Dwayne1m Samba Member
Joined: December 31, 2011 Posts: 3538 Location: Pennsylvania
Posted: Sat Sep 15, 2018 6:55 pm Post subject: 06 Beetle convertible top problem |
Yep, the top has come unglued from the rear window. I tried gluing it back on but the top is curled and stiff with no ability to stretch so I have very little mating surface. Here is my idea....to add material to the top so I have more of a mating surface to glue to the rear window. I'm thinking a 3" strip sewn into the top would give me enough material to have an adequate mating surface to glue it back on. I'm not overly concerned about looks at this time. I just need to keep that window attached. Thoughts? |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Sun Sep 16, 2018 4:27 pm Post subject: Re: 06 Beetle convertible top problem |
I’ve seen where upholstery shops remove the glass & see in one of the PVC windows. Past that, you get to replace the top, nothing will bond to the old glass or the top because of the failed adhesive. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sun Sep 16, 2018 5:14 pm Post subject: Re: 06 Beetle convertible top problem |
I've successfully glued the bottom of the rear window to the canvas and that is holding for 2 years now. I used Rhino Glue. But the top of the window there just isn't enough of a mating surface to be able to "get a bite", plus I believe the top has shrunk with age and the canvas isn't as flexible as it once was. Even if I lose 1" of window that wouldn't bother me at all. The price of a top is $700+ and that is with me installing it, so I'm looking at all alternatives. |
