Front end suspension build questions.
BJT
BJT is offline
PostPosted: Fri Sep 14, 2018 6:59 pm    Post subject: Front end suspension build questions. Reply with quote
So Iím in the midst of putting in a proper Thing beam in my 74, so of course Iíve got tons of questions.
So hereís one, I purchased torsion arms/ ball joints from the Thing shop. Put the arms on the new beam and springs today. I found it odd that there are no end caps on the ends of the torsion arms, leaving he grease and springs exposed to whatever is blown up there from the road. Am I missing some end caps or something?
KAmes
KAmes is offline
PostPosted: Sat Sep 15, 2018 3:26 pm    Post subject: Re: Front end suspension build questions. Reply with quote
I bought the thing shop torsion arms also, I used the caps from my old ones. They poke out easy from the back side, long bar and tap with a hammer, then tap them into the new ones. I've heard of people gluing electrical box blanks in or coins. Found for sale here, maybe others sell them too.
http://www.thingparts.com/torsion-arm-plug/
KAmes
KAmes is offline
PostPosted: Sat Sep 15, 2018 4:07 pm    Post subject: Re: Front end suspension build questions. Reply with quote
Check out this thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=675844&highlight=torsion+arm+cap
BJT
BJT is offline
PostPosted: Sat Sep 15, 2018 5:31 pm    Post subject: Re: Front end suspension build questions. Reply with quote
Thanks guys, figured there had to be some sort of cap. Strange when you buy these things they donít come with the caps. Canít get the old ones off the old torsion arms, old beetle beam that is all tar and rust, so guess Iíll rig something up.
Elroyyy
Elroyyy is offline
PostPosted: Mon Sep 17, 2018 9:29 am    Post subject: Re: Front end suspension build questions. Reply with quote
There are some elegant solutions here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=257920
I did what Mondshine did.
You can also order them:
My Classified Ads
74 Thing
74 Thing is offline
PostPosted: Mon Sep 17, 2018 10:52 am    Post subject: Re: Front end suspension build questions. Reply with quote
A US 50 cent piece taps right in.
BJT
BJT is offline
PostPosted: Mon Oct 01, 2018 10:18 am    Post subject: Re: Front end suspension build questions. Reply with quote
Got the beam in and all the new parts. Needs an alignment badly, which is happening tomorrow. Took it around the block and nothing fell off, so thatís a plus. But I am hearing a on/off squeak from one of the front wheels, prob a bearing... hopefully it goes away after some driving, donít really want to replace the bearings again.
Drives so much different too, very ďhoppyĒ over bumps, prob due to being out of alignment and the new shocks...
The Thing looks so much better with a Thing front end and not a beetle one. However the front end sits higher than the rear now, is that the way itís supposed to sit or do I need to adjust or index the rear? And by me, I mean pay someone to do it.
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Mon Oct 01, 2018 10:57 am    Post subject: Re: Front end suspension build questions. Reply with quote
The Thing spindles will raise a vehicle 3.5" from a Beetle spindle so someone lowered the rear of your Thing to match the incorrect front. So yes, you will need to re-index the rear torsion bars.
BJT
BJT is offline
PostPosted: Tue Oct 02, 2018 10:46 am    Post subject: Re: Front end suspension build questions. Reply with quote
Just got the Thing aligned. Feels great... in a straight line. However and thereís always a however, when I turn right, there is a loud ďthunk, thunk, thunkĒ. No idea what it is. Only happens when turning right. The mechanic also showed me there is way too much play in the steering wheel, gotta figure that out. And the steering column is rubbing on the gas tank... no good. Iím thinking I didnít rotate the steering box enough, gonna try to adjust that..
BJT
BJT is offline
PostPosted: Tue Oct 02, 2018 6:29 pm    Post subject: Re: Front end suspension build questions. Reply with quote
Well, found one problem. The passenger side spindle is rubbing on the inside of the wheel! Anyone ever have this problem after getting an alignment?!?!
BJT
BJT is offline
PostPosted: Wed Oct 03, 2018 1:31 pm    Post subject: Re: Front end suspension build questions. Reply with quote
Thanks to Mike from thingparts.com, figured out the PO had a bug or bus wheel on the front which caused the rubbing. So similar but just slight variation in the design of the wheel... moved it to the back and a back to the front and perfect! Now to work on the steering shaft rubbing on the gas tank. Rolling Eyes
