so I removed. I’ve ordered new. And the original VW rubber mat just crumbled. I ordered a new one. I’ve ordered a ton of parts this past week.
The worst part was someone had covered the inside of the pans with rattle can rubberized undercoat. I hate that stuff!!! It rusted UNDER it as it held moisture. I scraped every inch of that crap off. Then wire wheeled and covered with POR15.
There was plenty of solid metal there. One tiny pin hole I JB Welded. Blended it right into the contour of the pan. Can’t even tell now.
So next is carb rebuild and new distributor Tuesday. Then detail paint the undercarriage and clean the top.
Posted: Fri Sep 14, 2018 6:11 pm Post subject: Re: New 79 Vert bought today |
Carb has been soaked, rebuilt, rejetted, and a new 009 Distributor with the Pertronix electronic ignition from my old one switched over. The carb looks and functions like brand new. The car runs like a new car!!! Strong little 1600 DP.
This weekend I'm going to work on cleaning the top inside and out and getting the wheels refurbished. Maybe replace the front seat pads, paint the undercarriage...we'll see how far I get. |
Posted: Fri Sep 14, 2018 6:17 pm Post subject: Re: New 79 Vert bought today |
Now a lady at work wants to know if I'm interested in her 72 Super hard top. Its been sitting in her garage over 7 years. She says it needs some work as it hasn't been run in many years, but it's not a rust bucket.
I might go check it out this weekend. It's not something I'd really go after right now (like a late 50s or early 60s vert, 71/72 Vert, Oval sunroof, or even a late 60s or early 70s sunroof), but if it's a good car and a good deal, I might get it. We'll see. |
Posted: Sat Sep 15, 2018 6:25 pm Post subject: Re: New 79 Vert bought today |
So I got busy cleaning the Vert top and headliner. The white canvas top was put on 10 years ago and has sat outside in FL ever since. It had a lot of stains, mold, mildew, etc and I was concerned it wouldn’t come clean.
Topps cleaner and brush didn’t phase it. Tried some Woolite in hot water and slight improvement. So considering the moldcand mildew stains, I tried some cleaner with a small bleach content and BAM!!! Looks brand new. Tomorrow I’ll apply the Topps sealant.
The headliner also cleaned up like new.
I also cleaned up the wheels with CLR and scotch brite pads. Much improved but they'll still need need to be repainted.
Posted: Sun Sep 16, 2018 6:59 pm Post subject: Re: New 79 Vert bought today |
Applied 3 coats of RaggTopp protectant today and Ospho'd the wheels and all the rust areas on the car. That should stop it in its tracks until I can get it painted.
Next is detailing the undercarriage. |
Posted: Mon Sep 17, 2018 8:30 pm Post subject: Re: New 79 Vert bought today |
Have I ever proclaimed my absolute hatred of undercoat? It’s the Devil!!!
I scraped every inch of the underneath of my tunnel to rid it of that hideous scourge. Then wire wheeled, sanded lightly, and coated it and my driver’s side Vert rail with POR15.
The underneath of the pans had a good undercoat that sets up hard, so I just cleaned it up a bit and painted it gloss black. Tomorrow night is passenger side rail and pan. Thankfully no more scraping.
Then I’ll do the front beam and suspension and the rear forks another night. Then rear suspension.
This sure would be easier with a lift.
docdanracy Samba Member
Joined: June 26, 2012 Posts: 1118 Location: Auburn, CA
Posted: Mon Sep 17, 2018 8:57 pm Post subject: Re: New 79 Vert bought today |
Nice work so far _________________ Doc
1970 Sunroof Bug Yukon Yellow (L19K)
Custom 6.5x15” 914 Sport Wheels wrapped in 185x65x15 Contis
Empi shifter, full compliment of gauges, 1679 with mild cam, stock induction
SOLD: 1974 Marina Blue Standard Beetle undergoing restoration/preservation
1679 with Kadrons and header/QP
914 sport wheels 5.5" ET40 wrapped in 195x65x15 Kumhos |
Posted: Tue Sep 18, 2018 8:28 pm Post subject: Re: New 79 Vert bought today |
Thanks. No work on the car tonight. Got home too late. But got lots of VW parts delivered today. Jbugs, Wolfsburg West, eBay.
Carpet, seat pads, rubber mats, trunk liners, door seals, top boot, little parts here and there, etc.
Lots more work to do. Enjoying every bit of it. Using my OCD to my advantage. LoL.
Considering buying a 69 Vert and a 72 Sedan. I need another garage!!! |
Posted: Tue Sep 18, 2018 9:45 pm Post subject: Re: New 79 Vert bought today |
HippyTom wrote: |
If you only knew how much I think about this!!!! I do not have a driveway and we are only allowed to park one vehicle out on our street. So, every night I have to drive one of the ladies cars to a street that has parking allowed on it overnight, just outside out neighborhood. Adding to the issue are moments currently taking place, where I am being given a 76 Bug, that does not run. I have no parking, but still, I continue to accept cars. WTF is wrong with me! Oh, I know! I need another (much bigger) garage!!! _________________ Jimbo
TDCTDI wrote: |
Posted: Wed Sep 19, 2018 5:00 am Post subject: Re: New 79 Vert bought today |
I'm talking with a contractor currently. But by the time I go through HOA paperwork, permitting, and actually get the construction done who knows how long it will be.
And all these cars are finding their way to me now. For a year I had another house for sale a mile away with an empty 3 car garage. Couldn't have had these come up then...noooOOOOooo. Only a couple months after I sold it.
I've got room in the back yard, it's just not covered. Gotta get that garage built!!!!! Fast!!!! |
Cusser Samba Member
Posted: Wed Sep 19, 2018 6:58 am Post subject: Re: New 79 Vert bought today |
HippyTom wrote: |
I'm also toying with getting an additional garage; I have 2 acres and a house with garage with a double and single door. So I've got space. I've seen separate garages in my neighborhood with both a double and single door, plus some extra space for a tack room for Mrs. Cusser, even took photos of two of them on a nearby street. I don't think I can upload those here as my guess is that the moderator would not consider such photos VW related, but I'll try.
Posted: Wed Sep 19, 2018 9:17 am Post subject: Re: New 79 Vert bought today |
When we were looking to move I found a house with attached 3 car garage and detached garage with 2 double doors. With space on each side and between and extra deep. But it was across the street just outside my daughter’s school zone.
I have a clearing in my back woods I can fit a big garage. My plan is to be big enough I could fit 6 of my Silverado crew cab 4x4s in. We’ll see. |
Posted: Wed Sep 19, 2018 9:32 am Post subject: Re: New 79 Vert bought today |
HippyTom wrote: |
LUCKY!!! I have a 2100 square foot condo with attached two car garage. My back yard is 12 feet by 24 feet. That’s it. We have no extra room.
In the previous home at the base of mount Baldy in Upland, ca, I built a very large two car garage that I ran a custom cabinet shop out of, and we still parked two cars in the front of the shop! On the side we had room for four more cars and a driveway that would hold 2 cars! Man I miss that garage. Made restoring cars so much easier!
So jealous of your garages!!! _________________ Jimbo
TDCTDI wrote: |
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
Posted: Wed Sep 19, 2018 1:49 pm Post subject: Re: New 79 Vert bought today |
Great work on the project. The top came out perfect.
I've been contemplating getting a garage built also. I need the work space. I own 3 acres but I have huge trees that will need to come down first, so that's going to cost a small fortune. I thought about getting the metal enclosed ones but not sure about their quality.
Garagejournal.com had been my porn for the last few months _________________ **1971 Super Project
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
