MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4065 Location: East Kootenay, British Columbia
Posted: Wed Jun 22, 2022 1:51 pm Post subject: Re: Syncro locker panel wiring question. |
Just FYI here's a pic of the stock front locker setup. The silver doohickey in the middle with the white line is the vacuum/electric switch that activates the blinking warning light for the front locker.
Not needed for front locker addition, just nice to have if you can find one for authenticity.
And this is the blinker circuit board that plugs into that extra terminal on the locker panel wire harness.
_________________ Currently:
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6315 Location: Honolulu,Hawaii and France
Posted: Wed Jun 22, 2022 11:09 pm Post subject: Re: Syncro locker panel wiring question. |
ALIKA T3 wrote: |
Ooh, berry nice! I have never seen that circuit in real life. Do you have a picture without the foam protection? Do they mount the board to something? |
No sorry, that's the only picture I took of it, no longer have that van. Microbusdelux has it now.
I found the thing just hanging from the wire harness, no mounting! _________________ Currently:
Posted: Thu Jun 23, 2022 10:33 am Post subject: Re: Syncro locker panel wiring question. |
MsTaboo wrote: |
ALIKA T3 wrote: |
I found the thing just hanging from the wire harness, no mounting! |
Thank you
Dangling was probably how it was from factory since they put the foam on it anyway. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
pemz0r Samba Member
Joined: August 26, 2010 Posts: 126 Location: Huntington Beach
Posted: Fri Jun 24, 2022 12:28 pm Post subject: Re: Syncro locker panel wiring question. |
Thanks for the video!
I never bothered installing the blinking stuff on mine, a retrofit front locker.
I think this was just a device to not get sued by the consumer in case shit went wrong.
I mean, do you even see it blinking if it were to be pulled on it accidentally while driving? My eyes are on the road hundreds of yards ahead, I don't see these lights... _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
janv Samba Member
Posted: Wed Oct 19, 2022 2:37 pm Post subject: Re: Syncro locker panel wiring question. |
Hello. I’m installing the syncro locker panel and I can’t quite locate where to plug in the black/blue wire that Alika refers to as #15 behind the emergency flasher warning switch.
Can someone please explain me where does it go exactly? A picture for reference would be great. Thank you! |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6798 Location: Fort Lauderdale, Fl.
Posted: Wed Oct 19, 2022 9:58 pm Post subject: Re: Syncro locker panel wiring question. |
Missed this post so I'll just add these pics if they are any use to anyone
Edit: deleted as it is completely wrong diagram _________________ This free advice is worth exactly what you paid for it.
Posted: Thu Oct 20, 2022 11:39 am Post subject: Re: Syncro locker panel wiring question. |
Steve M. wrote: |
"The metal thing is the vacuum pump (Unterdruckpumpe) for the front locker, in Picture its No. 12 (but with the wrong discription; you have to change the names 11 <--> 12 on the second picture)."
Just FYI - This diagram is for the cruise control system. Has nothing to do with Syncro front locker setup.
#12 is the vacuum plunge device to the throttle, #11 is the electric vacuum pump for the cruise system. Again, not connected to locker system. _________________ Currently:
Posted: Thu Oct 20, 2022 2:39 pm Post subject: Re: Syncro locker panel wiring question. |
janv wrote: |
Page 97.178 of the Bentley. Plugs into the emergency flasher switch. Sorry, no picture and not much info. _________________ Currently:
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9895 Location: Orbiting San Diego
Posted: Thu Oct 20, 2022 3:52 pm Post subject: Re: Syncro locker panel wiring question. |
If you have the Syncro locker harness this is really pretty simple.
The locker harness should have a single black/blue wire with both a male spade and a female spade near the end.
This single black/blue wire is for power for the locker harness.
On the back of the hazard/flashers switch is another black/blue wire with a female spade plugged in to provide fused power to that switch.
Unplug that female spade from the switch and plug it into the male spade of the Syncro locker harness.
Lastly, plug the female spade of the locker harness onto the male spade of the hazard/flashers switch.
Mark
MsTaboo wrote: |
janv wrote: |
Page 97.178 of the Bentley. Plugs into the emergency flasher switch. Sorry, no picture and not much info. |
Posted: Thu Oct 20, 2022 7:47 pm Post subject: Re: Syncro locker panel wiring question. |
[quote="MsTaboo"]
Steve M. wrote: |
#12 is the vacuum plunge device to the throttle, #11 is the electric vacuum pump for the cruise system. Again, not connected to locker system. |
That is very good to know! It was given to me by someone from Germany a while back in reference to the lockers...I really never looked too closely at it. _________________ This free advice is worth exactly what you paid for it.
Posted: Fri Oct 21, 2022 5:37 pm Post subject: Re: Syncro locker panel wiring question. |
I got here too late, but look at the back of the emergency flasher, there are numbers. #15 is where the blue/black wire goes like explained above, it's connected in parallel, it's very plug and play. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
janv Samba Member
Posted: Thu Jan 26, 2023 10:08 am Post subject: Re: Syncro locker panel wiring question. |
Thanks guys. I think I got it figured out. One thing that is still not working for me is the individual lights don’t come on when I pull the knobs. The whole panel lights up when I turn the light switch on but not the lockers and decoupler lights when engaged. Since the main illumination light comes on that means I have power going to the panel right? Not sure what exactly should I look for when it comes to the locking light indicators. Any suggestions are appreciated!
Posted: Thu Jan 26, 2023 12:27 pm Post subject: Re: Syncro locker panel wiring question. |
Jump the connector with a paper clip at the locker switch. It should light. If not, use a voltmeter to see if you get continuity to ground from the switch connector. The switch puts the circuit to ground (if i recall correctly) _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
janv Samba Member
Posted: Sat Jan 28, 2023 2:59 pm Post subject: Re: Syncro locker panel wiring question. |
I’m troubleshooting my locker panel lights and it seems like for me it came down to my circuit board. My panel illumination light works just fine. I took the light power wire and ground and touched the metal connectors and it lights up. But when I connect the power wire to where the ignition power is supposed to be and ground the individual locker and decoupler circuits none of the lights come on. All the light bulbs are brand new and work in the panel illumination spot. Is it possible that my circuit board is bad? Am I missing something? Thank you for any suggestions.
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 11998 Location: Santa Cruz, CA
Posted: Sat Jan 28, 2023 3:04 pm Post subject: Re: Syncro locker panel wiring question. |
A multimeter would be an obvious tool to track down these issues. You can verify both power and ground that way without relying on a bulb. A unit that measures DC voltage and audible continuity can be had even on a cheap unit if you don't already have one.
LEDs are also sided, the will only illuminate if installed in the correct orientation. Any decent retailer should have that in their description. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9517 Location: Western WA
Posted: Sat Jan 28, 2023 5:09 pm Post subject: Re: Syncro locker panel wiring question. |
As ^said^, LEDs (often) have a plus and a minus orientation.
If they don't illuminate, remove, rotate 180° and re-insert the other way.
Where did you get those LEDs? _________________
....KTMs, GasGas, SPOT mtb |
Posted: Sat Jan 28, 2023 5:13 pm Post subject: Re: Syncro locker panel wiring question. |
In this case a simple test would be to put the ground wire on the +15 pin on the board and then touch the 12v power wire on each of the locker contacts 1 at a time.
That will reverse the polarity of each light and show if it simply needs to be turned 180 degrees.
Mark |
