Stripped spark plug hole
wickedinhere
wickedinhere is offline
PostPosted: Wed Sep 05, 2018 9:04 am    Post subject: Stripped spark plug hole Reply with quote
I was doing a compression check while changing plugs and when i went to put the new plug in it was a no go. I looked online and see that NAPA sells a kit that cuts new threads and has an adapter for the plug. I don't really want to use a heli coil cause i don't want to drill i am pretty sure i can use the napa kit without pulling the motor. What yalls opinions? Here is a pic of the said hole.LOL
slalombuggy
slalombuggy is offline
PostPosted: Wed Sep 05, 2018 9:20 am    Post subject: Re: Stripped spark plug hole Reply with quote
whether you drill or just use a tap, there's gonna be chips to clean out. Just coat the drill or the tap with grease to catch most of them and crank the engine over for a bit to blow the rest out.
brad
rugblaster
rugblaster is offline
PostPosted: Wed Sep 05, 2018 9:44 am    Post subject: Re: Stripped spark plug hole Reply with quote
I've gone a step further and fire the motor a let it run on 3 cylinders. Leave the afflicted hole open. Yes, I said afflicted hole.
Timesert would be my pick.
'69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!!
nextgen
nextgen is offline
PostPosted: Wed Sep 05, 2018 10:20 am    Post subject: Re: Stripped spark plug hole Reply with quote
I agree Timeserts. The kit has a Tap. once the Timesert is in it usually will not come out if you force it in and use some Bearing Loc on the threads.
Just make sure you use some anti seize on the plug threads.
Buy a few extra, in case in the future if the insert comes out with the plug.
Which is no big deal!!!! Did many a Timesert. Some have pins the you hammer in place.. Just nice to have a spare to screw on the plug and go.
email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs
busman78
busman78 is offline
PostPosted: Wed Sep 05, 2018 10:29 am    Post subject: Re: Stripped spark plug hole Reply with quote
To get the cuttings out of the cylinder just tape a straw to the the nozzle of a vacuum cleaner, prefer a straw for like a slurpee. Got to grease the drill bit and tap, best to use a tacky grease like Lucas "Red N Tacky" does not get flung off as easy as other greases, several other brands available in that style.
Ditto for Time-Sert, using a Helicoil on any engine should be a crime.
wickedinhere
PostPosted: Wed Sep 05, 2018 11:35 am    Post subject: Re: Stripped spark plug hole Reply with quote
Thanks guys i ran to NAPA and got the kit Worked great and super easy to do.
Cleaned the hole out and used red thread locker on the insert.
Cusser
Cusser is offline
PostPosted: Wed Sep 05, 2018 12:58 pm    Post subject: Re: Stripped spark plug hole Reply with quote
I also have a NAPA solid threaded insert, on #2 of my 1835cc engine since 2007, see my thread here https://www.thesamba.com/vw/forum/viewtopic.php?t=217316&highlight=solid+threaded+insert
Some solid inserts are stronger than others. In my thread above, I used red Loctite on the outer threads of the insert after cleaning the threads in the head, and never-seize lubricant on the spark plug threads. And I torqued to specifications, and I can understand how some folks would be reluctant to fully torque these.
The best inserts are considered to be Time-Sert, but I didn't use those. Those require special tool to install, see http://www.aircooled.net
oldschool5er
oldschool5er is offline
PostPosted: Wed Sep 05, 2018 2:09 pm    Post subject: Re: Stripped spark plug hole Reply with quote
I just did this for someone using a timesert kit and it worked well. The kit contains the tap and the expansion tool for installing the sert then expands it to lock it in, I use red Loctite also. I picked up the kit for 14mm at the local parts store. I use grease on the tap and keep the piston near tdc, I then duct taped a small hose to my shop vac and sucked out as much as possible. Just make sure you are carefull with the tap at tdc so you don't hit the piston.
HRE in Westerville,Ohio
Full machine shop with all types of CNC. Rapid prototyping available, CNC Plasma cutting, 3D printing and Laser engraving.
jbbugs
jbbugs is offline
PostPosted: Fri Sep 07, 2018 4:23 am    Post subject: Re: Stripped spark plug hole Reply with quote
Timeserts are the best plug repair kit I ever used.
They are worth the money.
Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
69 OG paint Transporter
73' Super Beetle Champcar Endurance Roadracer
Patina my ass, that's a Rust Bucket!
earthquake
earthquake is offline
PostPosted: Fri Sep 07, 2018 10:11 am    Post subject: Re: Stripped spark plug hole Reply with quote
Just crank the motor over until the exhaust valve is open and blast it out with compressed air.
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
VW&MGman
VW&MGman is offline
PostPosted: Mon Oct 08, 2018 4:10 pm    Post subject: Re: Stripped spark plug hole Reply with quote
Has anyone ever used a Time Sert in a hi reving performance vw engine? It's a 9.1:1 compression ratio, 2165cc that I use for road racing.
CheapBusForSale
CheapBusForSale is offline
PostPosted: Sat Aug 29, 2020 11:01 am    Post subject: Re: Stripped spark plug hole Reply with quote
Does anyone know if the 14 mm thread chaser needs to be at a certain pitch or are they all the same? As I just picked up one at Advance Auto but want to be sure before I stick it in the hole . Thanks
Looking for Groovy Bumper Stickers? Check out my Ads!
busman78
busman78 is offline
PostPosted: Sat Aug 29, 2020 11:23 am    Post subject: Re: Stripped spark plug hole Reply with quote
Yes, 1.25mm
CheapBusForSale
PostPosted: Sat Aug 29, 2020 2:26 pm    Post subject: Re: Stripped spark plug hole Reply with quote
Thanks Busman that's the one I got from advance even though I found out it's about $10 cheaper at Home Depot I have on order I'll use if it's the same pitch.
CheapBusForSale
PostPosted: Sun Aug 30, 2020 9:49 am    Post subject: Re: Stripped spark plug hole Reply with quote
So I haven't tried to remedy my spark plug hole yet but have a thread chaser on order hoping that will help. But here's a few pictures of what's going on in my case to see what you think? Thanks
modok
modok is offline
PostPosted: Sun Aug 30, 2020 11:02 am    Post subject: Re: Stripped spark plug hole Reply with quote
It might be possible to remove the helicoil and install a time-sert. The thread is the same.
It might also be possible to cut and remove the first 1-1.5 coils of that helicoil and get it to work, or replace it, but I don't think it could be done in the vehicle.
airschooled
Air-Schooled
airschooled is offline
PostPosted: Sun Aug 30, 2020 11:03 am    Post subject: Re: Stripped spark plug hole Reply with quote
Is your most recent thread picture of the same hole as the first picture? I'm a little confused as to why threads showed up if you haven't tried to fix it yet. Razz
The more recent picture also looks like it has remnants of a heli-coil. Is that?
I used the 14mm Napa (not Time-Sert) repair kit in a driveway a few years ago. Got 60k more out of it before oil pressure issues retired the engine. Turn the engine over to the middle of the exhaust stroke for the offending cylinder, and rig an air compressor nozzle in the tailpipe to pair with the straw-tipped shop vacuum. I think I used a healthy amount of read thread locker on the insert, and anti-sieze on the plug.
Tap straight, with "good" pressure.
Robbie
Learn how your vintage VW works. And why it doesn't!
www.airschooled.com
Danwvw
Danwvw is offline
PostPosted: Sun Aug 30, 2020 11:24 am    Post subject: Re: Stripped spark plug hole Reply with quote
I made it from Tallahassee to Jacksonville once using chewing gum wrappers to thread in my 66 Beetle plug! I would try to find a matching head for it and have it rebuilt or perhaps change both heads for new ones.
1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
Cusser
Cusser is offline
PostPosted: Sun Aug 30, 2020 12:50 pm    Post subject: Re: Stripped spark plug hole Reply with quote
It is possible to remove the helicoil and install a time-sert or a simple solid threaded insert. The thread is the same.
On my 1835cc engine where the head rebuilder had installed heli-coils at all four, one came out after 20 years and I installed a solid threaded insert, is holding up well.
Time Sert is considered the best but needs special tools to be rented, see aircooled.net
airschooled
Air-Schooled
PostPosted: Sun Aug 30, 2020 1:43 pm    Post subject: Re: Stripped spark plug hole Reply with quote
Absolutely! My choice was between using the standard Napa insert, and making it home for Thanksgiving. I think good, careful work with a sub-quality part can often yield better results than someone not paying careful attention, in a dirty work environment with a better part. My two cents…
www.airschooled.com
