TheVintageVw Samba Member
Joined: July 19, 2004 Posts: 654 Location: Porter Ranch California
Posted: Mon Sep 03, 2018 1:26 pm Post subject: 67 straight axle swap. Tranny acting strange |
Purchased a drum to drum straight axle from a member here for my swap. He said it was in great condition.
Did the nose cone swap and bolted her up. (New oil as well)
Now with engine in its acting strange. In neutral I have passenger side wheel spinning. (I can stop it by hand)
When I try to put it in gear the passenger side continues to spin to but driver side seems to be getting caught on something. With the car off I can spin both side by hand and nothing seems to be binding.
It also seems that I cant really find any gears. I can get into what seems to be 4th but its just all over the place.
I made sure that the forks in the tranny lined up befor putting in the hockey stick. Could this transmission be busted or did I screw something up with the nose cone? Please see videos below.
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Mon Sep 03, 2018 3:09 pm Post subject: Re: 67 straight axle swap. Tranny acting strange |
halchka99 wrote: |
It also seems that I cant really find any gears. I can get into what seems to be 4th but its just all over the place. |
Sounds like a shift linkage problem.
Wheel turning is because you have two shafts side by side in a viscous fluid called gear oil.
Note that the mixed blades are not touching the bowl, but the bowl turns despite that.
_________________ In Stereo, Where Available! |
Posted: Mon Sep 03, 2018 5:15 pm Post subject: Re: 67 straight axle swap. Tranny acting strange |
That makes sense but why when it’s in gear does one turn and the other acts like it’s binding? |
Posted: Mon Sep 03, 2018 5:31 pm Post subject: Re: 67 straight axle swap. Tranny acting strange |
halchka99 wrote: |
Turn by hand or by engine??
Probably because the open differential is working.
View part 1 & 2. _________________ In Stereo, Where Available! |
ryans65 Samba Member
Joined: February 16, 2016 Posts: 1259 Location: Yulee FL
Posted: Mon Sep 03, 2018 6:14 pm Post subject: Re: 67 straight axle swap. Tranny acting strange |
when you did the nose cone did you make sure all the shift forks were in the neutral position? |
Posted: Mon Sep 03, 2018 6:19 pm Post subject: Re: 67 straight axle swap. Tranny acting strange |
Here is how I had it.
Busted-bolt Samba Member
Joined: April 14, 2018 Posts: 514 Location: minnesoota
Posted: Mon Sep 03, 2018 6:37 pm Post subject: Re: 67 straight axle swap. Tranny acting strange |
When you had the nosecone off did you place the lower part of the hockey stick into the grove in the shift fork extensions you have pictured here ? Those are the three metal extentions with a common groove that provides movement for the hockey stick. Place the hockey stick in the common groove and carefully slide the nosecone down the stick while assuring the flat part of the stick stays in the common groove , and ya should be set _________________ Vw collection 60 combi ,61 panel ,62 deluxe micro,82 diesel Westfalia,88 Vanagon synchro,98 Jetta tdi,11 Jetta tdi mt ,11 Jetta tdi dsg.
I do all my own work,body,engine and transmission. |
Posted: Mon Sep 03, 2018 6:50 pm Post subject: Re: 67 straight axle swap. Tranny acting strange |
I did, made sure you can swing the stick between the forks, left to right, right to left. |
Posted: Mon Sep 03, 2018 7:15 pm Post subject: Re: 67 straight axle swap. Tranny acting strange |
The stock differential have "clunky" corse bevel cut gears in them and will jerk/divide power from one wheel to another while not under a load .This is normal But any abnormal actions or noises will go away under use /load. Have you tried it on the ground yet? Is you shifter,shift coupler and shift rods doing there job? The shifter will slide side-to-side and back and fourth when the two securing screws at the base of the shifter are loosened to facilitate adjustment. _________________ Vw collection 60 combi ,61 panel ,62 deluxe micro,82 diesel Westfalia,88 Vanagon synchro,98 Jetta tdi,11 Jetta tdi mt ,11 Jetta tdi dsg.
Posted: Mon Sep 03, 2018 7:25 pm Post subject: Re: 67 straight axle swap. Tranny acting strange |
Haven’t had it on the ground just yet as the brakes aren’t hooked up. This was the first time firing it up.
I haven’t messed with the shifter since the RGB was in there and was shifting just fine.
Shift coupler is good. Shift feels good in the neutral position.I can move it side to side no problem, but thats about it. Trying to get into any gear with it running or off has the same feel. First and second hit a wall and dont go in. Feels like 3rd and 4th go in but cant be sure if those are actually 3rd and 4th.
Same with the engine out. |
Posted: Mon Sep 03, 2018 7:38 pm Post subject: Re: 67 straight axle swap. Tranny acting strange |
The indexing on the hockey stick might be different between the two transmissions and it is affecting the ranges or "shift quadrants" you can access . In this case you can do a simple shifter "shuffle" adjustment . With the nose cone off you have to make sure the shift rods that protrude all are aligned at the center detent for the two rods for 1234 and reverse is not engaged. reverse rod will only have one detent to engage. "will move only half as much as the other two" _________________ Vw collection 60 combi ,61 panel ,62 deluxe micro,82 diesel Westfalia,88 Vanagon synchro,98 Jetta tdi,11 Jetta tdi mt ,11 Jetta tdi dsg.
NAES Samba Member
Joined: September 10, 2003 Posts: 2120 Location: AREA-52 Southern Killafornia
Posted: Wed Sep 05, 2018 8:28 am Post subject: Re: 67 straight axle swap. Tranny acting strange |
I personally have used an adjustable shift copler up front in all of my past conversions. Some get away without having to do it but mine never shifter correctly without it. _________________ Barndoor Mafia
Box On Wheels
SBS #00 |
Posted: Wed Sep 05, 2018 9:29 am Post subject: Re: 67 straight axle swap. Tranny acting strange |
does that work on late style cars? I might be for early only? any links? |
johny__utah Samba Member
Joined: September 02, 2008 Posts: 426 Location: Arizona/California
Posted: Wed Sep 05, 2018 2:08 pm Post subject: Re: 67 straight axle swap. Tranny acting strange |
not sure if covered but are you using the correct hockey stick with the slight bend? correct fir this type of nose cone. _________________ 1956 L31
1961 L346 L347
1963 L380 L289 |
Posted: Wed Sep 05, 2018 2:43 pm Post subject: Re: 67 straight axle swap. Tranny acting strange |
yeah using the bus nose cone and hockey stick. |
6sixTinBox Samba Member
Joined: September 30, 2007 Posts: 539 Location: Confinement
Posted: Wed Sep 05, 2018 3:18 pm Post subject: Re: 67 straight axle swap. Tranny acting strange |
https://youtu.be/-sYLtVXb_3M
Did you make certain that your forks were without a doubt in neutral? I thought I was certain with my Benco transmission swap, turned out I wasn't after having to remove everything again. Pain in the ass, but that was my issue, the video should help ^^^. Or, your shift rod coupler isn't in the dimpled grooves for the grub screws causing the shifter to not go into gears; don't forget to safety wire those bad boys or it will come off while driving. My wheel was turning fast because it was in gear, it went into fourth as well like yours, and it was never truly in neutral. I'm now an expert in removing/installing bus transmissions because of this simple mistake. Good luck! _________________ 1966 13 Window Deluxe
It is what it is |
Posted: Wed Sep 05, 2018 4:43 pm Post subject: Re: 67 straight axle swap. Tranny acting strange |
6sixTinBox wrote: |
Did you make certain that your forks were without a doubt in neutral? I thought I was certain with my Benco transmission swap, turned out I wasn't after having to remove everything again. Pain in the ass, but that was my issue, the video should help ^^^. Or, your shift rod coupler isn't in the dimpled grooves for the grub screws causing the shifter to not go into gears; don't forget to safety wire those bad boys or it will come off while driving. My wheel was turning fast because it was in gear, it went into fourth as well like yours, and it was never truly in neutral. I'm now an expert in removing/installing bus transmissions because of this simple mistake. Good luck! |
Now you got me questioning it. I had it in what I thought was neutral. can anyone tell from the picture I posted? I know its not the greatest. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14257 Location: Casa de Oro, California
Posted: Wed Sep 05, 2018 6:43 pm Post subject: Re: 67 straight axle swap. Tranny acting strange |
halchka99 wrote: |
If all of them are lined up then it has to be neutral. If any one is in a gear you shouldn't be able to slide another one. |
Posted: Wed Sep 05, 2018 7:26 pm Post subject: Re: 67 straight axle swap. Tranny acting strange |
If a few parts went missing in the intermediate housing "the two pins between the shift shafts" at once upon a time when it was apart they would all line up on the "pushed down " side. From the picture it looks like the rails are a bit low from the central line up point for correct neutral. To test this take the cone off and cycle the center rail up then down It should have three positions ,Then find its midpoint then line the others with the centered center one ,then re install the cone /stick combo _________________ Vw collection 60 combi ,61 panel ,62 deluxe micro,82 diesel Westfalia,88 Vanagon synchro,98 Jetta tdi,11 Jetta tdi mt ,11 Jetta tdi dsg.
Posted: Wed Sep 05, 2018 7:55 pm Post subject: Re: 67 straight axle swap. Tranny acting strange |
Also I can turn the wheels by hand in neutral with no resistance from the motor. |
