narrowfarm Samba Member
Posted: Sat Sep 15, 2018 10:41 am Post subject: heat riser tube single port |
Hello my VW car does not get driven that much. I have some water droplets on my intake manifold up by the under the carb. It has a solex 30-1 pic, 1300cc engine single port. I did clean out the heat riser tube awhile ago but how long does the engine normally take to warm up so the water droplets are not there??? My heat riser tube seems to be cold. I have been working on the car so it does not really get driven yet. My exhaust is not stock as it has a GT style exhaust on it with heat riser ports.
I usually run the engine in my garage for only about 5 minutes or so while I have been working on it. Thanks !! |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9770 Location: Oregon
Posted: Sat Sep 15, 2018 11:19 am Post subject: Re: heat riser tube single port |
The heat riser needs to get hot for the engine to function properly.
Starting and running the engine for 5 minutes at a time is not going to get it up to proper temp to boil out condensed moisture from the crankcase. Or warm up the heat risers enough to prevent the intake manifold from condensating.
Are the heat riser ports on the exhaust drilled? The drilled passages. Allow hot exhaust gasses to pass from one side of the heat riser to the other. Heating the intake manifold.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Sat Sep 15, 2018 12:47 pm Post subject: Re: heat riser tube single port |
That GT style exhaust will never flow right to warm up the intake as it should. It's just not made right. All off the aftermarket ones are made incorrectly to get exhaust flow through the riser.
Either it needs to be modified to work correctly, you put a stock exhaust back on, or you live with it. Thoes are about your only options. |
Posted: Sun Sep 16, 2018 2:47 am Post subject: Re: heat riser tube single port |
Thanks for the info! The heat riser tubes were drilled and sealed back up. I was able to run a cable through it ! The non stock exhaust system makes sense too. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Sun Sep 16, 2018 4:42 pm Post subject: Re: heat riser tube single port |
narrowfarm wrote: |
Dont understand what the heat riser tubes were drilled and sealed back up means. _________________ D-Dubya Manx clone - 63 Short pan,1914.
glutamodo The Android
Joined: July 13, 2004 Posts: 26323 Location: Douglas, WY
Posted: Sun Sep 16, 2018 5:41 pm Post subject: Re: heat riser tube single port |
My guess is they drilled through the corners where the center horizontal tube angle down to the muffler, and they then reamed across, afterwards closing up the holes.
While I totally agree that heat riser setups on non-stock exhausts are not designed at all for any kind of directional flow, sometimes they do actually work kinda-sorta OK.
Long ago, I did a bit of a (winter-time!) temperature survey on my stock-exhaust 40HP, then followed by one on my definitely non-stock dual port Baja, which has a header and a quiet pack muffler. I was actually rather surprised as to how well the heat riser setup worked despite the header (now, this was with a very clean and clear heat riser!)
Link to that thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=27 _________________ Andy T.
Posted: Mon Sep 17, 2018 6:37 am Post subject: Re: heat riser tube single port |
Duuhhhh - yeah that's probably what they mean....And yeah I have had similar results where there seemed to be a bit of heat with a header. I am sure its not as good as a correct design, but it has worked for me. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
Posted: Mon Sep 17, 2018 7:23 am Post subject: Re: heat riser tube single port |
Mine, 1971 DP engine. Look at heat riser on right side of engine, hole has been plugged and brazed shut.
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
bluebus86 Banned
Posted: Mon Sep 17, 2018 8:28 am Post subject: Re: heat riser tube single port |
Ok Cusser, would you please shift the camera just a little towards the right, some of the image is cut off on that side! Nice rear..... engine.
Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Cusser Samba Member
Posted: Mon Sep 17, 2018 11:01 am Post subject: Re: heat riser tube single port |
bluebus86 wrote: |
Bug On! |
Well, that engine is now installed in my 1970; I hope you're partially teasing me, as I'd have to walk outside 50 feet to take a new photo !!! Will these photos suffice? The access holes have been plugged with very short sheet metal screws and brazed shut.
Posted: Mon Sep 17, 2018 12:33 pm Post subject: Re: heat riser tube single port |
Cleaning heat risers - this has worked for me 75% of the time.
Have a couple pieces of old clutch cable or some other similar stranded wire cable. First one is maybe 8 or so inches long. Next one is maybe 16 and the last one close to 24".
Get a pair of HEAVY leather gloves.
Chuck the shortest cable into your drill and you will probably have the drill on reverse because you do NOT want the cable to unravel.
Run the cable into one side and then the other untill it bottoms out. You can then run the cable through in the reverse direction to unravel a bit and it will open up the tube more. shake out debris from tube.
Use the 16" cable and repeat. Then do the 24" cable.
Don't get crazy with the drill speed or pressure and work it in and out as you go. The last thing you want to do is snap the cable inside. If you do, the intake is junk.
There are other methods on here using an oxy acetylene torch and a few other ways, but this usually works for me. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Cusser Samba Member
Posted: Mon Sep 17, 2018 1:28 pm Post subject: Re: heat riser tube single port |
andk5591 wrote: |
There are other methods on here using an oxy acetylene torch and a few other ways, but this usually works for me. |
Steel cable procedure did not work for me.
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Mon Sep 17, 2018 3:23 pm Post subject: Re: heat riser tube single port |
bluebus86 wrote: |
Bug On! |
Whoosh... _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
Posted: Mon Sep 17, 2018 4:04 pm Post subject: Re: heat riser tube single port |
Cusser, I said it worked 75% of the time. Just think, maybe next time it will for you...or maybe after 2 more times it will Honestly, I cross my fingers every time I start on one. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Mon Sep 17, 2018 4:51 pm Post subject: Re: heat riser tube single port |
Hello again. exactly what i did started with short cable with drill in reverse and worked my way up to longer cables. the riser pipe is now open. i did this about a year ago. i just took off the intake manifold today and heat riser tube is still unblocked!!! blows air and water through the heat riser tube easy ! ihave the heat riser tube filled with coke cola and cleaning agent Alconox while i wait for new gasket kit to come in mail. i also ordered the other day 12 volt motorcycle hand warmers kit that i may try to wrap around the intake manifold to help warm the manifold along with aluminum foil and insulation on that long intake manifold. just trying to atomize the gas the best possible in this old engine. GT exhaust may be hurting me . |
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2388 Location: Seekonk,Massachusetts USA
mukluk Samba Member
Posted: Mon Sep 17, 2018 7:14 pm Post subject: Re: heat riser tube single port |
APPLEGREENVW wrote: |
Empi needs to bring back the header with the heat riser set up, built in again.
But that would mean they would be producing a quality part, something which the modern day Empi is incapable of doing. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Mon Sep 17, 2018 10:58 pm Post subject: Re: heat riser tube single port |
wowsers, someone actually used the two words "EMPI" and "quality" in the same sentence! I didn't think that was possible. _________________ Andy T.
bluebus86 Banned
