JeffRens Samba Member
Joined: August 25, 2012 Posts: 267 Location: Mishawaka, IN
Posted: Sat Jun 24, 2017 7:23 am Post subject: Oval ignition switch question |
I have 2 OE Oval ignition switches. They both seem to work fine except they don't have a spring to return them to the run position after depressing and turning them to the starter cranking position. Like I said, they work fine but I consciously have to turn them back to the run position once it starts.Both of them are the same way. Is that normal for these switches? Thanks in advance for a reply... Jeff |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Sat Jun 24, 2017 5:12 pm Post subject: Re: Oval ignition switch question |
... the 'SG' keyed switch in my '55 springs back, automatically. _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
54 Oval Samba Member
Joined: July 30, 2012 Posts: 91 Location: Alberta, Canada
Posted: Tue Aug 28, 2018 9:57 pm Post subject: Re: Oval ignition switch question |
Hi JeffRens, you might have an early Oval switch that was power on only. There would have been a second button to start the engine. My Oval is like that, it's a Canadian delivery 54. So I turn on the key, then push the button until it starts, then let the button go when it's running. Turn the key off to shut the engine off. They went to the momentary start (return spring) ignition switches sometime soon after or even during 54, I'm not exactly sure when. |
Bruce Samba Member
Posted: Sun Sep 02, 2018 6:06 pm Post subject: Re: Oval ignition switch question |
54 Oval wrote: |
Jan 1, 54 to be precise.
It's pretty common for oval switches to not spring back to the run position. Part of being an old switch. _________________
Posted: Sun Sep 02, 2018 9:48 pm Post subject: Re: Oval ignition switch question |
Precisely Bruce! 64 and-a-bit year old switches... I'm on my 3rd ignition switch in my 94 Dodge Ram farm truck with only 308,000-ish kms and it's only 24 years old! |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Mon Sep 03, 2018 7:07 pm Post subject: Re: Oval ignition switch question |
You may need to push in and twist to feel the spring back. One click to the right is ignition on. Push in and turn a bit more to crank.
Mine springs back. |
Ovally Samba Member
Posted: Mon Sep 03, 2018 10:32 pm Post subject: Re: Oval ignition switch question |
'52 - '53 : Zwitter (Oval dashboard) and early Oval have only ON-OFF switch (no return spring) and aluminum starter push button.
These switches with mounting bracket have 3 terminals on the back.
Regards. _________________ VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S MFI 1970
Mazda 929 Hardtop 1977
Mercedes SLC 180 Roadster 2018 |
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Tue Sep 04, 2018 11:14 am Post subject: Re: Oval ignition switch question |
I'm fairly certain they are all P-code switches, not SG. How many screw terminals are on the back of the switch? |
