Braukuche Samba Member
Posted: Sat Mar 09, 2019 3:50 pm Post subject: Re: VJU 4 BR 8/ 0 231 115 040 Cast Iron SVDA Distributor |
Glenn wrote: |
Yes but you might have a issue timing it since the points might have a advance added to it if the 2 plates are not locked in the 0 advance location.
Think about it, the vacuum canister moves the points to add advance. If it's not located correctly to the fixed plate you can have the advance off or have rotor phasing. |
So if you compare a working distributer and mark the position on the plate with no vacuum on the advance unit then you should be at zero I assume?
Thanks for the info! _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Sat Mar 09, 2019 4:05 pm Post subject: Re: VJU 4 BR 8/ 0 231 115 040 Cast Iron SVDA Distributor |
Braukuche wrote: |
Thanks for the info! |
Yes.
_________________ Glenn
Member #1009
#BlueSquare |
