Danwvw Samba Member
Posted: Sun Jun 16, 2019 8:31 pm Post subject: Re: just bought a seized 356SC engine. Want to talk about it? |
Danwvw wrote: |
I have the Harry Pella"Pellow" tapes if you have a VCR and a lot of time to watch them. |
Looks really good this fellow has some parts for them: https://www.thesamba.com/vw/classifieds/detail.php?id=2045571
Don't give up there are parts to be had last time I rebuilt a 356 Engine the Main bearings were still like Just $60 but that was in the 80's I think. Check everything especially piston to head clearance and if you run the big bore kit there probably will be about a .100 cylinder shim required, At least on the 356A engines with the NPR cylinders. I forgot mine. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
blackmoontravelcompany Samba Member
Joined: January 28, 2016 Posts: 15 Location: Portland, Oregon
Posted: Thu Jan 02, 2020 3:40 pm Post subject: Re: just bought a seized 356SC engine. Want to talk about it? |
tisius wrote: |
So did you start on the engine? |
Actually, the engine is in my shop now, and being converted to fit a 912. _________________ Measure twice, cut once.
Beat it to fit, paint it to match.
Go fast, don’t die. |
theduck Samba Member
Joined: March 05, 2006 Posts: 236 Location: hesperia california
Posted: Fri Dec 11, 2020 7:42 pm Post subject: Re: just bought a seized 356SC engine. Want to talk about it? |
Hello all.Say read this post and thought I would piggyback off it.I have a 356 engine numbered,P *605529*.Numbers on top of engine are 25/25 ,47923/61671.Here goes I want to put pistons rings on it,It has the 4 ring piston. And came with no rings on it.So I have located a set.Problem is is finding pictures/diagram ,to locate how the rings are placed. I am also wanting to rebuild it.I have not split the case,it rotates,but after 3 turns it locks up.So any clues?Thx,all |
