derRHDmeister Samba Member
Posted: Sat Feb 01, 2020 7:11 pm Post subject: Re: Vintage Barndoor Beach Buggy |
For the rear wheels, I was faced with a problem: they had to be with 2" or so backspacing as the original set up had that. I tried to bolt on regular bug wheels or ones with "deep dish" but had backspace of 3" or up- it wouldn't fit and ended up rubbing on the homemade pickup bed.
It took me a while looking for the rear wheels, mostly old school welded ones. I finally found a pair nearby. Bonus, it came with old Mickey Thompson Baja tires, which looked awesome but I doubt it is roadworthy.
The 14" widened front wheels were with the bd buggy when I picked it up- it will stay that way. I am looking for proper old school tires for the front. maybe E78-14 tires? https://www.cokertire.com/sta-traxion-e78-14.html
Heres a picture after I mounted the rears on, It looks good to me but I will need to figure out the rear fenders next. It was missing when I picked it up.
_________________ Ask not what your bus can do for you, but ask what you can do for your bus.
unclespanky wrote: |
Piercy could dip those wheel cylinders between his cheek and gums and spit them out rebuilt. |
Check us out @
Instagram: DeafVolks & BarndoorBuggy |
Posted: Tue Feb 18, 2020 12:05 pm Post subject: Re: Vintage Barndoor Beach Buggy |
adding more progress pictures after a trip to Sierra Madre Collection to pick up a master cylinder from early 356 (direct bolt-in)
Taillight mounting holes were similar to 356 beehives, so I grabbed a pair from SMC.
Check us out @
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Fri Feb 21, 2020 3:54 am Post subject: Re: Vintage Barndoor Beach Buggy |
Great thread, keep up the good work. Looking forward to a driving video soon _________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Posted: Mon Feb 24, 2020 10:36 am Post subject: Re: Vintage Barndoor Beach Buggy |
Thanks for the interest. I know this project is somewhat an oddball but I think it deserves some type of documentation and research support. I think that's why I posted here, in case someone might chime in with their experience with baja'd buses from the early days.
Anyway, as much I'd love to have a driving video soon, this project hit a major roadblock. When I got it, the shifter managed to get in 3rd & 4th gears but never could get in 1st or 2nd gears. Let's see why...
It appears the transaxle case was not barndoor, as I looked for the stampings to indicate its origin. The nose cone had 29 series #'s which I assume is barndoor, along with the axles of course.
Cleaned
Oh crap...
Check us out @
TheRustySuper Samba Member
Joined: June 24, 2009 Posts: 2076 Location: New Albany, IN
Posted: Mon Feb 24, 2020 11:02 am Post subject: Re: Vintage Barndoor Beach Buggy |
I don't own a Barndoor (or even a bus) but I've been following along since you got this thing. Neat seeing something like this getting put back on the road! _________________ My '72 Super |
nshaddox Samba Member
Joined: January 18, 2005 Posts: 612 Location: Hammatramma, MI
Posted: Mon Feb 24, 2020 12:08 pm Post subject: Re: Vintage Barndoor Beach Buggy |
nice safety shoes. I wear similar in my shop.
you can always adapt a later center section in and just save the bd reduction setup. thats probably what I'd do. doesn't make much sense to spend a bunch of $$ for year correct trans rebuild on this thing I'm guessing.
Either go w/lollipop front mount or fab up a center mount or fab some of those drop mounts I've seen other split bus folks use. I was considering getting some laser cut myself once the weather turns and I can confirm measurements. |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2179 Location: Graz, Austria, Europe
Posted: Mon Feb 24, 2020 2:22 pm Post subject: Re: Vintage Barndoor Beach Buggy |
Most probably the water got in from the small vent hole, that's on top of the nose.
why not try to clean the crap out and try to get the 1/2 gear selector unstuck. the corrosion doesn't seem that bad and the gasket surfaces are intact. Let's not bury this tranny before it's dead !
I like the beehive taillights and loving how you were able to reuse the og master cylinger aluminium reservoir. that is way cool ! _________________ Hotrods, Fords, Veedubs and Triumph Twins !
62 Dickholmer, custom color Seeblau L360
67 1500 Käfer, og paint Lotus weiß L282 w/red interior |
Posted: Wed Feb 26, 2020 8:44 pm Post subject: Re: Vintage Barndoor Beach Buggy |
When we had to get the transaxle out, we were forced to remove the gas tank to access the coupler bolts from the top. This slim design made it possible for the fuel tank to be mounted right under the driver's seat. This tank was peculiar to the British era sports car, based on possibly an early MG or AH because of the side-mounted "smiths" sender and top filler neck, the other clue is its distinctive stampings on the top and slightly curved ends.
For the moment, I will check to see if the tank is of any good use and if the sender can be replaced. I will run them as it is if possible.
Anyone who may recognize this tank, please chime in. Here are a few examples I've found so far...
https://www.bpnorthwest.com/fuel-tank-mg-midget-72...gJF4PD_BwE
http://www.victoriabritish.com/features/mg/MGFTL.h...gLpBPD_BwE
Check us out @
Posted: Sun Apr 26, 2020 8:34 am Post subject: Re: Vintage Barndoor Beach Buggy |
Quarantine Update:
with everything going on, I took a pause to focus on the kid's E-learning or distant schooling and I had issues with the nose cone on the rebuilt transaxle. Thanks to Vintage Warehouse for sending me the lollipop mount for the syncro trans, which solved the fit issue and pushed me to finish this phase. I had Benco swap the barndoor axles on a 4.37 pro sand unit I had laying around and flipped the center section, it should work ok with the 36hp and super tall rear tires.
Speaking of tires, I decided to go with General Grabber ATs, the fronts are 27x8.5r14 and the rears are 31x10.5r15 I think it looks decent. I painted the old buggy rims in L82 silver-white. I'm not quite sure if I will run hubcaps or not however that's not important right now.
Next item on the checklist to get the brake bleed, the gas tank hot dipped and see what repairs it will need, then wire up this bad boy. The engine is waiting for me to finish up the new seals all around and top-end assembly. Getting there soon. _________________ Ask not what your bus can do for you, but ask what you can do for your bus.
Check us out @
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4574 Location: St Charles, MO
Posted: Thu Apr 30, 2020 5:25 am Post subject: Re: Vintage Barndoor Beach Buggy |
You and your supplier friends are doing an awesome job refreshing and returning this piece of early off-road history to the road/trail! It's exciting to see your progress, and like others, we are waiting breathlessly for the "first drive'" video! Keep up the great work!
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Joined: August 31, 2013 Posts: 12861 Location: North Carolina
Posted: Mon May 04, 2020 2:13 am Post subject: Re: Vintage Barndoor Beach Buggy |
This thing is awesome!
With the internals of the transmission in the condition that they were, did you open up & inspect/rebuild the reduction boxes?
Great job on the beast. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon May 04, 2020 2:19 pm Post subject: Re: Vintage Barndoor Beach Buggy |
TDCTDI wrote: |
Great job on the beast. |
the rgb boxes were rebuilt and bearings replaced by benco when swapped on to the previously rebuilt pro sand tunnel case unit. _________________ Ask not what your bus can do for you, but ask what you can do for your bus.
Check us out @
Posted: Wed Jun 03, 2020 12:21 pm Post subject: Re: Vintage Barndoor Beach Buggy |
not a barndoor but check this out!
https://www.thesamba.com/vw/classifieds/detail.php?id=2385370 _________________ Ask not what your bus can do for you, but ask what you can do for your bus.
Check us out @
mr. warehouse Samba Member
Joined: February 27, 2001 Posts: 5001 Location: Nor Cal 707
Posted: Wed Jun 03, 2020 12:24 pm Post subject: Re: Vintage Barndoor Beach Buggy |
$500 price drop in the past day as well. |
Posted: Sun Jun 07, 2020 7:10 am Post subject: Re: Vintage Barndoor Beach Buggy |
Updates:
Put in the 36hp with the rebuilt 6v thin slot generator and rebuilt screw terminal 6v starter. I started to check off most items on the list.
I'm on a hunt for pair of an old fender, any kind, perhaps from a single wheel trailer or something- to fab some kind of rear fender soon.
Also, the gas tank is no bueno, the radiator shop told me it was too far gone to fix with thin spots due to rust. I guess I will have to figure out a low profile gas tank solution.
I had to get this license plate frame for this ride.
Check us out @
Peter_N Samba Member
Joined: February 19, 2014 Posts: 322 Location: The Netherlands
Posted: Mon Jun 08, 2020 11:28 am Post subject: Re: Vintage Barndoor Beach Buggy |
Nice update, a pity about the gastank though
Really dig the plate frame _________________ My 1958 PGSG project topic |
Posted: Thu Jul 15, 2021 6:17 am Post subject: Re: Vintage Barndoor Beach Buggy |
It's overdue for an update. Not much has been done but a major event happened. I packed up and sold our house in So Cal, moved to Eastern Tennessee near the Smoky Mountains. I sold almost everything VW I had except for the BD Buggy. I decided to stash it at my mom's cabin for a while before I could get a plan sorted out for this one.
After a while, a plan was hatched. Thanks to my good friend, Justin from Kombi Haus who graciously accepted the undertaking to finish up what I started, as I began to hit a wall regarding my abilities. I feel better now that it's in super capable hands, I hope to update this thread with a driving video in the future.
Here you can see him wondering WTF he got himself into.
(I could have sent this to any Baja/VW shop in So Cal but this is a Type 2 spec off-road vehicle, I couldnt think of anyone else) _________________ Ask not what your bus can do for you, but ask what you can do for your bus.
Check us out @
Posted: Sun Aug 15, 2021 7:16 am Post subject: Re: Vintage Barndoor Beach Buggy |
VWsArent4Hippies wrote: |
I’m not too far from you, in NC. When you bring this to the East Coast, we’ll have to get these two together at a show!
That's an awesome ride. tell us more about it. I believe it is too familiar that I've seen it somewhere before... yes definitely let's plan on meeting up once I get it running. _________________ Ask not what your bus can do for you, but ask what you can do for your bus.
Check us out @
EverettB Administrator
Joined: April 11, 2000 Posts: 69830 Location: Phoenix Metro
Posted: Tue Mar 01, 2022 4:36 am Post subject: Re: Vintage Barndoor Beach Buggy |
UPDATE:
It's alive! Jim Bass at Kombi Haus has been hard at work getting it to this stage. More to come with specifics but here's a video for now:
https://www.instagram.com/tv/CaiQuU_pgXD/?utm_source=ig_web_copy_link _________________ Ask not what your bus can do for you, but ask what you can do for your bus.
Check us out @
