wayne1230cars Samba Member
Posted: Wed Sep 19, 2018 11:03 am Post subject: Gear oil leakage with rear drum removed |
Pulled a rear drum on my ‘60 about 10 days ago while awaiting for some new brake parts to be shipped from WW. Noticed a bit of a puddle of gear oil on the garage floor today. Guessing that this happens with the drum removed and I need not be concerned??? Didn’t show any evidence of leakage before I pulled the drum. _________________ 1960 beetle
1970 beetle convertible |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Wed Sep 19, 2018 11:05 am Post subject: Re: Gear oil leakage with rear drum removed |
The torque of the drum nut compresses the spacer hidden o ring seal..
Yes normal..now that drum is off... but... if you have no idea of when the axle seal and o ring were changed last.. best to replace now..
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Wed Sep 19, 2018 1:08 pm Post subject: Re: Gear oil leakage with rear drum removed |
VOLKSWAGNUT wrote: |
Thanks. Sounds like a good idea especially with new brake shoes. Looks like a straightforward job. I noticed one method said 1) install o-ring 2) install spacer 3) install seal. The other one said 1) o-ring 2) seal 3) spacer. Which is best? _________________ 1960 beetle
Posted: Wed Sep 19, 2018 6:36 pm Post subject: Re: Gear oil leakage with rear drum removed |
1960 bearing caps?
Drum slinger?
Posted: Wed Sep 19, 2018 8:58 pm Post subject: Re: Gear oil leakage with rear drum removed |
1960 bearing caps?
Drum slinger?
Yes 1960 with the drum slinger. _________________ 1960 beetle
viiking Samba Member
Joined: May 10, 2013 Posts: 2667 Location: Sydney Australia
Posted: Thu Sep 20, 2018 4:14 am Post subject: Re: Gear oil leakage with rear drum removed |
wayne1230cars wrote: |
Thanks. Sounds like a good idea especially with new brake shoes. Looks like a straightforward job. I noticed one method said 1) install o-ring 2) install spacer 3) install seal. The other one said 1) o-ring 2) seal 3) spacer. Which is best? |
I used the Bugme video method. He puts the spacer into the housing and then puts the spacer and housing onto the axle as a unit. When doing this you inspect that the spacer has not dislodged the seal's wire retainer when inserting the spacer into the seal, which it can easily do.
You then add the combined unit onto the axle and therefore more or less guarantee that the outer seal is in perfect shape. |
Posted: Thu Sep 20, 2018 11:47 am Post subject: Re: Gear oil leakage with rear drum removed |
^ x2..
yep... but.. I've not watched any video on it..
Just common sense to me..
Buy a good axle seal kit.. the bigger one.. it will have all you need and some extra parts for the later and better caps too.
Advice....now's the time to ditch that drum slinger and go to 65-67 caps and weep hole..
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111598051A
Posted: Thu Sep 20, 2018 8:34 pm Post subject: Re: Gear oil leakage with rear drum removed |
^ x2..
Well I thought it was common sense as well, but thought by big-noting my post with a reference to Bug Me videos would get me extra brownie points and make my post all the more believable. |
Posted: Fri Sep 21, 2018 8:17 am Post subject: Re: Gear oil leakage with rear drum removed |
viiking wrote: |
^ x2..
Glad that you mentioned the Bugme videos. I have them and sure enough the one on brake maintenance shows the rear axle seal replacement. On the drum slinger kind that I have, Mike Higgins does not remove the bearing cover but rather just pries the spacer and the seal out and then removes the metal washer and small o-ring. On the newer style, he removes the bearing cover to access the seal from the inside. That way he also changes the paper gaskets and the large o-ring which are included in the kit anyways. If this sounds like a bit of a plug for the Bugme videos, I guess it is. Very helpful. _________________ 1960 beetle
herbie1200 Samba Member
Joined: April 27, 2006 Posts: 833 Location: Rome - Italy
Posted: Tue Sep 25, 2018 3:44 am Post subject: Re: Gear oil leakage with rear drum removed |
This is a new way for me, to change seals without removing the bearing house.
Probably the bearing house can be repaired less frequently because the oring and the paper gasket are static (no friction).
Instead the the seal is prone to wear.
From a technical point of view: also the little o-ring is static because rotates with the whole axle. |
