smitty24 Samba Member
Joined: April 28, 2008 Posts: 2723 Location: Salem, Oregon
Posted: Sat Oct 20, 2018 9:15 pm Post subject: Re: Kustom1wherehouse narrowed beam, steers like a dump truck! WHY? |
My bad, I just saw that you pulled the beam and put stock back on, and problem fixed. And you said you fought to get adjusters at half point. Sounds like adjusters welded wrong angle for one thing. Can you post a picture of the beam and adjuster blocks close up? Someone would surely buy it on here. All I use and install is stock or cb 2”. Perhaps it was an Empi 2” which sounds more like something K1 would do. |
fifthcenturycheese Samba Member
Joined: May 04, 2014 Posts: 172 Location: Pismo Beach
Posted: Sun Oct 21, 2018 8:12 pm Post subject: Re: Kustom1wherehouse narrowed beam, steers like a dump truck! WHY? |
Smitty 24,
Here is a picture of the beam before going on car. Yes, I installed the steering box adjusted, centered and lubricated. Yes, there was one set of Empi caster shims. Tie rods were checked by alignment guy, looked good, but he said ALL the ball joints were stiff. i mentioned this to K1 and he said he would "hammer" on them to break them in. I am not a person that beats on new parts to make them function. I don't believe the engineers of those parts said...."just let the customers beat them into place until they function"! Like I said, I resolved the my issue and am much happier with the stock beam I rebuilt, functions just as I wanted! DONE and moving on.....!
Posted: Sun Oct 21, 2018 8:57 pm Post subject: Re: Kustom1wherehouse narrowed beam, steers like a dump truck! WHY? |
Part of the problem is the way your beam is setup, I can see it...but as you said it’s done now. It’s too bad because the CB beams are usually pretty nice. |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Mon Oct 22, 2018 3:27 am Post subject: Re: Kustom1wherehouse narrowed beam, steers like a dump truck! WHY? |
smitty24 wrote: |
I’d be curious as to what you see for informations sake. I have a CB LP beam in a car that has horrificly stiff steering by mine was due to a stiff spindle with a bent carrier. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
Posted: Mon Oct 22, 2018 9:21 am Post subject: Re: Kustom1wherehouse narrowed beam, steers like a dump truck! WHY? |
Ill PM you...don't want to trash this guy's thread with debates of what's correct, blaming companies, and anyone's lack of skills. |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Mon Oct 22, 2018 10:45 am Post subject: Re: Kustom1wherehouse narrowed beam, steers like a dump truck! WHY? |
The adjuster studs are located in the wrong holes. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon Oct 22, 2018 5:59 pm Post subject: Re: Kustom1wherehouse narrowed beam, steers like a dump truck! WHY? |
TDCTDI.
The adjuster studs are located in the only holes I could find in the collars, I rotated them almost all the way around. These are the only holes! |
Posted: Tue Oct 23, 2018 2:28 am Post subject: Re: Kustom1wherehouse narrowed beam, steers like a dump truck! WHY? |
The second set of holes should almost be visible in the upper portion of the slot, they’re 90° from the ones where the stud is now. If they’re not there, the wrong collars were used and the adjuster teeth were welded in the wrong position. This angle would cause the front end to be oversprung & the balljoints would be binding because they were at their max angle.
Since you have confirmed that the adjusters do not have these second set of holes, then you should be able to return this beam as it is built incorrectly.
It sucks that you had to go through all of that, you should definitely contact the seller/builder of that beam to get a refund. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Keith Samba Member
Joined: August 15, 2005 Posts: 3634 Location: Brodheadsville, PA
Posted: Tue Oct 23, 2018 8:32 am Post subject: Re: Kustom1wherehouse narrowed beam, steers like a dump truck! WHY? |
TDCTDI wrote: |
It sucks that you had to go through all of that, you should definitely contact the seller/builder of that beam to get a refund. |
I had a buddy build his own beam with these adjusters and he slid the block in wrong on the leaf pack. _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
Mos6502 Samba Member
Posted: Fri Oct 26, 2018 2:18 am Post subject: Re: Kustom1wherehouse narrowed beam, steers like a dump truck! WHY? |
Wheels, tires?
People do realize the scrub radius changes with tire height and wheel offset right? And the larger the scrub radius - the heavier the steering.
If you're using wheels with more backspacing than stock - that increases steering effort. If you're combining more backspacing with low profile tires (less height) that again increases steering effort. If the tires are wider than stock - again, steering effort is increased. Combine all three with new ball joints, and whatever else has been done to the front end, and you can end up with pretty unwieldy steering (on any car!).
Not saying that's problem here, but it's something I almost never see anybody consider. |
