the joker Samba Member
Posted: Fri Oct 05, 2018 3:13 pm Post subject: Re: 84 joker weird no start/ ignition problem ? |
main jet , is the one inside the bottom of the bowl? removed everything cleaned and reinstalled
will chk spark via the old school way, pliers and leather glove , plug touched to the block
sat am installing new pump, came today's mail
interested to see if the flow is better than the old one.which was pretty weak
only thing different in the rebuild kit was the flow valve, wasn't like the original |
Posted: Fri Oct 05, 2018 4:04 pm Post subject: Re: 84 joker weird no start/ ignition problem ? |
Yes the main jet is the one in the bottom of the bowl it supplies fuel to both the idle system and the main venturi. Ethanol fuel can readily clog them up as the fuel in the bowl evaporates over time. Blowing air through the jet should have cleaned it right up, though I will take a wooden toothpick and stick it into the jet to break loose any crusties that may be left clinging to the sides of the jet opening.
Hopefully there will be something in the stuff you have bought that will set you engine right. |
Posted: Sat Oct 06, 2018 8:30 am Post subject: Re: 84 joker weird no start/ ignition problem ? |
ok started first try this am
didn't swap anything ran for 30 sec died
disconnected fuel line from the pump ,ran pump for 3 sec, had plenty of fuel in the cup.
reconnected everything, primed the bowl with 3 syringes of fuel
started up ran for 60 sec.dies
opened the top of the carb bowl full float was working
put it all together, started ran and is running now, took it for a short ride, seem normal
letting it cool down , going to check start it after lunch , let keep are fingers crossed , seafoam and cleaning? most of loosened things up |
Posted: Sat Oct 06, 2018 2:44 pm Post subject: Re: 84 joker weird no start/ ignition problem ? |
started first turn of the key , took it for a 10 mile ride, stopping and starting along the way, all seem back to normal.
seafoam must of did it's thing, adding to the next fill up, and from then on
looks like it's going to Transporterfest after all , thanks wild thing for all your input |
Posted: Sat Oct 06, 2018 3:05 pm Post subject: Re: 84 joker weird no start/ ignition problem ? |
A lot of people are resistant to adding carb/fuel injection cleaner to their gas, I know I was at one point, but way back my dad had a late '80 Chevy Impala (V6 automatic) that wouldn't shift right so I took it to the dealership the have it checked out. The service tech said that he could find nothing at all wrong with the transmission and then asked if I was running FI cleaner from time to time and I said "no". He then got on my case a bit, arguing that one couldn't expect the transmission to shift right if one didn't maintain the engine properly. I kind of took what he said as BS, but bought some FI cleaner anyway and added it to the fuel tank, withing a mile of driving the tranny was shifting just fine as the engine was now running within design parameters and the feedback from the engine to the tranny was as per the book. Have been using FI cleaner as a first step in trouble shooting ever since. |
Posted: Mon Oct 08, 2018 5:49 am Post subject: Re: 84 joker weird no start/ ignition problem ? |
took it to the show sunday
started normal was loading up, idled for 5 mins died WTF
few pumps of the pedal started right up
ran fantastic no problems very responsive on the highway ,acted totally normal
leaving the show, started normal, first red light , started to stumble a bit, gave its some gas, HUGE backfire, then back to normal all the way home
any ideas maybe the end of the bad gas,crud, |
Posted: Fri Oct 12, 2018 10:11 am Post subject: Re: 84 joker weird no start/ ignition problem ? |
ok update
after the show day, started right up , headed out to do and errand down the street , started to stumble , died, restarted, rev it huge back fire died! would not start or stumble after several attempts
towed it home
chk fuel pump pumping,and filling the bowl(drained it no water ) good volume
took a break from it for a few days(other stuff going on)
this am 3 pumps of the pedal, normal start, ran /rev/ idled 5 mins
no stumble or sputter just dies with a huge gasp at the carb( filter cover off at the time)
really frustrating thinking electrical? did not chk the bowl but it seems there fuel at the carb(good spray)
working alone ,so wiggled some wires /tapped the carb/looked at grounds/wires everything looks normal
have some tune parts on there way, never replaced the coil on this rig(30yrs)
also the electric fuel pump seems to (when the key is turned) sounds lower buzz/then higher buzz it's wired to the coil, but always has been
and if not enough it has been extremely wet/damp in the east
out of ideas,and this needs to be my daily dr for a while |
Posted: Fri Oct 12, 2018 10:34 am Post subject: Re: 84 joker weird no start/ ignition problem ? |
My ancient Dodge was running somewhat like this, start up and run fine, and then after a few miles run horrible, spit and backfire and then die and couldn't be restarted. Ended up being a bad diode in the alternator that the electronic ignition module was seeing as a signal from the pickup in the distributor. Had the alternator rebuilt and the problem went away. |
Posted: Fri Oct 12, 2018 11:05 am Post subject: Re: 84 joker weird no start/ ignition problem ? |
alternator was rebuilt and is putting out good volts
will chk if there noise
can I chk the diode ....replace?
belt did squeal today but things are damp around here |
Posted: Fri Oct 12, 2018 11:27 am Post subject: Re: 84 joker weird no start/ ignition problem ? |
the joker wrote: |
You would need a scope to see what the alternator was actually doing. Have you changed the ignition module?
Maybe get a condenser and install it between the + terminal on the coil and ground to clean up the power to the coil |
Posted: Fri Oct 12, 2018 11:45 am Post subject: Re: 84 joker weird no start/ ignition problem ? |
never replaced ign mod or halls
maybe time busdepot has OEM on closeout |
Posted: Fri Oct 12, 2018 12:57 pm Post subject: Re: 84 joker weird no start/ ignition problem ? |
the joker wrote: |
If you know someone close by, maybe ask if you could swap the distributor and ignition module over to your van for a test. |
Posted: Sat Oct 13, 2018 9:33 am Post subject: Re: 84 joker weird no start/ ignition problem ? |
Ok a little update
took the alt off and had a local shop test it all good
here's the weird stuff
put it back on, and went thur my normal routine, 3 pumps of the pedal, started first turn, ran normal cold idle, little high, reved up normal settled to a little high
tweaked the idle /mix screw ever so slightly, the spray draw noise sounded real steady,idled better
ran normal, reved settled to decent idle, for 15 minutes, then ,I was at the engine, a slight click? at the carb either the float v, or the idle cut off? and it died
started right back up, I started wiggle wires / grounds ran normal 15 mins kept my hands on the carb and cut off nothing , shut it down
letting it cool down now
it's raining now ,but will go out soon for a test ride in the neighborhood
have a buddy with an igni mod but not till monday |
Posted: Wed Oct 17, 2018 10:08 am Post subject: Re: 84 joker weird no start/ ignition problem ? |
ok back to pulling my hair out
update ran great all week, lite highway/ city driving
some new gas
this am started right up, got a 1/2 mile , turned a corner DIED no sputter, just died.
check the eng bay , everything looks normal , carb bowl cold(gas in there?)
was a bit of pump noise, but that has been like that.
tried numerous times to start it , remembered I had a spare igni switch, swap it in, and it started briefly
tried again, push on it a little harder, heard a relays over fuse was clicking and it stumbled.
had it towed the 1/2 mile, charging the batts now, thinking the spare igni switch is a brand new junk part
ordering a few from different vendors asap
going to a buddies tonite to remove his igni mod to eliminate that
going out after lunch to pull down the fuse panel and check things out
even ordered a mech pump set up (waiting for it)
thinking the pump /igni system are both acting up coincidently, plus I hate the noise from the elec pump
any input would be appreciated greatly , one good thing is I was planning on a road trip , better to break down in town |
Posted: Wed Oct 17, 2018 10:15 am Post subject: Re: 84 joker weird no start/ ignition problem ? |
My dozen year old Airtex marine pump is still very quiet. I put my hand on it if I want to know for sure it is running. |
Posted: Wed Oct 17, 2018 10:58 am Post subject: Re: 84 joker weird no start/ ignition problem ? |
went out to put the charger on it, tried it for the hell of it started right up , moved it over in the driveway , ran at a fast idle for 5 mins died, now no start
I'm still thing fuel? pump is really laboring
have yet to pull down the fuses panel, |
Posted: Wed Oct 17, 2018 12:07 pm Post subject: Re: 84 joker weird no start/ ignition problem ? |
Sure your alternator is good and that your battery is good? |
Posted: Wed Oct 17, 2018 1:07 pm Post subject: Re: 84 joker weird no start/ ignition problem ? |
vdo volt gauge on the batt, just put the trickle on because
newer diehard ? international?
had the local ace armature (rebuilder) check it last week all good. great
just waiting to swap out igni mod
order a couple igni switches continental / meryle ?
and new igni(plug) wires , needs a total tune up pretty soon anyway |
Posted: Thu Oct 18, 2018 7:45 am Post subject: Re: 84 joker weird no start/ ignition problem ? |
ok back at it this am
manual pump installed ( no marks on the pump? so bottom inlet from the tank? top to the carb?) I quess?
started and died what the f//k
spray starter fluid in the carb starts dies
going to switch hoses? and see if that makes a difference
wondering about the return hose and one way valve back to the tank?
won't be able to get the igni mod till tonite but don't think that's the problem
what else can I do to the carb / this is really f//king with my head
I need this vehicle running |
Posted: Thu Oct 18, 2018 9:47 am Post subject: Re: 84 joker weird no start/ ignition problem ? |
Some fuel pumps have top outlets and some have bottom outlets. |
