robert reese Samba Member
Joined: March 19, 2011 Posts: 51 Location: asheville n.c.
Posted: Sun Sep 16, 2018 3:48 pm Post subject: second battery |
Good Day, my question is when dose the second [house battery] charge ? I've had the 2001 eurovan plugged in to shore power for 2 days and on the panel it still shows 1 red dot for the battery condition . Must the van be running ? To be charged ? THanks for your help. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Sun Sep 16, 2018 6:27 pm Post subject: Re: second battery |
Is this for a EV Camper or a EV weekender second battery? _________________ .ssS! |
Posted: Mon Sep 17, 2018 5:49 am Post subject: Re: second battery |
IT IS A EUROVAN WINNIEBAGO FULL CAMPER. |
e&m_ghia Samba Member
Posted: Mon Sep 17, 2018 7:04 pm Post subject: Re: second battery |
The EVC shouldn't need the engine running, to charge the battery, shore power should do fine. (On our 97, the engine charger didn't work when we got it - the relay connecting the aux battery to the engine alternator had quit before we got it! So we could only charge by shore power, until we replaced the relay.)
You might try directly hooking the battery up to a plug-in charger, see if that works any better.
If you can take a look at the battery voltage directly with a DVM, as it's charging and disconnected, that might tell you something also. (We put an ammeter on ours, just so I could monitor it... But that's excessively compulsive.) |
Posted: Tue Oct 16, 2018 5:50 pm Post subject: Re: second battery |
Hello, I'm still trying to figure out why the house battery is not charging. so I put a volt meter on the battery with the shore power plugged in . It was plugged in for days.[ cold beer]. The meter read 8.4 volts. I unplugged the shore power and the meter read 5.4. So I took the battery out and put a charger on it and the next morning the meter read 13.4. I then unhooked the charger. The next day today I check the battery and it read 10,4 Bad battery ?. So the I plug the shore power in and hooker the volt meter to the battery wires and got a 11.8 reading . I also started the van with the shore power unplugged and the meter on the wires got no reading on the meter. Sorry for the long story but if anyone can under stand me and can help me under stand it it would be greatly appreciated thanks |
Posted: Wed Oct 17, 2018 3:44 am Post subject: Re: second battery |
If it sat at below 12 volts for any amount of time it is dead. Probably the shore power charger is faulty _________________ .ssS! |
Posted: Wed Oct 17, 2018 2:50 pm Post subject: Re: second battery |
Thanks ,that's what I was thinking . I checked the battery today and it was at 5 volts. Could you guide me to the charger location ? Or better a location for a repair manual . once again Thanks |
