66 bus sheet metal question
67_13Deluxe
Samba Resident Alien
67_13Deluxe is offline
PostPosted: Wed Sep 19, 2018 12:10 pm    Post subject: 66 bus sheet metal question Reply with quote
This may be a dumb question but under the front floor is this metal bracket type thing. It has the shift rod going through it. What is this piece called and where can I find one? Thanks.
Enkiel
Enkiel is offline
PostPosted: Wed Sep 19, 2018 12:15 pm    Post subject: Re: 66 bus sheet metal question Reply with quote
this one?
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211703029C
1964 Turkis Flipseat
67_13Deluxe
PostPosted: Wed Sep 19, 2018 12:17 pm    Post subject: Re: 66 bus sheet metal question Reply with quote
Not that one. I guess it would help if I put up the pictures.
Eric&Barb
Eric&Barb is offline
PostPosted: Wed Sep 19, 2018 12:18 pm    Post subject: Re: 66 bus sheet metal question Reply with quote
Not sure what part you are referring to. Have you tried the VW parts manuals here?:
http://www.oacdp.org/
Would try the hand and foot controls section in that. Use the "Full Index" for easier searching thru.
In Stereo, Where Available!
Eric&Barb
PostPosted: Wed Sep 19, 2018 12:20 pm    Post subject: Re: 66 bus sheet metal question Reply with quote
OK, you might get that from Gerson, but more likely you need a donor part since that is part of the frame.
67_13Deluxe
PostPosted: Wed Sep 19, 2018 12:24 pm    Post subject: Re: 66 bus sheet metal question Reply with quote
Thanks. I’m looking though the link and haven’t seen it so far. I’ll get a hold of Gerson.
67_13Deluxe
PostPosted: Thu Sep 20, 2018 1:29 pm    Post subject: Re: 66 bus sheet metal question Reply with quote
Here’s an update. I just got an email back from Gerson and he doesn’t make this. He said he doesn’t think anyone else makes it either. If anyone has a bus they are cutting up and you have one let me know. Or a picture of a complete one so I can fab it up. Or try.
Eric&Barb
PostPosted: Thu Sep 20, 2018 1:58 pm    Post subject: Re: 66 bus sheet metal question Reply with quote
Thanks for the update! Put up a "WTB" ad in the classifieds, and look thru the ads at least twice a day for buses being cut up.
67_13Deluxe
PostPosted: Thu Sep 20, 2018 4:04 pm    Post subject: Re: 66 bus sheet metal question Reply with quote
Yup. Ill be doing that. I have a couple messages out but no replies as of yet. I wonder if this is a common part to rust. I would think it is.
Eric&Barb
PostPosted: Thu Sep 20, 2018 4:17 pm    Post subject: Re: 66 bus sheet metal question Reply with quote
The whole lower 6 to 8 inches of the body is common to rust out on these old VWs! Laughing
67_13Deluxe
PostPosted: Thu Sep 20, 2018 11:10 pm    Post subject: Re: 66 bus sheet metal question Reply with quote
That's exactly what I have to replace on this one!! Very Happy I got a reply on my ad and he said CIP1 sells the floor with this attached to it. Ill verify that tomorrow and let you know.
tpinthepack
tpinthepack is offline
PostPosted: Fri Sep 21, 2018 2:21 am    Post subject: Re: 66 bus sheet metal question Reply with quote
I think this floor includes the part you need. It is listed as "hand brake bracket" but I see the shifter plate also. Not sure what year bus you have, but this is 65 and down.
https://alanhschofield.com/ourparts/prod_6232415-C...1051E.html
TP in the Pack (I am a cyclist)
1968 Manx N.O.S. w/ Barrett Chassis
1960 Single Cab 1914 w/ 40 DLRA's
1990 Vanagon DOKA
1972 Super Beetle
1979 Super Beetle Convertible
2011 Porsche Cayenne
67_13Deluxe
PostPosted: Fri Sep 21, 2018 2:51 am    Post subject: Re: 66 bus sheet metal question Reply with quote
Thanks! I'm wondering if all floors sold have the hand brake bracket on them.
EmpiGT
EmpiGT is offline
PostPosted: Fri Sep 21, 2018 6:40 am    Post subject: Re: 66 bus sheet metal question Reply with quote
No not all floors have that. In fact that is the only floor I've seen with it. WW and Gerson's doesn't.
Bruce Amacker
Bruce Amacker is offline
PostPosted: Fri Sep 21, 2018 9:08 am    Post subject: Re: 66 bus sheet metal question Reply with quote
If you're doing the front floor I'd recommend panel bond over welding- I've done both. About halfway down this page is the panel bond job I did.
https://leakoil.net/forum/viewtopic.php?f=23&t=4263&start=40
'66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263
67_13Deluxe
PostPosted: Fri Sep 21, 2018 4:18 pm    Post subject: Re: 66 bus sheet metal question Reply with quote
I’m doing the whole front end! I’ll definitely look into that panel bond. My step dad uses it in his auto body shop. Been doing that work for 50 years and if he says it’s good stuff too, I’ll go with it.
67_13Deluxe
PostPosted: Fri Sep 21, 2018 4:27 pm    Post subject: Re: 66 bus sheet metal question Reply with quote
I called CIP1 today and they told me their floors also do not have the hand brake bracket.
Hokie87
Hokie87 is offline
PostPosted: Fri Sep 21, 2018 4:28 pm    Post subject: Re: 66 bus sheet metal question Reply with quote
Out of curiosity, why do you like the panel bonding for the front floor over welding?
Busted-bolt
Busted-bolt is offline
PostPosted: Fri Sep 21, 2018 5:41 pm    Post subject: Re: 66 bus sheet metal question Reply with quote
It would be nice if we had those floors with the bracket on our side of the pond,w/o obscene shipping costs .Confused
Vw collection 60 combi ,61 panel ,62 deluxe micro,82 diesel Westfalia,88 Vanagon synchro,98 Jetta tdi,11 Jetta tdi mt ,11 Jetta tdi dsg.
I do all my own work,body,engine and transmission.
Bruce Amacker
PostPosted: Fri Sep 21, 2018 6:04 pm    Post subject: Re: 66 bus sheet metal question Reply with quote
Faster. Stronger. Little or no after-work (grinding out the welds).
'66 Deluxe Bus
'65 Standard Bus
Build threads:
