rocket280 Samba Member
Posted: Sat Sep 22, 2018 8:29 am Post subject: low light air vent mesh |
Does anyone reproduce the mesh that goes in the front nostril on low lights, not the basket but the mesh made up of rectangles. I was going to draw it up and have it laser cut but wondered if anyone had already done it.
cheers Jason
Braukuche Samba Member
Posted: Sun Sep 23, 2018 8:57 am Post subject: Re: low light air vent mesh |
Hi Jason,
If you have one made can you have two done? I am missing one as well. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
c21darrel Samba Member
Posted: Mon Sep 24, 2018 11:43 am Post subject: Re: low light air vent mesh |
Those are for later Ghia, but I wonder if they can be cut down to fit lowlight nostrils? Height being the concern.
Also, how do they install? Does the grill hold them in place? _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
xzener Samba Member
Posted: Mon Sep 24, 2018 5:24 pm Post subject: Re: low light air vent mesh |
Should be easy enough to simply make your own. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Mon Sep 24, 2018 9:21 pm Post subject: Re: low light air vent mesh |
simple if you have the correct mesh, but so far I have not seen anything that is right. I guess if someone had already made them It would have been posted here by now. |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13957 Location: Southampton U.K.
d5626 Samba Member
Joined: December 09, 2008 Posts: 154 Location: Pomona
Posted: Tue Sep 25, 2018 4:19 pm Post subject: Re: low light air vent mesh |
Braukuche wrote: |
Also, how do they install? Does the grill hold them in place? |
I'm pretty sure I've cut some down to size in the past from the later/larger mesh. I dont have any of the newer mesh to measure though. |
CalifornianClassics Samba Member
Joined: August 22, 2019 Posts: 2 Location: St Leonards-on-Sea, East Sussex, UK
