Turp75 Samba Member
Joined: February 12, 2021 Posts: 40 Location: South Carolina
Posted: Fri Feb 19, 2021 5:58 pm Post subject: Re: Deebs' 1971 Super Beetle "Refresh" |
Had one of the rear tail light housings that had a broken tab so today we replaced them both. We decided to go with American style since they don't have the amber turn signal lenses.
Turp75 Samba Member
Posted: Fri Feb 26, 2021 4:36 am Post subject: Re: Deebs' 1971 Super Beetle "Refresh" |
Starting to refresh the rear shocks and front struts and give Fireball a little ride height adjustment.
Turp75 Samba Member
Posted: Fri Feb 26, 2021 12:11 pm Post subject: Re: Deebs' 1971 Super Beetle "Refresh" |
Springs are off for powder coating and we're kicking rocks waiting on the new shocks, struts, and adjustable strut housings to arrive now.
Lemons 4 Gigi Samba Member
Posted: Fri Feb 26, 2021 2:15 pm Post subject: Re: Deebs' 1971 Super Beetle "Refresh" |
Nice picture. _________________ 1971 Super Convertible "Gigi", Lemon Yellow (Factory Zitronengelb L-11E)
1970 Dodge Challenger R/T "Jezzy", 440, 4-spd, pLuM cRaZy!
A couple of Jeeps.. |
Turp75 Samba Member
Posted: Fri Feb 26, 2021 2:32 pm Post subject: Re: Deebs' 1971 Super Beetle "Refresh" |
Thanks! |
Turp75 Samba Member
Posted: Mon Mar 01, 2021 5:40 pm Post subject: Re: Deebs' 1971 Super Beetle "Refresh" |
Rear shocks are on. Still waiting on the coil springs to come back. Meanwhile considering going black with the rims.
Turp75 Samba Member
Posted: Mon Mar 01, 2021 5:47 pm Post subject: Re: Deebs' 1971 Super Beetle "Refresh" |
So we got the new dash in from Jbugs. It's missing the hole for the windshield wiper switch?? I've email Jbugs. Anyone ran into this before? Seems like it wouldn't be too hard to put the hole in it but I'm a little concerned since I've got zero experience with interior stuff.
kpf Samba Member
Joined: March 01, 2017 Posts: 852 Location: California, US
Posted: Tue Mar 02, 2021 11:35 am Post subject: Re: Deebs' 1971 Super Beetle "Refresh" |
Turp75 wrote: |
So we got the new dash in from Jbugs. It's missing the hole for the windshield wiper switch?? |
Starting with 1972, VW put the wiper switch on the steering column. Probably the replacement dash pad lacks that hole so that it can work for all years that had that style of dash, with or without the wiper switch on the dash. _________________ 1971 Super Beetle |
Turp75 Samba Member
Posted: Tue Mar 02, 2021 12:17 pm Post subject: Re: Deebs' 1971 Super Beetle "Refresh" |
Thanks. I assume an exacto knife would be the right way to go about putting the hole in it? |
kpf Samba Member
Michael Ambrozik Samba Member
Joined: October 17, 2020 Posts: 631 Location: San Jose, CA
Posted: Tue Mar 02, 2021 1:41 pm Post subject: Re: Deebs' 1971 Super Beetle "Refresh" |
Have a 1971 SB and that is what I had to do. I got my pad from WW, but they all come from the same place. |
Turp75 Samba Member
Posted: Tue Mar 02, 2021 2:31 pm Post subject: Re: Deebs' 1971 Super Beetle "Refresh" |
Very helpful! Thank you both! |
Turp75 Samba Member
Posted: Thu Mar 04, 2021 5:25 am Post subject: Re: Deebs' 1971 Super Beetle "Refresh" |
So the suspension is pretty much wrapped up. I discovered that hard turns or body roll are going to require a little modification on the ball joint studs. Shouldn't be difficult to fix. Surprisingly the car rode really well with the stock suspension pieces that had seen their better days. I'd say the new stuff improved the ride quality but not drastically. In my humble opinion it did drastically improve the look of the car by getting the nose down out of the air.
raydog Samba Member
Joined: February 09, 2006 Posts: 1163 Location: Cape Cod
Posted: Thu Mar 04, 2021 5:58 am Post subject: Re: Deebs' 1971 Super Beetle "Refresh" |
I had the same problem with the ball joint stud rubbing the wheel during a corner. Just grind off the bottom edge of the stud, problem solved. |
Turp75 Samba Member
Posted: Thu Mar 04, 2021 8:24 am Post subject: Re: Deebs' 1971 Super Beetle "Refresh" |
That's the plan. The passengerside is about 1/4" higher front and back than the drivers side. I measured both factory springs at 17" uncompressed so I'm not sure why the difference from side to side on the front. It was equal when I took it off of blocks but after driving and letting the suspension set it changed. Not much but I'm curious as to why. I assume the back could simply be the torsion bars a little out from side to side. |
AutoMechanic Samba Member
Joined: December 28, 2019 Posts: 483 Location: Roanoke Virginia
Posted: Thu Mar 04, 2021 11:05 am Post subject: Re: Deebs' 1971 Super Beetle "Refresh" |
Nice beetle and garage too . Looks like it’s coming along nicely. |
Turp75 Samba Member
Posted: Thu Mar 04, 2021 11:11 am Post subject: Re: Deebs' 1971 Super Beetle "Refresh" |
Thanks for the compliments. Complete interior makeover is next. Hopefully have the last few pieces in the coming weeks and get it installed by May. |
Turp75 Samba Member
Posted: Mon Mar 08, 2021 4:30 am Post subject: Re: Deebs' 1971 Super Beetle "Refresh" |
So I've cut the lower ball join stud off about as far as it can be cut. Still having an occasional slight rub though. Only on the drivers side. It takes a combination of turning the wheels sharp left and a little body roll for the rub to occur. I measured both springs uncompressed at 17". The driver side front is sitting 3/8" lower than the passenger side front. Could this possibly be due to one spring being slightly weaker than the other? If so has anyone used a coil Spring rubber booster? Seems like it would work to me. |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4419 Location: Stuck in Ohio
Turp75 Samba Member
Posted: Mon Mar 08, 2021 8:52 am Post subject: Re: Deebs' 1971 Super Beetle "Refresh" |
I did adjust the driver's side wheel bearing. I tightened it until I physically couldn't move the rotor and then backed off 1/4 of a turn. |
