calo1956 Samba Member
Joined: April 18, 2011 Posts: 701 Location: long Island new york
Posted: Thu Sep 20, 2018 6:00 pm Post subject: Flasher relay for LED blinkers? |
Hello fellow Samba members. I finally have a cut and dry question to post here. I just replaced my tail lights bulbs with LED bulbs. I think its a good upgrade, (especially if you saw my last post). So the issue is that my directionals blink fast now. I heard thats a possibility, and was told i need to change the flasher. Does anyone know where this is on a 1980? is there even one? _________________ Enjoy the ride....
72 bug
80 westfalia |
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Thu Sep 20, 2018 7:43 pm Post subject: Re: Flasher for blinkers? |
The cheapest easiest solution is to add a parallel load resistor each side, to simulate the low resistance of the incandescent bulbs that you replaced. Most places that sell LED replacements will stock them. _________________ Jim Crowther
Vespa GTS 300 |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
kamzcab86 Samba Moderator
Posted: Thu Sep 20, 2018 10:05 pm Post subject: Re: Flasher for blinkers? |
calo1956 wrote: |
was told i need to change the flasher. Does anyone know where this is on a 1980? is there even one? |
Yes, your van should have a flasher relay. It may not be stamped with a number in your van, but it's #21 in this borrowed photo:
Head to your local auto parts store and grab an electronic flasher relay with pins 49, 49a, and 31. Or, go the resistor route as noted above. _________________ ~Kamz
2016 Golf GTI S
Posted: Fri Sep 21, 2018 5:36 am Post subject: Re: Flasher for blinkers? |
Im going to try changing the flasher relay, seems like the simplest route _________________ Enjoy the ride....
72 bug
80 westfalia |
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Fri Sep 21, 2018 12:35 pm Post subject: Re: Flasher for blinkers? |
This relay: CF13-GL02
worked for me to stop the hyperflashing after the turn signals were swapped with LEDs.
I don't think you'll find it at the auto parts store. |
Posted: Sun Sep 23, 2018 3:45 pm Post subject: Re: Flasher for blinkers? |
Thanks Erste, i appreciate the link, i ordered one on amazon, so if it doesn't work, i have a fall back plan! _________________ Enjoy the ride....
72 bug
80 westfalia |
skelly Samba Member
Joined: May 13, 2018 Posts: 45 Location: Upper peninsula, MI
Posted: Sun Sep 23, 2018 3:54 pm Post subject: Re: Flasher for blinkers? |
superbrightleds.com sells the relay. works perfect. Just did it yesterday. What LEDs did you use for your blinkers? |
Posted: Mon Sep 24, 2018 5:36 am Post subject: Re: Flasher for blinkers? |
Im using these fit perfect, and your well other than the quick flash. Its not that fast that i can't still drive till i get the new relay. Coming tuesday.
Philips 12898B2 1156 Bright White Vision Led Back-up light, 2 Pack _________________ Enjoy the ride....
72 bug
80 westfalia |
riceye Samba Member
Joined: March 09, 2006 Posts: 1661 Location: Caledonia, WI
Posted: Mon Sep 24, 2018 5:55 am Post subject: Re: Flasher for blinkers? |
I replaced my directional bulbs with LED quite a while ago - over a year, for sure. I did notice right away that they flashed at a 2x rate. No worries, kind of a "Euro-look" thing, so I left it at that.
This summer I noticed that my hazard lights (four ways?) do not flash at all. They just turn on and stay lit. I'm guessing the hazard flasher needs to be changed out or resistors added to the circuit(s). Winter project.
Just a heads up, check your hazard lights for functionality. _________________ '87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
“I find that things usually go well right up until the moment they don't.” - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig |
skelly Samba Member
Posted: Mon Sep 24, 2018 9:33 am Post subject: Re: Flasher for blinkers? |
is everything working properly when headlights are on? Are front side markers on when headlights are on? The ones I picked up do NOT work properly, in that the side marker running lights are on when headlights are on and then the don't blink. With headlights off, the side marker lights are off and blinkers work. superbrightleds.com is telling me I need a "CK switchback bulb" to get both running lights and blinkers working. |
84Cabby82Westy Samba Member
Joined: April 03, 2004 Posts: 49 Location: Missoula, MT
Posted: Mon Sep 24, 2018 10:52 am Post subject: Re: Flasher for blinkers? |
I just went to a FLAPS and bought an LED-compatible flasher and the recommended superbrightleds units worked fine. One thing to remember, with the LEDs when one goes out there won't be a change in the blinker frequency to let you know like with incandescents. |
Posted: Mon Sep 24, 2018 4:26 pm Post subject: Re: Flasher for blinkers? |
Well so far everything works fine, flashers, side markers etc, like you said, they blink at 2x the rate the should, ill see how the flasher works, coming tomorrow _________________ Enjoy the ride....
72 bug
80 westfalia |
Posted: Mon Oct 01, 2018 6:55 pm Post subject: Re: Flasher for blinkers? |
Well thank you Erste! The two previous relays i ordered didn't work,( i guess the first one really didn't count because it was a 5 pin,not 3 pin, my fault for not looking first!) The second one was 3 pin bought on Amazon, but didn't work, there was no flash at all. CF13-GL02 this one was the ticket! It was in Ebay, came today, and worked like a charm!! Thanks again for the link!! _________________ Enjoy the ride....
72 bug
80 westfalia |
danfromsyr Samba Member
Posted: Mon Dec 27, 2021 11:34 pm Post subject: Re: Flasher for blinkers? |
there is this flasher relay that has a dial where you can set the speed rate of the flash to your preference.
https://www.ebay.com/itm/224083204830
Abscate wrote: |
4Gears4Tires Samba Member
Posted: Tue Dec 28, 2021 8:01 am Post subject: Re: Flasher for blinkers? |
I ordered 2, I'll let you know how they work out. _________________ '87 Syncro
Posted: Tue Dec 28, 2021 8:22 am Post subject: Re: Flasher relay for LED blinkers? |
the dial a flash relays, work great in our VWs
but I guess you never know for how long till it stops.. so YMMV..
*toss your old #21 flasher in the abyss of the bottom of the glove box.
I would NEVER.. ever install a resistor pack to correct flash rate when an electronic flasher is a plug and play option..
resistor packs do not alleviate the circuit load.. and they add in not only a new wiring splice.. but another component to fail. _________________
Abscate wrote: |
