thomast Samba Member
Posted: Tue Sep 11, 2018 9:27 am Post subject: 1995 EVC Manual - FANS aren't cycling |
Hello - My fans when at idle or at slower around town speeds aren't coming on and the temp starts to rise. Normally, if I have the van idling, the fans will come on about every 3 to 5 minutes for about a minute and then stop. Looking for some tips on what to look at first?
Thanks!
Thomas |
Posted: Tue Sep 11, 2018 9:37 am Post subject: Re: 1995 EVC Manual - FANS aren't cycling |
Meant to say, normally the fans would come on about every 3 to 5 minutes. Currently they are not. Thanks! |
Joined: August 31, 2013 Posts: 12854 Location: North Carolina
Posted: Tue Sep 11, 2018 11:56 am Post subject: Re: 1995 EVC Manual - FANS aren't cycling |
Fuses, relays, resistors, fans. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Tue Sep 11, 2018 1:55 pm Post subject: Re: 1995 EVC Manual - FANS aren't cycling |
The fans and resistors are fairly new, so hoping it's a fuse or relay. Thanks! |
tds3pete Samba Member
Joined: April 04, 2004 Posts: 914 Location: Seattle, WA
Posted: Wed Sep 12, 2018 2:08 pm Post subject: Re: 1995 EVC Manual - FANS aren't cycling |
An easy way to troubleshoot is to move your a/c lever to a/c. Then turn on the ignition but don't start the engine. The fans should be running.
Now work your way upstream with a meter. _________________ '58 Westy camper-come and gone
'73 Westy-bought new in Holland,now gone
'86 Syncro weekender-come and gone
'79 Westy...Oscar
'95 Eurovan Camper/5 spd...Marsha Mellow |
