0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3416 Location: OR & CA (Oregon/California)
Posted: Mon Sep 17, 2018 4:44 pm Post subject: Re: True High Performance Waterboxer Injectors |
hi Marco...
is my order is in? |
9.5isCanadian Samba Member
Joined: September 16, 2017 Posts: 465 Location: In your blind spot.
Posted: Mon Sep 17, 2018 4:45 pm Post subject: Re: True High Performance Waterboxer Injectors |
marcotheturbosteamengine wrote: |
Someone just pulled out of there order, so i have one set still left if anyone is intrested.
Thank you
Marco |
Dibs!
Pm incoming
Edit: PM sent _________________ 9 1/2 - missing a few pieces.
1987 Getaway Hightop
1980 Sunroof Vanagon
2018 BMW R Nine T
2012 Golf tdi |
mtnride1 Samba Member
Joined: March 30, 2011 Posts: 194 Location: la quinta, CA
Posted: Tue Sep 18, 2018 3:33 pm Post subject: Re: True High Performance Waterboxer Injectors |
Well nuts, I guess I will have to wait 25 days. I put in new GW Injectors early April and one already failed now I have doubts about the other 3. So I will now wait for yours. _________________ 87 westy 2wd (NED) |
Syncronoid Samba Member
Joined: January 21, 2012 Posts: 1111 Location: Stanford, CA and Bend, OR
Posted: Tue Sep 18, 2018 7:35 pm Post subject: Re: True High Performance Waterboxer Injectors |
I had one of my brand new GW's fail within 700 miles. GW confirmed bad wiring (after Mr Injector said the same). They replaced the bad one, but the GW set is now 2nd backup to a set that was refurbished and proven to work over the years. Marco's new injectors are working great so far, about 2000 miles.
mtnride1 wrote: |
Well nuts, I guess I will have to wait 25 days. I put in new GW Injectors early April and one already failed now I have doubts about the other 3. So I will now wait for yours. |
_________________ '90 Syncro Westy w/GW2.5L |
marcotheturbosteamengine Samba Member
Posted: Wed Sep 19, 2018 2:30 pm Post subject: Re: True High Performance Waterboxer Injectors |
The New Gold Standard!
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4772 Location: Bemidji, MN
Posted: Wed Sep 19, 2018 4:25 pm Post subject: Re: True High Performance Waterboxer Injectors |
so i'm seeing 2 rubbers on the nozzle end, stacked on each other. is that needed on these due to body length differeneces? i've got a set coming, shall i use 2 on the nozzle end? _________________ -dan
www.thefixitworkshop.com |
Posted: Wed Sep 19, 2018 4:56 pm Post subject: Re: True High Performance Waterboxer Injectors |
DanHoug wrote: |
so i'm seeing 2 rubbers on the nozzle end, stacked on each other. is that needed on these due to body length differeneces? i've got a set coming, shall i use 2 on the nozzle end? |
As they are a different injector body the rubbers are there to make up the difference, you dont have to do anything they come pre-assembled ready for you to bolt in.
Posted: Wed Sep 19, 2018 5:09 pm Post subject: Re: True High Performance Waterboxer Injectors |
cool beans. i wish mine would arrive tomorrow as i have a 500 mile trip planned starting Friday! so excited to try these! _________________ -dan
Posted: Thu Sep 20, 2018 1:34 pm Post subject: Re: True High Performance Waterboxer Injectors |
mtnride1 wrote: |
PM sent👍🏼 |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16501 Location: Brookeville, MD
Posted: Thu Sep 20, 2018 2:44 pm Post subject: Re: True High Performance Waterboxer Injectors |
dobryan wrote: |
When will you have more? |
In 2 weeks, first come first serve, half of the second batch has already sold. |
bjrogers86auto Samba Member
Joined: March 26, 2009 Posts: 1375 Location: Halifax, N.S.
Posted: Fri Sep 21, 2018 4:09 am Post subject: Re: True High Performance Waterboxer Injectors |
According to my supplier I have the first set of Marco injectors on the Canadian East Coast!
Finally got out for a good highway drive yesterday and found the van ran great on the highway with(maybe I'm crazy) a difference around 3k rpm in throttle response. I admit, I baby this van and don't often push it at all.
Looking forward to adding the rocker arms to my winter engine rebuild along with an upgraded oil pump and these injectors. Next summer will literally fly by!
Thanks again Marco
Brian _________________ 86 Vanagon GL Westfalia 2.1
18 Nissan Frontier Pro 4X
19 Honda Civic Hatchback
A little rudeness and disrespect can elevate a meaningless interaction to a battle of wills and add drama to an otherwise dull day. Calvin and Hobbes. |
jlrftype7 Samba Member
Posted: Fri Sep 28, 2018 5:47 pm Post subject: Re: True High Performance Waterboxer Injectors |
Almost Aswan Brown/Assuan Brown.... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Snort Samba Member
Joined: April 02, 2005 Posts: 1957 Location: Seattle, WA
Posted: Mon Oct 01, 2018 5:32 pm Post subject: Re: True High Performance Waterboxer Injectors |
Testimonial on a 2.1L stock Carat.
I now have smoother idle both cold and hot, hardly misses a beat.
I have better throttle response from a standstill, when shifting gears and at speed.
I am using taller gears around town on Seattle hills, third when I previously used second and fourth when I used third.
I can't see how there is any performance downside with these injectors. |
jxgyvr Samba Member
Joined: October 21, 2012 Posts: 11 Location: Vancouver, BC
Posted: Tue Oct 02, 2018 6:51 am Post subject: Re: True High Performance Waterboxer Injectors |
High Performance WBX Injectors Testimonial: Stock 2.1L 87 Syncro Hightop.
I notice quicker starts, smoother idle, both cold and hot.
Improved throttle response from a standstill and at speed.
Pulls noticeably better in the 3k-4k RPM range.
Very satisfied with this purchase. _________________ 87 Syncro hightop.
Posted: Tue Oct 02, 2018 3:52 pm Post subject: Re: True High Performance Waterboxer Injectors |
Snort wrote: |
Thanks for your honest report, the is a noticeable boost in mid-range torque that alows you to drive in a higher gear, as you noticed the improvements and an overall nicer running engine.
Thanks again
Last edited by marcotheturbosteamengine on Tue Oct 02, 2018 4:00 pm; edited 1 time in total |
Posted: Tue Oct 02, 2018 3:59 pm Post subject: Re: True High Performance Waterboxer Injectors |
jxgyvr wrote: |
Very satisfied with this purchase. |
Thanks, Im very happy you can feel the Improvements, these are the real deal, Its taken along time to get my injectors to this point.
Thanks again. |
Posted: Tue Oct 02, 2018 4:02 pm Post subject: Re: True High Performance Waterboxer Injectors |
You can bet there will be more versions on the market soon, and I think we know from whom. _________________ '90 Syncro Westy w/GW2.5L |
Posted: Tue Oct 02, 2018 5:43 pm Post subject: Re: True High Performance Waterboxer Injectors |
Syncronoid wrote: |
You can bet there will be more versions on the market soon, and I think we know from whom. |
Thats ok, competition is a great thing. my injectors are an accumulation of years and years of testing, it doesn’t happen over night.
You have got to be some sort of crazy man(me) to do these things out of passion not profit🤪 |
D Clymer Samba Member
Joined: December 22, 2005 Posts: 2978 Location: Issaquah, WA
Posted: Tue Oct 02, 2018 5:45 pm Post subject: Re: True High Performance Waterboxer Injectors |
Syncronoid wrote: |
I was thinking the same thing. Hopefully people will remember who developed/originated these and continue to buy from him. Threads like these at least help to document the creater of a ground breaking product. |
