bartt59 Samba Member
Joined: October 14, 2009 Posts: 31 Location: Directly over the gravitational center of the earth
Posted: Sun Jun 26, 2022 7:07 am Post subject: Re: Vanagon Land Rover Defender mirrors and brackets now avail in US |
No more floppy mirrors. Did I say they have tensioners that WORK !
I can do 80 and so can these.
Awesome mounts and fast delivery.
See about it.
_________________ Failure is not an option, unless, of course it was predicted and nothing was done to prevent it.
1984 Westy GL 4 sp
1985 Westy GL Auto |
oasis Samba Member
Posted: Sun Jun 26, 2022 5:23 pm Post subject: Re: Vanagon Land Rover Defender mirrors and brackets now avail in US |
Yup. Love mine. _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Past: 1974 Thing Acapulco / 2009 Eos Komfort / 1997 Jetta GT / 2002 Cabrio GLX / 2002 Passat GLS / 1971 Super Beetle / 1993 EuroVan MV Westfalia / 1981 Pickup LX / 1985 Vanagon / 1986 Jetta GLI |
unclekenz Samba Member
Joined: November 14, 2009 Posts: 37 Location: Sydney, Australia
Posted: Thu Aug 04, 2022 6:14 am Post subject: Re: Vanagon Land Rover Defender mirrors and brackets now avail in US |
Keen to learn .... can the bracket be swivelled forward an/or back to enable the mirror to be tucked back against the body whenever needed? |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3100 Location: ABQ NM USA.... Except when not
Posted: Thu Aug 04, 2022 7:36 am Post subject: Re: Vanagon Land Rover Defender mirrors and brackets now avail in US |
unclekenz wrote: |
Yes
Full +90deg/-90deg from straight out.
Possibly more though I haven't considered it tried beyond that.
I sometimes use that feature to clear obstacles when maneuvering tight spaces. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
valvecovergasket Samba Member
Posted: Thu Aug 04, 2022 8:06 am Post subject: Re: Vanagon Land Rover Defender mirrors and brackets now avail in US |
unclekenz wrote: |
definitely
they have 2 (3?) angles it can lock in at, and you can collapse them fully against the door as well _________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2323 Location: Adobe Jungle USA
Posted: Tue Aug 01, 2023 11:03 am Post subject: Re: Vanagon Land Rover Defender mirrors: warning! |
Warning to anyone who has these mirrors, beware! One broke off spontaneously while driving down the road. I went back and retrieved it but the mirror had shattered. Upon examination, the weld was extremely minimal and only on the outside. The weld had metal fatigued and broke off from the wind of driving.
I can imagine a stronger angle that is stamp-bent rather than welded. Any reports of better construction? _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
Posted: Tue Aug 01, 2023 11:39 am Post subject: Re: Vanagon Land Rover Defender mirrors: warning! |
Gnarlodious wrote: |
I can imagine a stronger angle that is stamp-bent rather than welded. Any reports of better construction? |
Hi, it has been covered in this thread that a manufacturing defect was discovered 3? years ago after which process was changed to bent rather than welded joints.
You will also see on this thread where I (the manufacturer) put the word out on here and other channels of this issue asking for reports of failurea and sending replacement of failed units.
If you contact me directly from SuperVanagon.com I'll work with you on a replacement on the bracket (I'm not involved in the mirror)
It is always most efficient to contact the seller/manufacturer if an issue comes up. Likely they have already dealt with that issue and have a solution and process in place.
It always surprises me to see threads started that are " product xxx I bought from yyy did this, how shall I fix". Before the user even contacted the seller/manufacturer. For those post, my first reply is "what did the seller/manufacturer say when you asked them?"
And, unfortunately, often those posts come with a words of what terrible product or seller (thanks for not going there) which is which really is out of place since the user did not go to the source that is best position to resolve the issue
....now if the seller/manufacturer doesn't respond, for sure post the facts so others can make their decisions more informed
....and if the seller/manufacturer resolves well, post that good resolution too so folks can feel comfortable that any issue is likely to be resolved well.
Look forward to hearing from you.
Andy _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
Posted: Tue Aug 01, 2023 2:19 pm Post subject: Re: Vanagon Land Rover Defender mirrors and brackets now avail in US |
Thanks Andy, I might have even bought these from you as I live in Santa Fe but it has been so long I don't remember and come to think of it there's a lot I don't remember. I didn't read this whole thread and not slamming any seller as I did get several years out of the thing. Yeah I already ordered a replacement glass from eBay seller glassmar_0 which was only $20. Are you saying the newer mounts are bent rather than welded? I'd prefer to upgrade befor the other side falls off! Thanks. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
Posted: Tue Aug 01, 2023 2:54 pm Post subject: Re: Vanagon Land Rover Defender mirrors and brackets now avail in US |
Yes, new design is bent not welded. Contact me through SuperVanagon.com for resolution.
If you bought only brackets you might have gotten them from me.
If you got brackets with mirrors you didn't get them from me directly. My brackets go to eBay seller listed on first page who bundles them with mirrors. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
