shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3796 Location: VA/TN
Posted: Tue Aug 18, 2020 6:39 am Post subject: Re: True High Performance Waterboxer Injectors |
bobbyblack wrote: |
Just a tiny tip on what I found; the gold injectors do a tad better with the voltage they're expecting, which is more than the stock Alternator puts out. 240turbo.com has a voltage regulator for us though! I got the variable unit. LOVE it. So inexpensive, and totally easy to install.
(No affiliation, just a fanboy)
-bobby |
Hey Bobby! I have just a stock alternator with these gold injectors. Did you get the external unit?
https://www.240turbo.com/AdjustableVoltage.html#external _________________ Brandon
Instagram @joannthevan |
dart330 Samba Member
Joined: July 19, 2004 Posts: 454 Location: Houston, TX
Posted: Tue Aug 18, 2020 6:51 am Post subject: Re: True High Performance Waterboxer Injectors |
bobbyblack wrote: |
-bobby |
I found the product page on their website, which one did you install?
https://www.240turbo.com/AdjustableVoltage.html#vw |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4349 Location: United States, Iowa
Posted: Tue Aug 18, 2020 7:00 am Post subject: Re: True High Performance Waterboxer Injectors |
The Variable unit, fiddled with it a bit. I put the adjuster part behind the PS signal lens. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Tue Aug 18, 2020 7:05 am Post subject: Re: True High Performance Waterboxer Injectors |
I know Dave Barton has a couple different ones that can fit. I didn't make a specific request for the type, and he sent the usual sized variable model. I got the standard length of wire, but thinking it over, it would be better to have the variable component in the cab somewhere, perhaps a longer cable setup would be something to consider.
All I did was to include a note of what I was putting his Variable unit in, and he sent the right one. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1507 Location: Deep South of the Great White North
Posted: Tue Aug 18, 2020 7:11 am Post subject: Re: True High Performance Waterboxer Injectors |
The correct adjustable regulator for the stock 90 amp Bosch alternator is the 28 mm internal model. There is a tiny screw on the face of the regulator for making adjustments. _________________ 1988 Vanagon
The most important part in every vehicle is the nut behind the wheel...... |
OlRivrRat Samba Member
Posted: Tue Aug 18, 2020 9:21 pm Post subject: Re: True High Performance Waterboxer Injectors |
Bobby
What is the Voltage that You have found that these injectors are
Happiest with ??
ORR ~ DeanB |
Posted: Wed Aug 19, 2020 9:44 am Post subject: Re: True High Performance Waterboxer Injectors |
OlRivrRat wrote: |
Bobby
Happiest with ??
ORR ~ DeanB |
14.9 at the Alterator after about 5 minutes since firing up the engine. I've got a couple other locations to look at voltage while underway, so at the dash with a few accessories running, I see a variety of volts. Oh, Cary a handful of spare fuses, as you're going to be replacing some. Just a little consequence I've run across. In my case, seems like the ones I've replaced are due to age. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
marcotheturbosteamengine Samba Member
Posted: Wed Aug 19, 2020 10:07 am Post subject: Re: True High Performance Waterboxer Injectors |
bobbyblack wrote: |
OlRivrRat wrote: |
Bobby
Happiest with ??
ORR ~ DeanB |
14.9 at the Alterator after about 5 minutes since firing up the engine. I've got a couple other locations to look at voltage while underway, so at the dash with a few accessories running, I see a variety of volts. Oh, Cary a handful of spare fuses, as you're going to be replacing some. Just a little consequence I've run across. In my case, seems like the ones I've replaced are due to age. |
I do NOT recommend running A higher voltage regulator higher than 14.1v, any higher and you risk burning out components that were never designed to run at higher voltages. |
Posted: Wed Aug 19, 2020 10:54 am Post subject: Re: True High Performance Waterboxer Injectors |
Hey Marco
Thanks a bunch for the info & Quick Response ~ |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Wed Aug 19, 2020 11:48 am Post subject: Re: True High Performance Waterboxer Injectors |
Yeah...easy there, captain...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Wed Aug 19, 2020 6:46 pm Post subject: Re: True High Performance Waterboxer Injectors |
Ya, listen to Marco. I'm mostly delusional. Anyway, I haven't measured voltage in the injector circuit. Whatever the PO did to my beast might not be kosher, or anything seen before or since. I still am finding plenty of his Engineering form time to time. All I know is that I LOVE these injectors. Not sure how to explain 20 mpg doing ~70 and running a/c. Certainly can't explain how I'm running the original engine and trans at 307k miles. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
ARMc Samba Member
Joined: February 10, 2012 Posts: 116 Location: Wisconsin
Posted: Thu Aug 20, 2020 6:17 am Post subject: Re: True High Performance Waterboxer Injectors |
While I certainly don't have the expertise Marco does and respect his advice, and ask for it at times, it is interesting to note that when reading the success reports of vanagon owners on Dave's site using his variable voltage regulator they report encouraging results. One guy says 6 years at 14.5v no problem, another set also at 14.5 is quoted as saying: "IDK, van seems to run really great now. Still absolutely amazed that less than 2 volt increase actually makes an audible and tactile difference in engine operation." I guess dial it up cautiously, and at your own risk! I can hardly resist the promise of improved running and a happier battery for only $36. Possibility of damaging sensitive components? I can find spares |
a2wolfsburggli Samba Member
Posted: Thu Aug 20, 2020 6:39 am Post subject: Re: True High Performance Waterboxer Injectors |
I'm also running the variable voltage regulator. I'm running at 14.3 at the battery.
Total respect to Marco and his knowledge. As a second (third, forth etc,) opinion though most information here on TheSamba and other internet reference points say that 14.1-14.5 is the sweet spot for the voltage to run on the Vanagon.
I will very highly indorse the variable regulator as something that seems to just wake up the van a bit. It's not faster, more powerful or anything else. It just straight runs better. (much like Marco's injectors, which I also have.)
https://www.thesamba.com/vw/forum/viewtopic.php?t=687372
https://www.thesamba.com/vw/forum/viewtopic.php?t=363115
https://www.240turbo.com/AdjustableVoltage.html#vw _________________ Current: '87 Westfalia | '16 Audi Q5 3.0T S-Line w/sport package.
Past: '09 CC 3.6L 4motion "R36 wannabe" | '02 Audi TT "ALMS Edition" | '84 Jetta GLI with Autotech Supercharger | '89 Helios Jetta GLI 16v's (x2) | '95.5 URS6 | and the list goes on.
Never underestimate the entertainment value of OCD overruling Common Sense |
SCM Samba Member
Joined: January 26, 2011 Posts: 3115 Location: Bozeman MT
Posted: Fri Oct 23, 2020 8:03 pm Post subject: Re: True High Performance Waterboxer Injectors |
Are these still available? The classified ads I’m finding say they’ve been deleted, and wifey just asked me to start working on my Xmas list😏 _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
RoryGirl Samba Member
Joined: October 14, 2016 Posts: 784 Location: WestWorld Nanaimo BC
do.dah Samba Member
Joined: August 27, 2015 Posts: 444 Location: Washington
Posted: Fri Nov 20, 2020 8:09 pm Post subject: Re: True High Performance Waterboxer Injectors |
Not to go too far off track here, but, regarding variable vr on Dave Barton' site,, I'm the one who said "audible and tactile difference".
The adjustment on these vr's are very touchy, ever so slight of increase makes a WORLD of difference. Been running about 14.3 for years without a problem. But, my vr is mounted up by the battery, as per Tencentlife, so engine heat isn't affecting vr output. Much more stable that way. And WAY more fun to initially install.. |
coastdog Samba Member
Posted: Tue Nov 24, 2020 1:07 am Post subject: Re: True High Performance Waterboxer Injectors |
Anyone know if these injectors have been installed on any 2.7GW and their EFI? |
JEL91Westy Samba Member
Joined: December 04, 2020 Posts: 211 Location: Central PA
Posted: Fri Dec 11, 2020 10:43 pm Post subject: Re: True High Performance Waterboxer Injectors |
Marco,
Are you still selling these injectors?
Thanks
Joe |
Zeitgeist 13 Samba Member
Posted: Fri Dec 11, 2020 11:17 pm Post subject: Re: True High Performance Waterboxer Injectors |
https://mansispeed.com/products/ _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Sat Dec 12, 2020 7:59 am Post subject: Re: True High Performance Waterboxer Injectors |
Thanks Casey.
I bought new injectors years ago based on a recommendation here somewhere, but convinced myself the price was too good for them to be any good, so I never installed them. Fast forward 5yrs and I am again thinking I should replace what I believe are the original fuel lines (have had the replacement kit for 5yrs). My longtime VW mechanic tells me the hoses look fine, but I keep reading the horror stories so may do it anyway. Now again questioning putting in the cheap aftermarket injectors, or getting these.
Also curious what people are using for the hose clamps? Like everything else there seem to be no shortage of opinions on what is best, so I am hoping for a recommendation from someone who has direct experience with them.
Thanks
Joe _________________ 91 Westy
85 911 |
