Zar Samba Member
Joined: July 19, 2018 Posts: 42 Location: San Diego, CA
Posted: Mon Sep 24, 2018 7:30 am Post subject: Doghouse Conversion |
I am converting my 1600 SP (1970 B6 case) over to a doghouse oil cooler. I have obtained all the parts necessary for the conversion except the oil cooler stand and the nut insert for the engine to trans mounting bolt.
For the oil cooler stand, should I source a used VW original stand or aftermarket? Does it even matter?
Where can I find the nut insert for the case?
Thanks. _________________ 1968 Beetle 1600 SP |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Mon Sep 24, 2018 7:41 am Post subject: Re: Doghouse Conversion |
Zar wrote: |
Engine Case Nut Insert Captive Nut press-in nut
https://www.wolfgangint.com/store/product/engine-case-nut-insert-111199102/
Part #111 199 102
This captive nut came on all dual relief cases. This is because with a doghouse cooler it is near impossible to get a nut off or on once the engine is in unless you add the small shroud tins afterwards. If you're putting a dual relief case on a transmission that took a single relief case, make sure you grind off the locking boss for the bolt on the clutch arm side before you put the motor in. Be careful not to crack the case when installing. Rig up a pipe that has a notch to match the notch on the flywheel side of the case. Draw the nut into the case with a bolt. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Zar Samba Member
Posted: Mon Sep 24, 2018 7:52 am Post subject: Re: Doghouse Conversion |
Awesome thank you.
My B6 case is from a 1970 bug and is dual relief but does not have the nut insert because it was pre doghouse. _________________ 1968 Beetle 1600 SP |
