mandodave Samba Member
Joined: July 29, 2008 Posts: 107 Location: St. Paul MN
Posted: Sat Sep 15, 2018 4:16 pm Post subject: Big oil leak at start - then fine. |
This has only happened maybe 5 times over the past couple months. After starting the bus cold a bunch of oil will barf out and drip off the end of the oil filter.
This is on a 2L -- My question is-- it possible the the Oil Pressure Relief Valve is stuck and creates too much pressure and forces the oil out -- After the that the oil warms up a little and flows fine. Again this has only happened intermittently and only when cold -- otherwise it does not leak nor have excess oil usage.
I have not yet determined where the leak is coming from - when the "barfing" occurs i have not been able to find a source
Thanks
David |
SGKent Samba Member
Posted: Sat Sep 15, 2018 4:40 pm Post subject: Re: Big oil leak at start - then fine. |
yes or you have too thick an oil. Is your oil pump stock? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Sep 15, 2018 4:50 pm Post subject: Re: Big oil leak at start - then fine. |
Yes, stock Oil Pump.
I picked up a new piston and spring. Are there any obvious ways to see that it was sticking? Other than replacing it and not having the problem anymore? |
busdaddy Samba Member
Posted: Sat Sep 15, 2018 4:54 pm Post subject: Re: Big oil leak at start - then fine. |
Sometimes the wear pattern on the sides of the plunger can tell a story, or if it's hard to remove that's a fairly definitive sign.
What weight oil are you using? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Sep 15, 2018 4:59 pm Post subject: Re: Big oil leak at start - then fine. |
Thanks.
20 .50 right now. prior was Mobil 1 5- 30 - Had the leak with both |
SGKent Samba Member
Posted: Sat Sep 15, 2018 5:13 pm Post subject: Re: Big oil leak at start - then fine. |
just be aware that some plungers are slotted and some are not. You need the kind for that engine, and where it goes in the engine.
The filter type should have a bypass in it if the pressure across the filter is too high which it can be when the oil is cold. There is also a bypass in the filter mount but it is too small if the filter lacks a high pressure bypass. Essentially when oil is too thick to get past the filter element - rather than rupture it or swell the can, the bypass in the oil filter opens. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Sep 15, 2018 5:22 pm Post subject: Re: Big oil leak at start - then fine. |
Thank you all for your responses. I will report back when 8 replace it. |
Posted: Sat Sep 15, 2018 5:37 pm Post subject: Re: Big oil leak at start - then fine. |
Another thing to look at is the sealing surface where the filter mounts, sometimes the old gasket (flat o ring) comes out of the filter and sticks to the base, that's one place where two stacked on top of each other isn't good. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Sat Sep 15, 2018 7:24 pm Post subject: Re: Big oil leak at start - then fine. |
mandodave wrote: |
If it were consistent, this is classic symptom of a blown gallery plug above the filter mount. Most usually, this leak occurs after someone botched a tapped gallery plug installation. It is a devil of a location and often has inadequate room for threads. It only leaks when the pressure relief plunger is in a particular position.
See: http://www.itinerant-air-cooled.com/viewtopic.php?t=12450#p212934 _________________ www.itinerant-air-cooled.com |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Sat Sep 15, 2018 8:44 pm Post subject: Re: Big oil leak at start - then fine. |
I wouldn’t just buy a plunger and spring to install without measuring to make sure that the plunger and bore have the right “fit” _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Wed Sep 19, 2018 2:45 pm Post subject: Re: Big oil leak at start - then fine. |
I would suspect a failed oil pressure switch, it could blow apart at any moment. |
Posted: Thu May 23, 2019 9:32 pm Post subject: Re: Big oil leak at start - then fine. |
It ended up being the oil cooler seals. Thank you all |
74 Thing Samba Member
Posted: Thu May 23, 2019 10:45 pm Post subject: Re: Big oil leak at start - then fine. |
Do you have photos of the seals? Were they torn or just hard and leaking? |
Posted: Fri May 24, 2019 7:09 am Post subject: Re: Big oil leak at start - then fine. |
It was not cracked at all. Pretty stiff - Misshapen and a collection of goop in it. The other was just more stiff than I expected |
Posted: Fri May 24, 2019 7:25 am Post subject: Re: Big oil leak at start - then fine. |
Looks like someone didn't get it installed correctly. Not a good place to use any kind of goop.
Wonder if someone tried to reuse an old seal and used goop to try to get it to seal again? |
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2539 Location: Plattsburgh, New York
Posted: Fri May 24, 2019 9:07 am Post subject: Re: Big oil leak at start - then fine. |
Nice to find a smoking gun like that anytime you have an oil leak... |
Posted: Fri May 24, 2019 10:28 am Post subject: Re: Big oil leak at start - then fine. |
Yep. Nothing worse than thinking you found the leak. |
