mnkytail Samba Member
Joined: February 28, 2017 Posts: 92 Location: Houston
Posted: Wed Sep 04, 2019 6:51 pm Post subject: Re: Rebuild question on crankshaft movement fore and aft. |
It's been a year, but I literally just got this engine finally pulled altogether. Once I installed the flywheel I was able to set the endplay to exact specs and everything was tight as could be; no movement. Bench started it and ran it to seal the piston rings. Things ran great. Thanks for the tips. Thought I'd give an update. |
Danwvw Samba Member
Posted: Mon Sep 03, 2018 1:51 pm Post subject: Re: Rebuild question on crankshaft movement fore and aft. |
Just make sure that if you have the distributor drive gear installed and it's 2 washers that you have the distributor on and clamped in so the brass gear does not get in a bind against the distributor drive gear if it pushes it up. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Mon Sep 03, 2018 1:41 pm Post subject: Re: Rebuild question on crankshaft movement fore and aft. |
Thanks, guys! So, it seems that the movement of the crankshaft doesn't seem to be a concern at this point. Best thing to do is finish out the build by installing flywheel, setting endplay and going from there. |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3330 Location: 802 The Pointless Forrest
Posted: Mon Sep 03, 2018 12:22 pm Post subject: Re: Rebuild question on crankshaft movement fore and aft. |
Correct , two shims , torque flywheel (100# or more), measure endplay. Subract.004 ", result should be third shim thickness , remove flywheel, add third shim, torque flywheel again, recheck endplay . If in spec . (.003-.005). Good to go. Remove flywheel , install crank seal, install o ring , using appropriate libricants ( Bentley has this) , reinstall flywheel , torque to spec, 270 ft/lbs . Done. Good luck, dont forget to report back _________________ "Albatross"! |
cbeck Samba Member
Posted: Mon Sep 03, 2018 12:12 pm Post subject: Re: Rebuild question on crankshaft movement fore and aft. |
^ Disclaimer, the above advice is a start, not the entire process. _________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
bugheadred Samba Member
Posted: Mon Sep 03, 2018 10:58 am Post subject: Re: Rebuild question on crankshaft movement fore and aft. |
calvinater wrote: |
set your endplay, install flywheel , tourque gland nut to100 ft/lbs at least then rotate crank. then get back to thread |
tourque gland nut to100 ft/lbs ? thats wrong |
mukluk Samba Member
Posted: Mon Sep 03, 2018 10:53 am Post subject: Re: Rebuild question on crankshaft movement fore and aft. |
Correct, the endplay is set by installing a set of three shims between the #1 bearing and the flywheel with it bolted/torqued properly to the crank. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Mon Sep 03, 2018 10:48 am Post subject: Re: Rebuild question on crankshaft movement fore and aft. |
calvinater wrote: |
Can't set endplay without flywheel being installed first right? Again total neb here! |
Posted: Mon Sep 03, 2018 10:44 am Post subject: Re: Rebuild question on crankshaft movement fore and aft. |
set your endplay, install flywheel , tourque gland nut to100 ft/lbs at least then rotate crank. then get back to thread _________________ "Albatross"! |
Posted: Mon Sep 03, 2018 10:40 am Post subject: Rebuild question on crankshaft movement fore and aft. |
Hey guys, I'm trying my hand (first time) at rebuilding a 1600 DP motor. I got everything together (I've been following the Bug Me Videos) except for the flywheel and clutch. I noticed that when I push and pull the pulley the crank will move back and forth. The main bearing at the front of the engine does not move when the crank does. When I placed the bearings, everything felt snug.
Then when I turn the motor by hand there is a point in the rotation where the pulley wheel will push out and then pull back in towards the motor. Trying to figure out what's wrong. Again, I have not installed the flywheel yet. Any ideas on what my next step should be or if this is normal? |
