tjet Samba Member
Posted: Sun Sep 02, 2018 4:44 pm Post subject: Westfalia roof corner repair / doubler? |
I just picked up a mint pop top roof for my tin top, but I broke one of the corners off removing it from my van, about a 5" section. I was removing it by myself, which was a...
https://getyarn.io/yarn-clip/51a2ec50-a4fd-449f-b383-acd5c416b762
Has anyone fabricated a repair or made doubler plates for a corner repair? |
Marshj Samba Member
Posted: Sun Sep 02, 2018 6:41 pm Post subject: Re: Westfalia roof corner repair / doubler? |
tjet wrote: |
I am coordinating a repair in my Multivan top. Cracked from a tree limb by the skylight. Look into boat and Jetski fiberglass work. There are reinforcements done there that have to take significant force - lots to learn from that community on fiberglassing. And most anything is repairable in the fiberglass world. I used to be a big standup Jetski finatic and even built a hull from scratch with a friend in a weekend using a mold
Lookup reinforcing superjet hull and you’ll start to learn some of the tricks that you can adopt to fixing your Westie corner |
Vanagon Nut Samba Member
Posted: Sun Sep 02, 2018 8:31 pm Post subject: Re: Westfalia roof corner repair / doubler? |
jet wrote: |
... I broke one of the corners off .... about a 5" section. |
edit: post deleted. Most likely not applicable.
1988 West DIY 50º ABA
VE7TBN |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2079 Location: Bulli Klinik, Colorado Springs
Posted: Mon Sep 03, 2018 6:45 am Post subject: Re: Westfalia roof corner repair / doubler? |
If you are referring to the metal portion of the top, you shouldn't have to fabricate anything as your tin top will have the same part, or you can get the broken section back into shape and weld it back to the top. _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
