mattoreg Samba Member
Posted: Mon Sep 17, 2018 9:37 pm Post subject: 12 motor to 6 volt? |
Oh boy, so I think I may have screwed up.
I wanted to replace my tired 1500 motor in my 62 double cab. It’s all six volt. So I bought a rebuilt 1776 duel carb motor, put the generator on, prettied up all the tin, all together ready for install. Pulled my motor and went to install the 1776!! Now I just realized the flywheel on the 1776 is a 130 tooth 200 mm clutch and the old motor is a 109 tooth 200 mm clutch. So now I think I’m screwed as I believe the 130 tooth flywheel will not marry up to my starter.
So what do I do?
Is there a six volt starter with a teeth to match the 130 tooth flywheel?
So I think could install the 1776 with a little grinding of the bell housing. But this starter issue is really throwing me for loop.
Advice? I’d love to keep it 6 volt.
Matt _________________ 62 Turkis DC |
madmike Samba Member
Joined: July 11, 2005 Posts: 5291 Location: Atlanta,Michigan
Posted: Tue Sep 18, 2018 3:43 am Post subject: Re: 12 motor to 6 volt? |
sorry u want to stay 6v. but your gonna need a 6-12v bushing for the bell housing ,yae ur going to need a 12v starter too _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
esde Samba Member
Joined: October 20, 2007 Posts: 5927 Location: central rust belt
Posted: Tue Sep 18, 2018 5:22 am Post subject: Re: 12 motor to 6 volt? |
Mofoco sells a later style o ring flywheel, that uses a 200mm clutch, but has the 6 volt ring gear.
*win*
You can even use the 6 volt starter on 12 volts, they hold up very well. _________________ modok wrote:
rpattee Samba Member
Joined: September 27, 2010 Posts: 223 Location: Anchorage, AK
Posted: Wed Sep 19, 2018 9:20 pm Post subject: Re: 12 motor to 6 volt? |
And that my friends! Is the answer!! _________________ 62 Turkis DC |
RWK Samba Member
Posted: Thu Sep 20, 2018 4:42 am Post subject: Re: 12 motor to 6 volt? |
You could swap the 6volt flywheel to new engine also,have reground and put new clutch on it, that flywheel you have is somewhat rare. I used that setup in my first car/baja bug, couldn't afford to convert to 12v, motor came from an older bus that was 6v/200mm gave me a larger clutch to learn on and burn up, also no grinding bell housing out! 6 volt starter will work on 12v just dont crank too long. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
