Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3574 Location: Sarasota, in my adopted state of Florida
Posted: Fri Sep 14, 2018 2:56 pm Post subject: A coupe wind wing glass or pattern |
Need wind wing glass for my 57 A coupe. If you have them on your car a paper pattern of them would help me greatly.
Thanks in advance. Dan |
MoPor Samba Member
Joined: December 03, 2010 Posts: 292 Location: Canada
Posted: Fri Sep 14, 2018 4:13 pm Post subject: Re: A coupe wind wing glass or pattern |
Thanks for looking, that is quarter window glass. I need wind wing glass and the A glass is different than the B an C cars. I already called stoddard about it. Dan |
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1958 Location: FL Panhandle
Posted: Fri Sep 14, 2018 5:58 pm Post subject: Re: A coupe wind wing glass or pattern |
There's a Speedster replica owner that makes replicas and supplies them to SierraMadre. Is that what you are looking for? They are Lexan though.
http://www.sierramadrecollection.com/Wing-Window-Set-Speedster-p28343.html _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
Brad Ripley Samba Member
Posted: Fri Sep 14, 2018 11:30 pm Post subject: Re: A coupe wind wing glass or pattern |
Is this the vent wing you are referring to? |
Posted: Sat Sep 15, 2018 8:59 am Post subject: Re: A coupe wind wing glass or pattern |
Brad Ripley wrote: |
Yes, knew someone would get it. Just need the patern and will have local glass shop make me one.
Dan |
Posted: Sat Sep 15, 2018 10:23 am Post subject: Re: A coupe wind wing glass or pattern |
My car, you can see the lower part of the wing bracket. Getting it ready to sell. Been mine for 38 years. Dan
Starbucket Samba Member
Posted: Sat Sep 15, 2018 2:33 pm Post subject: Re: A coupe wind wing glass or pattern |
If it's flat glass and you have the other side the glass shop can use it for a pattern. |
Posted: Sat Sep 15, 2018 7:00 pm Post subject: Re: A coupe wind wing glass or pattern |
Don’t have the glass and never did. When I bought the car they were missing.
Dan |
Posted: Sat Sep 15, 2018 7:42 pm Post subject: Re: A coupe wind wing glass or pattern |
If you have the frame just hold some stiff cardboard next to it and draw a pattern and cut it out and fit it until you get it right and have them make the glass from it or just take the car to them and say make them, it's easy and they do stuff like that when some one comes in with a busted out wind wing. Try a different shop if they don't know what you want. |
Posted: Fri Sep 21, 2018 2:51 pm Post subject: Re: A coupe wind wing glass or pattern |
Starbucket wrote: |
The frame does not fit 360 around the glass making it tough to get an exact trace. Anybody else have this setup on their A model?
356 registry wants $$$ to sign up. |
Posted: Sat Sep 22, 2018 7:31 am Post subject: Re: A coupe wind wing glass or pattern |
Let me be a bit more clear. (1) Hold the cardboard next to frame. (2) Trace the frame inner edge. (3) Cut out along line leaving extra material where there is no frame. (4) Fit the cardboard into the frame and close wind wing. (5) with door glass up, you can now see where the cardboard needs to be cut. Now the glass shop will have a pattern. Or you can wait for someone to respond with a pattern. You can also sell the car as is, as some missing glass won't deter someone who wants that clean 356 as it didn't deter you from buying it. |
copellos Samba Member
Joined: February 18, 2004 Posts: 937 Location: sonora ca
Posted: Tue Sep 25, 2018 3:56 pm Post subject: Re: A coupe wind wing glass or pattern |
I need to make these ..to add to my other wings |
vwbrewer Samba Member
Joined: March 23, 2009 Posts: 200 Location: San Antonio
Posted: Sun Nov 04, 2018 7:48 am Post subject: Re: A coupe wind wing glass or pattern |
Starbucket wrote: |
The Porsche has 1 piece windows, Its not like the Bug in the picture. The vent windows he's referring aren't factory and mount on the outside. _________________ 1957 Oval Rag |
MoPor Samba Member
donco735 Samba Member
Joined: December 13, 2018 Posts: 38 Location: New Mexico
Posted: Thu Dec 13, 2018 2:02 pm Post subject: Re: A coupe wind wing glass or pattern |
Dan Ruddock wrote: |
My car, you can see the lower part of the wing bracket. Getting it ready to sell. Been mine for 38 years. Dan |
My 58 coupe has them. Send me a PM with your address and I will mail you a template.
Ps: Nice 57 coupe |
Posted: Sun Dec 16, 2018 10:27 am Post subject: Re: A coupe wind wing glass or pattern |
Thanks, you are a back-up as I have another member sending a pattern. Are yours made from plexi or real glass. I have conflicting info on what is correct.
Dan |
Posted: Sun Dec 16, 2018 10:49 am Post subject: Re: A coupe wind wing glass or pattern |
Or mine
Posted: Sun Dec 16, 2018 10:57 am Post subject: Re: A coupe wind wing glass or pattern |
Not like mine. Mine are the same as donco's |
Posted: Sun Dec 16, 2018 1:41 pm Post subject: Re: A coupe wind wing glass or pattern |
Dan |
Mine are glass. The glass is the same thickness as early VW beetle vent windows. They have the "Duro - Sekurit" etching in the lower corner. As far as I know, they were only offered as a Porsche factory installed option (as opposed to dealer installed), although I have seen a few scarce NOS-NLA new ones in the wrapper on the web in past years.
