stevespeirs Samba Member
Joined: June 10, 2008 Posts: 310 Location: Virginia Beach, VA
Posted: Sun Sep 16, 2018 10:03 am Post subject: Positive Battery Cable Diameter |
What's the correct gauge for the positive battery cable? Looks like the PO has installed 6 gauge. I think I remember reading the original cable diameter was 25mm. (4 AWG equivalent?)
I need to replace the positive terminal (it's actually a negative terminal, so doesn't fit the positive post on my new battery), so might as well get the correct cable while I'm at it. Nice bit of crimping, huh?
Thanks for any help! _________________ 1979 Microbus |
Joined: January 01, 2007 Posts: 16878 Location: sticksville, ct.
Posted: Sun Sep 16, 2018 10:38 am Post subject: Re: Positive Battery Cable Diameter |
25mm is close to 1 inch...
I have run 2ga and it's a wonderful upgrade. iirc 4 is stock _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Sun Sep 16, 2018 10:46 am Post subject: Re: Positive Battery Cable Diameter |
skills@eurocarsplus wrote: |
Of course. What was I thinking! _________________ 1979 Microbus |
wcfvw69 Samba Purist
Posted: Sun Sep 16, 2018 11:05 am Post subject: Re: Positive Battery Cable Diameter |
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=311971225C
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111971235C
I bought these from WW. They nice and thick. _________________ Contact me at [email protected]
The Samba member since 2004.
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Sun Sep 16, 2018 7:40 pm Post subject: Re: Positive Battery Cable Diameter |
It’s all about conductivity. With that shitty assed clamp you have pictured, you’re going to lose so much conductivity that it doesn’t really matter what size the cable is. You can do much better _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Sun Sep 16, 2018 11:39 pm Post subject: Re: Positive Battery Cable Diameter |
Another factor to consider is the number of wire strands. For any given wire gauge, more strands of finer wire (automotive wire) is preferable to fewer strands of thicker wire (house wire). The finer wire is much more flexible and fatigue resistant.
The ultimate solution is welding cable. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Tue Sep 18, 2018 10:14 am Post subject: Re: Positive Battery Cable Diameter |
I have used this company in the past to have custom cables made for our test vehicles. Fast turnaround and very good pricing.
https://www.batterycablesusa.com/battery-cables.html |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Tue Sep 18, 2018 10:31 am Post subject: Re: Positive Battery Cable Diameter |
If you look at the wiring diagram, it shows the original wire size in square millimeters.
The large cable from the battery to the starter is 25 sq. mm. cross sectional area so that's probably why you had 25mm in your head. But yeah mm diameter and sq. mm. cross sectional area are two different things
You can google up a chart of conversion from sq. mm. to American Wire Gauge (AWG). 25 sq. mm. is a little bit closer to 3 gauge than it is to 4 gauge, but it's in between there. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Tue Sep 18, 2018 10:38 am Post subject: Re: Positive Battery Cable Diameter |
sjbartnik wrote: |
The large cable from the battery to the starter is 25 sq. mm. cross sectional area so that's probably why you had 25mm in your head. |
Indeed it is. Thanks for the explanation! _________________ 1979 Microbus |
Posted: Wed Sep 19, 2018 2:19 pm Post subject: Re: Positive Battery Cable Diameter |
I think my cables are #1 AWG. Nice and fat. |
Posted: Wed Sep 19, 2018 2:22 pm Post subject: Re: Positive Battery Cable Diameter |
I think my cables are #1 AWG. Nice and fat. More voltage at the starter means less energy loss, faster cranking, and longer starter life, still running the starter I got with my van when I bought it 30 years ago, with just brush and bearing replacement a couple of times over the years. |
