Mikes57BuginPA Samba Member
Joined: October 15, 2011 Posts: 101 Location: Pennsylvania
Posted: Thu Aug 30, 2018 6:51 am Post subject: Turn signals |
Continuing an old story (or beating a dead horse):
I recently converted to LED tail lights that I bought from a Samba member. My issue involves the indicator light in the speedometer not working. The LED kit comes with a 3 prong flasher unit. The Samba wiring diagram for '56 & '58 shows a four prong flasher. The 3 prong flasher is power, load and ground for the flasher unit itself. There is no place to hook up the ground going to the bulb in the speedo. The original setup (pre LED) also has 3 prongs so I don't think that the light worked then either.
Anyone know which flasher unit will work?
I can't get the turn signals to cancel (any advice would be appreciated on this too) so the light not working is a safety issue.
Edit to add that it is a 12 volt system |
Zwitterkafer Samba Member
Joined: November 17, 2007 Posts: 879 Location: Lanark County, Ontario, Canada
Posted: Thu Aug 30, 2018 11:03 am Post subject: Re: Turn signals |
You need a flasher with a "K" or "KBL" terminal, which provides a pulsed connection to ground for the speedo bulb. This subject has been covered before. As to not cancelling, check the position of the turn signal switch cancelling fingers relative to the cancelling ring on the steering wheel. _________________ "Criticism comes easier than Craftsmanship"
- Zeuxius, 400 BC |
Posted: Fri Oct 12, 2018 6:25 am Post subject: Re: Turn signals |
So....another member sent me a PM with his fix for my problem. He used a bulb holder from a later beetle (79 & up?) that had 2 spade terminals attached. Using the 3 prong flasher, I wired up the new bulb holder. I know have power to the socket (it flashes properly) but when I put (severl different) bulbs in they do not flash.
The new bulb holder seems a bit deeper than the '57 factory holder so I'm thinking the bulb is not reaching the contact in the holder.
Is there a quick fix? Should I be using a different bulb? |
