123ignition curves
kendy
kendy is offline
PostPosted: Mon Sep 17, 2018 10:53 am    Post subject: 123ignition curves Reply with quote
Hi
Can I find any sources with curves for modified engines? Have problem with my engine - some predetonations Sad Want to correct it by 123ignition but have no idea how Sad
2332 ccm , fk89 , 44x37 progas heads, 10,5:1 - vpower racing fuel
Can anyone help ? Smile
kendy
hobbybob517
hobbybob517 is offline
PostPosted: Mon Sep 17, 2018 11:24 am    Post subject: Re: 123ignition curves Reply with quote
I bought the 123 ignition and it sucks,
It's basically a 009, unless you get the USB one.
THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote:
3 million rpm? Well there's your problem! No wonder it blew up!
Bad bug
Bad bug is offline
PostPosted: Mon Sep 17, 2018 11:45 am    Post subject: Re: 123ignition curves Reply with quote
Why didn't you try crank fired ignition.
bugguy1967
bugguy1967 is offline
PostPosted: Mon Sep 17, 2018 12:49 pm    Post subject: Re: 123ignition curves Reply with quote
How much total advance do you have now? From the description, it looks like you'd need around 28°. Maybe less. Just keep backing-off timing until it goes away.
"A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine"
kendy
kendy is offline
PostPosted: Tue Sep 18, 2018 2:48 am    Post subject: Re: 123ignition curves Reply with quote
Ok, thanks Smile Will start with 28 Smile It should be around 2000 rpm?
kendy
