cdn_squareback Samba Member
Joined: September 25, 2016 Posts: 53 Location: canada
Posted: Tue Sep 18, 2018 7:57 am Post subject: Has Anybody Tried? |
Has anybody tried making a cold air intake system from those 2" intercooling pipe kits from Ebay? |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5995 Location: Brooklyn
Posted: Tue Sep 18, 2018 8:25 am Post subject: Re: Has Anybody Tried? |
Type 3 already has cold air intake system stock. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Tue Sep 18, 2018 9:46 am Post subject: Re: Has Anybody Tried? |
Yes it has been tried & done with varying components/success. He probably just wants to duct dual Webers to the stock intake air oval outlet.
W1K1 in Canada has the best one so far! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Tue Sep 18, 2018 10:41 am Post subject: Re: Has Anybody Tried? |
sjbartnik wrote: |
Type 3 already has cold air intake system stock. |
my 71 sb has dual carbs and the EMPI filters are restricting air, car runs fine with air filters, as soon as I put them on they choke. so I'm looking into alternatives. |
Posted: Tue Sep 18, 2018 10:45 am Post subject: Re: Has Anybody Tried? |
Mike Fisher wrote: |
W1K1 in Canada has the best one so far! |
that's amazing, wish I had the craftsmanship to do something like that |
Posted: Tue Sep 18, 2018 11:02 am Post subject: Re: Has Anybody Tried? |
I just found 21 discussions on dual carburetor air cleaners by using the Search tab below the Forums tab.. There have been VW Fox/Quantam/Australian etc components found to use in a Type 3 setup. Read through these 21 discussions & you'll find the components used/needed.
https://www.thesamba.com/vw/forum/search.php?searc..._chars=200 _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Tue Sep 18, 2018 11:14 am Post subject: Re: Has Anybody Tried? |
https://www.thesamba.com/vw/forum/search.php?searc..._chars=200 |
I have read a lot the last 3 weeks, non of which mentioned the intercooler piping kits. I was just wondering if anyone had success with it. |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4919 Location: Southern AB
Posted: Tue Sep 18, 2018 11:58 am Post subject: Re: Has Anybody Tried? |
2"tubing will not supply your carbs with enough air unless you are putting a turbo on it.
I started with 2.5" oval tubing, the engine fell on it's face around 4K when it ran out of air. the filter was fed by both the stock location and a scoop under the car, pushing through 2.5" hose.
My current oval intake is equivalent to a 4" diameter tube. still fed by 2 2.5" tubes. _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Posted: Tue Sep 18, 2018 12:26 pm Post subject: Re: Has Anybody Tried? |
W1K1 wrote: |
My current oval intake is equivalent to a 4" diameter tube. still fed by 2 2.5" tubes. |
thanks for the feedback. will scrap that idea lol. think I will measure the cfm needed for each carb this weekend as a starting point. it's stock at the moment but I'm planning on building a 1776 this winter. |
oxsign Samba Member
Joined: February 19, 2006 Posts: 607 Location: Sanford, FL
Posted: Fri Oct 05, 2018 2:57 pm Post subject: Re: Has Anybody Tried? |
cdn_squareback wrote: |
W1K1 wrote: |
Please be sure to post those results here. _________________ 1971 Squareback, fully bagged, 1776.
Build thread here.....
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
old_man Samba Member
Joined: June 19, 2018 Posts: 1381 Location: Newfoundland
Posted: Fri Oct 05, 2018 3:58 pm Post subject: Re: Has Anybody Tried? |
Using an online calculator I get about 150cfm for a 1600. That's about 75 per carb at 6500 RPM.
https://www.widman.biz/English/Calculators/CFM.html
http://4secondsflat.com/Carb_CFM_Calculator.html |
