gphilflier Samba Member
Posted: Thu Sep 06, 2018 11:02 am Post subject: Wheel sizes and widths for 74 Ghia |
Starting a new subject. The Ghia I own has some supposedly rare wheels on it that most people do not like. I was told that a set of new wheels would pop it out and make it more desirable. The car has Sway-away on the rear and adjustable front. It has been lowered a lot. Other than choosing a good wheel what size tire, width wise would be recommended? There is not too much wiggle room under there are far as width is concerned. I would look much better with a slightly wider wheel in the rear. Think the current wheels are Woolfberg (sp) aluminum mostly solid. Give me some input on this even what you might think would look good. Thanks for all the info in the latch, open now and working on it. G |
slalombuggy Samba Member
Posted: Thu Sep 06, 2018 11:54 am Post subject: Re: Wheel sizes and widths for 74 Ghia |
Look in the Ghia section. There is a sticky thread devoted to wheels and suspension. And if you do a search in that section there are TONS of threads about all that you are asking.
brad |
Posted: Thu Sep 06, 2018 1:00 pm Post subject: Re: Wheel sizes and widths for 74 Ghia |
thanks Brad. Got another question you can help with surely. Tried everywhere but gonna ask you. Ghia has been in storage for a while and the brake reservoir went dry. Has two chambers and while adding more fluid noticed the other side was still empty. When does or how does it bet fluid. I hope it has a slot at the top for do not want a mess there. I just plain forgot and I installed it the last time. thanks |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17962 Location: Eugene, OR
Posted: Thu Sep 06, 2018 1:05 pm Post subject: Re: Wheel sizes and widths for 74 Ghia |
Pick out & buy your wheels first & then go on to engineer your desired stance & tires. Good place for ideas in this thread below.
https://www.thesamba.com/vw/forum/viewtopic.php?t=247735 _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13842 Location: White Mountains Arizona
Posted: Fri Sep 07, 2018 7:27 am Post subject: Re: Wheel sizes and widths for 74 Ghia |
The Karmann Ghia correct wheel offset is 46mm for the four bolt wheels. Same as the type 3. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Fri Sep 07, 2018 9:31 am Post subject: Re: Wheel sizes and widths for 74 Ghia |
phil tells us he has some rare aluminum wheels, but doesn't post a picture of them for us to identify them. I have 185X60 & 205X70 on my lowered square. 2.0 Liter 914 Porsche wheels are 5'5"X15" & work well because they have a flat face ET40.
Posted: Fri Sep 07, 2018 10:09 am Post subject: Re: Wheel sizes and widths for 74 Ghia |
gphilflier wrote: |
Just keep pouring fluid in. there is a slot near the top of the divider that will let fluid into the other reservoir once the one for the other is near full.
brad |
Posted: Sun Sep 09, 2018 12:23 pm Post subject: Re: Wheel sizes and widths for 74 Ghia |
Thanks, Brad, got it done now to bleed the brakes. First, the master cylinder was frozen but pecked on it a little and it broke loose. Just hope the seals are not gone New master cyl etc, only the old part is the fixed lines all the rest are new. but sitting for a while does nothing well. All was working fine but heat and such took the toll. How the heck anyone adjust the cable pull on the front hood is a mystery to me. I guess hold together with some needle nose vise grips and turn the lock screw with pliers. The screw head faces up and how one would get a screwdriver to it is like I say a mystery. What it is all about I guess tinkering on an old car... lol |
Posted: Sun Sep 09, 2018 12:36 pm Post subject: Re: Wheel sizes and widths for 74 Ghia |
Hey guys, I will post some pictures of the Ghia soon as I learn how. lol I will probably post on photo bucket or something. But that too is a chore for an old guy like me but I will figure it out. Thanks for all the input and apologize for all the not knowing how things. Where is my grandson when I need him. Gary |
Posted: Sun Sep 09, 2018 4:28 pm Post subject: Re: Wheel sizes and widths for 74 Ghia |
Have a picture in the gallery of my purple Ghia and going to try and get it here. No luck so far. A learning process for me.
Shows the above but no picture Lost. |
Posted: Sun Sep 09, 2018 4:29 pm Post subject: Re: Wheel sizes and widths for 74 Ghia |
I managed and did not know lol So there she is and getting it back on the road after a long storage after this was posted. |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3804 Location: Georgia
Posted: Mon Sep 10, 2018 12:42 pm Post subject: Re: Wheel sizes and widths for 74 Ghia |
gphilflier wrote: |
You really can’t choose tires without the wheels.
I like the wheels you have and offered to buy a set from someone else on here but went with gas burners as I got o response.
If you want them to pop I would polish them or polish the bare metal parts and paint the rest to match the car color.
What part of GA are you in?
I’m a little north of Atlanta.
Maybe we can have weekend play sessions? |
Posted: Mon Sep 10, 2018 1:55 pm Post subject: Re: Wheel sizes and widths for 74 Ghia |
Superior Industry Formula V wheels, but we call them Turtlebacks for their shape. They do look good polished out IMO but lots of them are painted.
https://www.google.com/search?q=vw+turtleback+whee...fox-b-1-ab _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Tue Sep 11, 2018 6:32 am Post subject: Re: Wheel sizes and widths for 74 Ghia |
Thought never crossed my mind to color match with the car but bet that would look nice. Thanks, need to tosss that thought around. I repainted them myself and quite a hassle to tape. I saw one other set in Marietta ,a at a car show and they were polished. Fella wanted a big price. Rare, probably not but researching I think only 2500 sets were made and went to Ca. I was looking t some Sprintstar wheels. One feature I do not like on the turtleback is the way they go on. Just bolts and no lugs on the hub. |
Posted: Tue Sep 11, 2018 8:25 am Post subject: Re: Wheel sizes and widths for 74 Ghia |
Jeffery, just saw your question about ny location. I am in Commerce ,Ga. |
Posted: Thu Sep 13, 2018 9:13 am Post subject: 74 Ghia |
Have a 2110cc engine with a larger oil sump and external oil cooler. The cooler is over the transaxle and with the lines after it sits for a while the sump shows over full. Now normally add extra with a new filter etc. I was wondering if it is fine to just let it be a little over full. If I did not allow for the extra going to the external cooler, then it would run somewhat low. Thoughts on this and thanks. Gary |
Posted: Fri Sep 21, 2018 4:18 pm Post subject: Re: Wheel sizes and widths for 74 Ghia |
I’m building a 2276 for mine and never really thought about leak down from the cooler. Maybe there is a one way valve that could be put in line to prevent that. Or maybe it’s a non issue?
Maybe ask that in the performance engine thread. Surely it has come up before. I suppose as long as it doesn’t pool enough to flood the cylinders there shouldn’t be a problem.
I’m on the other side of the mountain in Canton |
Posted: Sun Nov 11, 2018 1:46 pm Post subject: Re: Steering columns and wheels for 74 Ghia |
I have an expensive steering wheel, wood that I thought would fit a 74 but no Seems they changed in 74. Is there an adaptor that can be used so the new wheel will bolt down etc. Needs a bearing too. Gary aka gphil |
Posted: Sun Nov 11, 2018 10:24 pm Post subject: Re: Wheel sizes and widths for 74 Ghia |
Ask questions like this in the Ghia section. this section is for wheels amd tires.
But yes there is different adapters.
brad |
