docdanracy Samba Member
Joined: June 26, 2012 Posts: 1118 Location: Auburn, CA
Posted: Fri Sep 21, 2018 7:12 am Post subject: 34-pict3, SVDA distributor switch |
Considering going to above combination on my mild 1679 SP.
currently have H30-31 and 009 that runs decent.
Any suggestions, pit falls I should watch for?
Is there an adapter to go from SP intake to 34-pict3 carb?
Other option would be dual 34 EPCs and SVDA
Thanks
Doc _________________ Doc
1970 Sunroof Bug Yukon Yellow (L19K)
Custom 6.5x15” 914 Sport Wheels wrapped in 185x65x15 Contis
Empi shifter, full compliment of gauges, 1679 with mild cam, stock induction
SOLD: 1974 Marina Blue Standard Beetle undergoing restoration/preservation
1679 with Kadrons and header/QP
914 sport wheels 5.5" ET40 wrapped in 195x65x15 Kumhos |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Fri Sep 21, 2018 7:31 am Post subject: Re: 34-pict3, SVDA distributor switch |
You'll need an adapter.
I suggest getting a rebuilt German carb and distributor. Yes, they're more expensive but they will work right out of the box and save you hours of trouble.
_________________ Glenn
Member #1009
#BlueSquare |
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
AlmostHeavenWV_VW Samba Member
Posted: Fri Sep 21, 2018 8:59 am Post subject: Re: 34-pict3, SVDA distributor switch |
For your consideration, IMO:
If you go with the 30pict3, no manifold adapter is needed.
Some with distributor rebuild experience state that early 70s SVDA distributors are superior quality of materials too.
Plus it'd be the 1970s set up for your engine too
_________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Fri Sep 21, 2018 10:24 am Post subject: Re: 34-pict3, SVDA distributor switch |
30PICT-3 with a 205T or 205K would be my pick, with preference to the 205K simply for more initial advance. I've run both and they work well.
If the 30/31 currently works well, I would just keep it, and get a vacuum distributor with preference to the 205K. The 30/31 is a perfectly serviceable carb if you have a good one to begin with (brosol ggood, empi iffy) and has a larger venturi than the 30 series carbs anyway. _________________ 73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087! |
Posted: Fri Sep 21, 2018 10:27 am Post subject: Re: 34-pict3, SVDA distributor switch |
Lingwendil wrote: |
If the 30/31 currently works well, I would just keep it, and get a vacuum distributor with preference to the 205K. The 30/31 is a perfectly serviceable carb if you have a good one to begin with (brosol ggood, empi iffy) and has a larger venturi than the 30 series carbs anyway. |
Ran the h30'31 for awhile with no issues. I only switched for originality. _________________ **1971 Super Project
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Fri Sep 21, 2018 5:16 pm Post subject: Re: 34-pict3, SVDA distributor switch |
I would stay with the 30 PICT series carburetors, a bit simpler to tune than the 34 PICT 3. The other reason for staying with a 30 PICT is that your choice of distributors is much better. The late 1960's SVDA are ok but your much better off with a SVA like the 113 K. Keep it mind if you go with the 113 K your timing will not be to stock specifications. The stock SVA would be a 113 905 205 T or a 113 905 205 M. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
wcfvw69 Samba Purist
Posted: Fri Sep 21, 2018 7:50 pm Post subject: Re: 34-pict3, SVDA distributor switch |
A couple of other thoughts-
* What muffler are you running? You really need to run a stock muffler so the heat risers get hot and warm the carb manifold.
* Is your bug manual or autostick? There's a big difference between the distributors advance.
All great suggestions already made. Simplicity would be a restored German Solex 30-1 with a base flange number 105-1. It's a 1967 carb and the best IMOP. Match it to a SVA like Tim suggested. 113905205K,M or T. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Fri Sep 21, 2018 9:19 pm Post subject: Re: 34-pict3, SVDA distributor switch |
Stock muffler with heat risers
Stock stick shift 4 speed _________________ Doc
Posted: Sat Sep 22, 2018 6:07 am Post subject: Re: 34-pict3, SVDA distributor switch |
docdanracy wrote: |
Stock stick shift 4 speed |
Dual port or single port? _________________ Contact me at [email protected]
Frank Bassman Samba Member
Posted: Sat Sep 22, 2018 6:55 am Post subject: Re: 34-pict3, SVDA distributor switch |
If it were mine I'd get the single port end castings and a 34 pict center section. I'm partial to the new Empi center section, which seems to be a copy of CB performance's part now. You WILL need to shorten the heat riser tubes and finagle them into place.
If you do these modifications to make the engine breathe more, as well as add displacement, don't choke the motor with a carb that has a 30 mm throttle plate when you can get a carb that has a 34 mm plate already. You can't go wrong with a rebuilt carb from volkzbitz but to be honest I have yet to go wrong with Empi's 34 pict which comes with extra jets already and is brand new...
Since you are increasing displacement I would also add a set of 1.25:1 ratio rockers to maximize the gains. You won't be disappointed.
-Frank |
Posted: Sun Sep 23, 2018 7:48 pm Post subject: Re: 34-pict3, SVDA distributor switch |
Any discussion on dual 34 EPCs? _________________ Doc
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15987 Location: North Florida, USA
Posted: Sun Sep 23, 2018 8:07 pm Post subject: Re: 34-pict3, SVDA distributor switch |
I think you need to answer the question of where you plan to take this build? Do you just want stock reliability (with stock HP), or do you really want more power than stock, in which case you have to decide where you want to end up (75HP, 100HP, 200HP+)? Each has a bigger price tag than the last. Do you want to buy parts that will support you from beginning to end, or are you willing to buy parts that will work at some stages but need to be replaced at later stages.
The 1679cc engine is not much larger than stock so you will not get much more performance than you would with a stock SP 1600 engine. Better breathing carbs (like dual EPCs) will be restricted by the SP heads and the stock exhaust so you will not get the most from them. The SP heads are probably you biggest issue when looking for performance. If you are planning to stick with them you should probably just look at stock single carb configurations. You CAN get performance from SP heads you just need to work more/harder and you will hit the performance limit sooner.
The heat risers in your stock exhaust allow you to run a stock center mounted carb and heat the intake properly. If you replace the stock exhaust in the future with headers you may loose the heat riser function (or degrade it) and your exhaust may no longer properly support a center mounted carb. The dual single carbs are much less finicky about heat since they sit right over and much closer to the HOT heads. But carbs along will not get you big performance gains. You need a properly thought out system that allows the engine to breath to maximize the performance. The stock engine configuration is really quite a good balance of economy, performance and power band to fit the stock use of the car. Often adding just ONE performance item (like a header) will result in throwing the balance of the system off and getting reduced performance AND economy.
So the question is, where do you want to go with this engine? _________________ AshMan40
Posted: Sun Sep 23, 2018 8:21 pm Post subject: Re: 34-pict3, SVDA distributor switch |
I would like a reliable set up with possibly minimal performance gains.
The car is really very stock, and was nicely restored ~10years ago.
My current setup seems to run a bit rich, bit has no bog or hesitation off idle or mid throttle acceleration..
Runs quite well up to from idle to full throttle.
Want to continue down the fairly stock route.
Car is driven daily.
Later I may build a bigger motor in the 1900-2000cc range and the put this one on a pallet in the corner of the shed
Thanks
gt1953 Samba Member
Posted: Mon Sep 24, 2018 6:53 am Post subject: Re: 34-pict3, SVDA distributor switch |
The 1600cc stock single port stock carb stock muffler stock sheet metal thermostat and flaps in place. Able to run down the highway at 65~70 mph when I want to. Reliable simple, works fine for me. Over the weekend went to the Jerome Jamboree 500 mile round trip ran fine and got to pass a few cars on the two lane hy.
Build the big engine you want and keep the reliable one, you will be glad you did. Some of the issues based on the photo of the engine is the mis match carb distributor. Unable to tell if the thermostat and flaps are in place. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Mon Sep 24, 2018 2:11 pm Post subject: Re: 34-pict3, SVDA distributor switch |
Everything is stock as far as thermostat l, flaps etc
H30-31 and 009 with Pertronix runs great, just wondering what might be out there to improve performance slightly along with economy. _________________ Doc
Posted: Mon Sep 24, 2018 5:00 pm Post subject: Re: 34-pict3, SVDA distributor switch |
docdanracy wrote: |
H30-31 and 009 with Pertronix runs great, just wondering what might be out there to improve performance slightly along with economy. |
Here's my 69 bug engine, bone stock running all it's original, restored parts. I have no issues with keeping up with traffic. Runs like a sewing machine. Starts and runs perfectly on cold mornings. No cold engine symptoms.
There's trade offs when you start adding performance goodies to these VW's. I drag raced cal-look bugs back in the 80's. Now, I've come to love the simplicity, reliability and driveability of a stock VW engine as delivered from VW. They are amazing engines when they have their thermostat and flaps in place. Working warm air to the carb hooked up. Stock carbs with matching SVA distributors. They can also be boring as the only thing they need is PM maintenance. Oil changes, valve adjustments, dwell checks.
I guess I've reached the age of boring. _________________ Contact me at [email protected]
Posted: Tue Sep 25, 2018 4:49 pm Post subject: Re: 34-pict3, SVDA distributor switch |
Good example of a correct original engine there, Bill. Folks need to take note of the fuel line from pump to carburetor without a filter. Bill's and mine are the only I've noticed recently being run this way- and scucessfully. _________________ Roads Scholar &
