Burlinsonk Samba Member
Joined: August 10, 2018 Posts: 6 Location: Stowe, Vermont
Posted: Sun Sep 09, 2018 9:40 am Post subject: 1988 Cabriolet transmission |
Want to put later model 2.0 in a 1988 Cabriolet and keep the automatic trans. In the car. Will the 2.0 bolt to the 1988 automatic trans? |
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Sun Sep 09, 2018 9:48 am Post subject: Re: 1988 Cabriolet transmission |
Yes, the problem is going to be getting the throttle linkage to work correctly since it is actuated through the transmission. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Mon Sep 10, 2018 8:20 am Post subject: Re: 1988 Cabriolet transmission |
Look into keeping the stock head and putting it on the ABA block. It should solve a lot of problems on plumbing and just may keep the transmission linkage happy. |
Posted: Sat Sep 15, 2018 11:17 am Post subject: Re: 1988 Cabriolet transmission |
Is the 1.8 head a direct bolt on? Any other modifications? |
Posted: Sat Sep 15, 2018 2:50 pm Post subject: Re: 1988 Cabriolet transmission |
I have never done it. So double check everything I mention.
I believe it does. An ABA head has the intake on the opposite side of the head and that means you would have several things that are in a different location. So that means a lot of the stock stuff would have to be butched to make it work. This would include the automatic transmission linkage.
If you use the original head [I'm assuming you have the stock engine in it now and that should be a JH hydraulic lifter head], then the main difference is that the head would sit slightly higher [The ABA block is 16mm taller]. I believe the oil and coolant ports align properly and I know the headbolt spacing is the same.
So if you do put the JH head on, I believe there is enough wiggle room for the stock components to reattach everything to the intake/throttle, etc. without any hassle.
Again, I have not done this but I do plan on it in the future. My wife has a 91 Cabriolet and it is an automatic also. |
Posted: Sat Sep 15, 2018 3:02 pm Post subject: Re: 1988 Cabriolet transmission |
http://www.techtonicstuning.com/ABA_Engine_Swap.htm _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon Sep 17, 2018 5:16 pm Post subject: Re: 1988 Cabriolet transmission |
How hard would this swap be if it was a standard? Have a 1990 with cable throttle. |
Posted: Mon Sep 17, 2018 5:47 pm Post subject: Re: 1988 Cabriolet transmission |
Probably slightly easier since the linkage should not be effected by the engine. |
Posted: Mon Sep 17, 2018 6:00 pm Post subject: Re: 1988 Cabriolet transmission |
Burlinsonk wrote: |
Much easier! _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
