Matt Wilson Samba Member
Joined: November 14, 2005 Posts: 2408 Location: Colorado
Posted: Thu Sep 13, 2018 10:56 am Post subject: Re: Looking at a 70 beetle Classic |
To me he's selling you the engine/transaxle (as cores) and wheels.
The rest is a huge rusty full restoration. If you have the time and skills, and enjoy the work, buy it for $500, then buy two donor cars! Just to repair that rear parcel shelf involves surgical cutting, drilling, etc. not to mention you'll remove the glass, transaxle, engine, and possibly even be required to split the pan. Then all new interior.
Ball joints and other mechanical stuff is fairly easy and cheap, which is why it was already done.
It's cars like this that probably keep fostering this "patina ratrod look" garbage that keeps popping up at car shows. (Apparently EVERY VW is a show car) _________________ 1972 Standard Beetle
1969 Baja Beetle |
sb001 Samba Member
Posted: Thu Sep 13, 2018 11:11 am Post subject: Re: Looking at a 70 beetle Classic |
Matt Wilson wrote: |
It's cars like this that probably keep fostering this "patina ratrod look" garbage that keeps popping up at car shows. (Apparently EVERY VW is a show car) |
Watch out you'll get joey and scott h after you!!!
https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
AlmostHeavenWV_VW Samba Member
Posted: Thu Sep 13, 2018 11:21 am Post subject: Re: Looking at a 70 beetle Classic |
FWIW, I picked up my beetle in the Harrisburg area for not much more than that asking price.
My bug came rock-solid, running, driving, intact paint (some primer, but good shape), maintenance records.
Save your $$$ unless you are really wanting to weld and grind. There are better quality/condition beetles out there (and lots of them are closer to you than they were to me) for not much more $$$$.
That parcel shelf/package tray in and of itself is a LARGE undertaking. If you care to see what it takes to do it right, check this thread out:
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=28 _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
Posted: Thu Sep 13, 2018 12:20 pm Post subject: Re: Looking at a 70 beetle Classic |
Dude how do I even find you talking about me on another thread???
You need to get past it. Life's too short to worry about patina.
I like the way that car looks. I would buy it for about $1400, fix the rear shelf and floors, make it safe and ride it.
While others worry about their cars not being 100% perfect, I'll be enjoying a sweet looking, 40+ year old bug with no worries on my mind. _________________ **1971 Super Project
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
kpf Samba Member
Joined: March 01, 2017 Posts: 853 Location: California, US
Posted: Thu Sep 13, 2018 12:54 pm Post subject: Re: Looking at a 70 beetle Classic |
Dugout5 wrote: |
...Owner is a mechanic and said it would pass state inspection ... |
I don't live in a state that requires inspections, so I don't know anything about them, but wouldn't having a 6-square-foot hole in the floor cause it to fail inspection? If you drive that thing as-is, you're going to be breathing exhaust, dirt, hot oil and whatever else is under the rear of the car.
For future knowledge, there is supposed to be a metal floor (parcel tray) above the transmission. You should not be able to see any of the ground below when looking at the interior of the car! Similarly, you should not be able to see any of the ground below when looking in the engine compartment! _________________ 1971 Super Beetle |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Thu Sep 13, 2018 1:11 pm Post subject: Re: Looking at a 70 beetle Classic |
If it is anything like here, inspectors only look at windshield, lights, horn, and maybe anything obviously wrong like a missing door handle. When I was a kid they would at least drive the vehicle to make sure the brakes worked, but I haven't had that happen in many years. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9971 Location: Huntington Beach, CA
Posted: Thu Sep 13, 2018 5:35 pm Post subject: Re: Looking at a 70 beetle Classic |
TDCTDI wrote: |
VW_Jimbo wrote: |
If you do not want to deal with the rust. Buy it. Get it registered in California. Then bring it over to me. Hand me $4000.00, plus your current California registered Bug and I will give you my current 70 Bug, minus the engine and transmission. I do have a used stock tranny I could install for you. We would need to swap rims and tires too. But you would get, a completely rebuilt front end, narrowed, so you can run wider tires if you like. Also, all the rust has been cut out of the body and patch and primed. Pan is in excellent shape, no holes. Never been hit in the front or the back. New rubber at the windows. Pop outs at the back. New dash panel, radio, speakers, seat covers. Windows all work. All electrical works. Hood opens, new gas tank and fuel lines. Disk brakes up front. Rear brakes all new parts. New shocks, new tie rod ends, new ball joints, rebuilt steering box, new horn, new lights, new turn signal switch, etc......
PM me if interested! |
That sounds like a convoluted clusterfuck. Why would anyone pay $2,700 for a car, transport it from coast to coast, give it AND $4,000 for a rolling shell that has been patched together? |
Good question. Maybe they are not mechanically inclined. Maybe they have a bunch of money and feel like sharing. Maybe they do not possess the skills, tools or talents. I don’t know. I do not ask that question, because I do have the tools, the talent and enough free time to do it. I just enjoyi supplementing my income! Helps me with the college bills! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Thu Sep 13, 2018 5:49 pm Post subject: Re: Looking at a 70 beetle Classic |
AlmostHeavenWV_VW wrote: |
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=28 |
Thanks for pulling that tread up! That was the easy way to do it! The full tray is a royal pain in the arse!
Thanks for not raking me over the coals like knucklehead 1 and 2. I think they are jealous that I like to weld and grind on these little cars and that my current one has a clutch pedal! Don’t know, don’t care to know! _________________ Jimbo
TDCTDI wrote: |
sb001 Samba Member
Posted: Thu Sep 13, 2018 6:09 pm Post subject: Re: Looking at a 70 beetle Classic |
VW_Jimbo wrote: |
Thanks for not raking me over the coals like knucklehead 1 and 2. I think they are jealous that I like to weld and grind on these little cars and that my current one has a clutch pedal! Don’t know, don’t care to know! |
WE'RE the knuckleheads???
You just asked a guy to pay $2700 for a tattered piece of shit, pay to have it transported all the way across the fucking country, pay to have it tagged and registered in California, and pay you another $4 fucking thousand dollars on top of all that -- and he gets a rolling shell in return???? What's that -- around $8k total if not more?? And that makes more sense to you than him just waiting for a better DRIVABLE car to show up locally for thousands less??
I wondered if there was sarcasm at play in your post, but apparently not since you took offense to our questioning whether you are actually sane.
I'll say it again:
WHAT
THE
FUCK.
I mean holy SHIT. Is business really that bad???!! _________________ I'm the humblest guy on this board.
1600 SP engine
Dwayne1m Samba Member
Joined: December 31, 2011 Posts: 3538 Location: Pennsylvania
Posted: Thu Sep 13, 2018 6:10 pm Post subject: Re: Looking at a 70 beetle Classic |
Q-Dog wrote: |
If it is anything like here, inspectors only look at windshield, lights, horn, and maybe anything obviously wrong like a missing door handle. When I was a kid they would at least drive the vehicle to make sure the brakes worked, but I haven't had that happen in many years. |
PA inspection looks at EVERYTHING. Brakes, lights, exhaust, suspension, shocks, ball joints, rust on the frame/chassis, leaks of any kind, cracked/broken glass, emissions, engine warnings, window tinting, .... It all depends on how picky the mechanic is as to what he'll pass or fail, but his name is on the inspection sticker so he has a lot riding on his work. |
Zundfolge1432 Samba Member
Posted: Thu Sep 13, 2018 6:14 pm Post subject: Re: Looking at a 70 beetle Classic |
So there it is and it runs the gamut. Some would buy a solid car from a dry state, others buy rusty cars and spend time on their backs for reasons known only to them fixing and patching with varying degrees of success. Others don’t care about anything and just cobble shit together driving cars that are structurally dangerous because it looks cool. Which one is right? Hell man each of them is doing their own thing. Sly said it best, it’s your thing do what you wanna do I can’t tell you who to sock it to.... 😀🎼🎸 |
Dugout5 Samba Member
Posted: Fri Sep 14, 2018 1:10 am Post subject: Re: Looking at a 70 beetle Classic |
Wow, you guys have given me a lot to think about. I will bring these points up to the seller and see what comes of it. I’m still looking around for a different car but most I see here are worse than this. It’s shows I’m a rookie cause I thought this one was pretty solid LOL. Maybe I’m not looking in the right places?
Thanks for all the input, I will keep you guys updated on my journey into the VW underworld! |
Posted: Fri Sep 14, 2018 6:33 am Post subject: Re: Looking at a 70 beetle Classic |
Dugout5 wrote: |
You're probably looking in the right places, just takes time to find a good one. I looked at lots of cars before I found my Bug.
Craigslist, Samba classifieds, Facebook, local paper, and those free auto sales magazines in the little colored plastic bins.
Keep looking, your bug is out there _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
sb001 Samba Member
Posted: Wed Sep 19, 2018 5:17 pm Post subject: Re: Looking at a 70 beetle Classic |
Dugout5 wrote: |
Well?? _________________ I'm the humblest guy on this board.
1600 SP engine
73SlowBug Samba Member
Joined: November 28, 2017 Posts: 439 Location: PENNSYLVANIA
Posted: Wed Sep 19, 2018 10:13 pm Post subject: Re: Looking at a 70 beetle Classic |
Q-Dog wrote: |
PA inspection is super tough. Anything you can think of is on the list. Brake wear, rust through the body. Frame rust, alignment, lighting, e brake, defrost, seat belts, anything you can think of. My jeep failed becuase of rust on the fender. They even check to see if the springs protrude through the seats. I had to get seat covers It's not easy to pass. Make sure you get older than a 73, or you'll need to pass emissions too.
Personally, I think that would be a great car were it not for the missing parcel section. The floors aren't too bad. I think they can be fixed pretty easily. The patina on that car looks awesome. I'd ask the seller to go down about 700 unless he can fix that rear parcel section.unless you're a skilled welder, that doesn't look fun. Also, you'll ned to find some metal to fit in there. (Sheet metal might work, if you just want to get it on the road and legal. The floor can be patched _________________ Daily driven....Slowly. |
Posted: Thu Sep 20, 2018 4:40 pm Post subject: Re: Looking at a 70 beetle Classic |
PA emissions is for cars 75 and newer. When my 74 was getting inspected it was not tested for emissions. You can always license it as "antique", which is what my Bugs are licensed as, then no inspection of any kind is needed, but "antiques" can't be daily drivers. |
Posted: Thu Sep 20, 2018 7:15 pm Post subject: Re: Looking at a 70 beetle Classic |
Dwayne1m wrote: |
Couldn't remember if it was 73 or 75. I don't have antique tags because I drive my 73 the majority of the time. My county doesn't do emissions testing at all. It's by county in Pennsylvania. As much as PA tests for, bugs are exempt from a lot of it because we don't have a lot lf the equipment they are looking for. These cars are as basic as they can be. Rust is the real killer in these cars, nut can be fixed with time patience, metal, body filler. and a welder. _________________ Daily driven....Slowly. |
