Rocky Mountain Westy Samba Member
Joined: April 17, 2008 Posts: 1031 Location: Fort Collins Colorado
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9939 Location: Orbiting San Diego
Posted: Fri Sep 21, 2018 2:42 pm Post subject: Re: Vendors please help, we need this 2 pin connector! |
It needs 2 beveled corners and takes 2 small flat pins.
Mark |
kamzcab86 Samba Moderator
Posted: Fri Sep 21, 2018 3:31 pm Post subject: Re: Vendors please help, we need this 2 pin connector! |
This it?
That's the part number in the pic.
The boot (protective cap) is 447919141 in the parts catalog.
_________________ ~Kamz
2016 Golf GTI S
Posted: Fri Sep 21, 2018 3:51 pm Post subject: Re: Vendors please help, we need this 2 pin connector! |
Yes, as I said, the individual bits are available and common to many older VW/Audi vehicles.
What I'm attempting here is to get someone to offer a fully assembled splice-in wiring pigtail kit.
When I buy a replacement Syncro fuel tank sender because the contacts on the old one have corroded away, I'd like to put a complete new end on the wiring to match it.
Not just a bag of bits to attach to old corroded wires, an assembly with new wire pigtails already attached.
The same pigtail would work for the even more common corroded coolant level sensor harness.
Corrosion tends to work its way up the wires and after cutting some wire off back to a cleaner spot the wires may be too short so extra new wire is helpful. Also if you can't cut far enough back to find clean wire inside you may have to revisit the splices sooner than you hope and having to replace generic splices is much better than having to source and replace the VW connector pins again.
Yes, I'm fully capable of sourcing my own loose bits and installing them but that isn't what I talking about HERE.
The closest thing I've seen so far is a UK vendor's product, but it is just a bag of loose bits, nice as they may be.
Mark |
Posted: Fri Sep 21, 2018 4:22 pm Post subject: Re: Vendors please help, we need this 2 pin connector! |
Right, I know that.
I'm merely attempting to provide the vendors, like RMW who posted above, the correct part number for that specific connector so that they, you know, can perhaps source a bunch of them and put together a replacement kit. _________________ ~Kamz
2016 Golf GTI S
Posted: Fri Sep 21, 2018 4:28 pm Post subject: Re: Vendors please help, we need this 2 pin connector! |
Thank you. I already provided the numbers I have to the vendor who expressed interest.
Mark
kamzcab86 wrote: |
Right, I know that.
I'm merely attempting to provide the vendors, like RMW who posted above, the correct part number for that specific connector so that they, you know, can perhaps source a bunch of them and put together a replacement kit. |
syncro surf Samba Member
Posted: Fri Sep 21, 2018 4:32 pm Post subject: Re: Vendors please help, we need this 2 pin connector! |
kamzcab86 wrote: |
This it?
Where do these two parts come from? - I'd be happy enough to get the connector and the boot and make my own pigtail. That would be much better than the two individual spade connectors that I'm using now |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Fri Sep 21, 2018 5:46 pm Post subject: Re: Vendors please help, we need this 2 pin connector! |
crazyvwvanman wrote: |
I don't know why some Vanagon vendor doesn't step up and sell this connector setup for repairs. |
Probably because the parts are available and most people are able to assemble the parts themselves? _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
Posted: Fri Sep 21, 2018 6:06 pm Post subject: Re: Vendors please help, we need this 2 pin connector! |
And yet they are so keen to offer similar items that one might say the same about. For example:
https://www.vancafe.com/category-s/4715.htm
Mark
Mellow Yellow 74 wrote: |
Probably because the parts are available and most people are able to assemble the parts themselves? |
Joined: January 01, 2007 Posts: 16883 Location: sticksville, ct.
Posted: Fri Sep 21, 2018 6:18 pm Post subject: Re: Vendors please help, we need this 2 pin connector! |
kamzcab86 wrote: |
don't bother trying to help....because evidently even though the p/n of the parts is known, buying the correct female pins and a proper F crimp tool is just far to much to ask to make these at home.
o/p...
would you like the tool p/n and the pin p/n as well? because I love to breastfeed info to guys that just don't want to listen.... _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Zeitgeist 13 Samba Member
Posted: Fri Sep 21, 2018 6:43 pm Post subject: Re: Vendors please help, we need this 2 pin connector! |
Don't be your usual jackass. This was a legit request to the vendors for a legit part that frequently needs attention. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
hdenter Samba Member
Joined: October 14, 2008 Posts: 2754 Location: San Luis Obispo, CA
Posted: Fri Sep 21, 2018 6:45 pm Post subject: Re: Vendors please help, we need this 2 pin connector! |
Why not see if "thatvwbusguy" wants to do it? He does headlight pigtails and other things...
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
Posted: Fri Sep 21, 2018 6:50 pm Post subject: Re: Vendors please help, we need this 2 pin connector! |
I have all the parts and tools in hand already, been building harnesses for decades, even as part of my former professional electronics career. I am trying to get a Vanagon supplier to add a valuable and needed part for everyone to have available, its as simple as that. I recently stocked up on the pins and looked for the shells from somewhere other than VW parts channels. It is a common and much needed part, we shouldn't have to scrounge for it. If one of our vendors can make a few bucks and make some customers happy, great. I have my own supply covered for now.
Mark
skills@eurocarsplus wrote: |
kamzcab86 wrote: |
o/p...
would you like the tool p/n and the pin p/n as well? because I love to breastfeed info to guys that just don't want to listen.... |
thatvwbusguy Samba Member
Joined: April 18, 2007 Posts: 1712 Location: Newmarket, New Hampshire
Posted: Sat Sep 22, 2018 3:50 am Post subject: Re: Vendors please help, we need this 2 pin connector! |
I will see if I can source the connector. I'm thinking that a repair kit with a 6" pigtail and a couple heat shrink butt connectors would be the way to go.
Mark, please PM me some specs and I will see what I can find. _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sat Sep 22, 2018 8:39 am Post subject: Re: Vendors please help, we need this 2 pin connector! |
Attaboy, Jay...our new favorite!
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Sat Sep 22, 2018 9:24 am Post subject: Re: Vendors please help, we need this 2 pin connector! |
Connector sourced. Now the wait for samples to come in begins.. _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
Posted: Sat Sep 22, 2018 2:51 pm Post subject: Re: Vendors please help, we need this 2 pin connector! |
Zeitgeist 13 wrote: |
Don't be your usual jackass. This was a legit request to the vendors for a legit part that frequently needs attention. |
yes....usual jackass....who said call vw, get the connector and pigtail
the repair wires have the ends crimped right on them. no need for anyone to waste time trying to make them...or try to sell them. you'll be in and out of the dealer for <10.00
so to sit there and spend the time to do it, market it, and try to make any money is a losing proposition...
so why bother making them when you can open 2 bags, cut the repair wire in 1/2 and clip it into the connector? takes 2 seconds...
work smarter....not harder
and....here is a nifty little vw fun fact... all repair harnesses are yellow to show they have been repaired at one point. #themoreyouknow
jackass or helpful? you decide....
with love,
skills _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Sat Sep 22, 2018 4:25 pm Post subject: Re: Vendors please help, we need this 2 pin connector! |
The local VW dealer list price for the parts to make the pigtail with boot is $29, with tax $31
For that I get to drive 15 minutes each way, order it, come back a few days later.
Or I can mail order it from that local dealer for another $10 shipping making it $41
In either case if I am not positive of the part numbers needed it may take some time for them to look them up for my 35 year old van. If wrong, then what, try again, eat them?
I can find it for a little less on the web from distant VW dealers who discount.
I also have a pile of those yellow wired VW repair pins like in your photo. Had most of them many years, waiting for a sudden need, most will never get used. Some of them now cost close to $30 for a single wire with 2 ends.
Mark |
Posted: Mon Oct 15, 2018 6:31 pm Post subject: Re: Vendors please help, we need this 2 pin connector! |
Repair connector kits are now available for $8.50 including shipping via First Class Mail in the US. I have about a dozen currently in stock and more on the way.
Kit includes beveled connector with 10" wires and a pair of Molex PermaSeal butt connectors with heat shrink and internal adhesive.
I have the following wire colors in stock and can set them up with whatever color combination you would like: Red, Black, Yellow, White, Brown, Green, Purple, Blue, Orange, Pink, Light Green, Tan, Grey.
Payment via PayPal to [email protected] _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
