Fuel Pressure Setup
MeeferMadness
MeeferMadness is offline
PostPosted: Tue Sep 04, 2018 7:05 pm    Post subject: Fuel Pressure Setup Reply with quote
Need to check the fuel pressure on my WW Okrasa engine. Not sure how to go about checking the pressure. How is a guage inserted after the pump and before the carbs? The Okrasa has all metal lines so not sure how others are setting up the pressure guage.
Thanks
Meefer Madness
RareAir
RareAir is offline
PostPosted: Sat Sep 08, 2018 8:42 pm    Post subject: Re: Fuel Pressure Setup Reply with quote
Check out last months issue of Hot VWs. There’s a featured article regarding Che king fuel pressure. As a bonus, there’s also a blueprint on how to make your own fuel pressure gauge tool
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
MeeferMadness
PostPosted: Sun Sep 09, 2018 2:13 pm    Post subject: Re: Fuel Pressure Setup Reply with quote
Hey, thanks, I think I missed that issue. I will see where I can locate that article. The part that has me puzzled is that with the metal Okrasa line going from the pump all the way to the carbs is how to insert the pressure gauge in line with the dual carb lines.
Bruce
mk-Zero
mk-Zero is offline
PostPosted: Thu Jul 14, 2022 2:55 pm    Post subject: Re: Fuel Pressure Setup Reply with quote
Sorry, old thread here. Does anyone have pics of the setup used for measuring fuel pressure that could be used in an Okrasa setup (hard lines). I don't subscribe to HVWs, so I have don't have access to the article RareAir mentioned. Thanks
Vintage Classic Specialist, Orange, CA
www.VCSresto.com
[email protected]
1952 VW Standard beetle
1955 VW Type 1, 231 hp daily driver
1956 VW Karmann Convertible Okrasa
Doug914
Doug914 is offline
PostPosted: Tue Jul 19, 2022 2:53 am    Post subject: Re: Fuel Pressure Setup Reply with quote
I used this setup. A double length 10mm banjo bolt and an additional banjo fitting with a 5mm push on barb. All from Bellmetric.com. Hope this helps Smile
1959 Karmann Ghia
1960 Single Cab
1956 Beetle Oval Window
mk-Zero
mk-Zero is offline
PostPosted: Tue Jul 19, 2022 6:47 am    Post subject: Re: Fuel Pressure Setup Reply with quote
Oh cool, thanks!!!
www.VCSresto.com
[email protected]
Vedderism
Vedderism is offline
PostPosted: Sat Sep 03, 2022 10:29 am    Post subject: Re: Fuel Pressure Setup Reply with quote
From the Sept 2018 Hot VW
