hemifalcon Samba Member
Joined: June 15, 2005 Posts: 1481 Location: Union Grove, WI
Posted: Mon Sep 24, 2018 6:03 pm Post subject: I need help ID’ing an Oval body-possibly a split turned oval? |
I’m attaching pictures of this find.. the body I believe tells me it’s a ‘50–but the oval window opening wasn’t too deeply investigated. Possibly a grafted oval into a split body? The failed headliner material was definitely not original. Before parts come off-I may want to collect it intact if any experts believe its an early body.
Body number is 141811, engine number 405754.. I’m working on owning it.. it’s been in the woods in Wisconsin a long time-it needs real help. I didn’t get inside to see the pan numbers.
_________________ '62 VW Bug Sedan (Ruby Red)
Resto pics> http://smg.photobucket.com/albums/v697/hemifalcon/Bug%20resto/?start=all&paginator=top |
hm Samba Member
Joined: October 12, 2005 Posts: 191 Location: Whittier California
Posted: Mon Sep 24, 2018 6:15 pm Post subject: Re: I need help ID’ing an Oval body-possibly a split turned oval? |
looks to be a 56 or 57 |
sled Samba Member
Posted: Mon Sep 24, 2018 6:55 pm Post subject: Re: I need help ID’ing an Oval body-possibly a split turned oval? |
January of 1956 _________________ drive your split. |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Mon Sep 24, 2018 7:24 pm Post subject: Re: I need help ID’ing an Oval body |
I concur, 1/1956 -
Some reasons: Has a late oval SEMI-BATWING steering wheel and post 1954 chrome trim around the ash tray - interior handles are not ribbed - looks to have a pretty typical red interior... all splits, even 1952-53 Zwitters had a push button to start - this car has NEVER been a split... also. all splits had semaphores.
A 1950 dash is completely different - KDF style -
... '50 dash
_________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Posted: Mon Sep 24, 2018 8:18 pm Post subject: Re: I need help ID’ing an Oval body |
ZENVWDRIVER wrote: |
I concur, 1/1956 -
... '50 dash
It’s sort of what I thought and I was taking a stab at trying to interpret the body and engine numbers.. _________________ '62 VW Bug Sedan (Ruby Red)
Blue Baron VW Aficionado
Joined: June 16, 2006 Posts: 24131 Location: Southeast USA
Posted: Mon Sep 24, 2018 8:28 pm Post subject: Re: I need help ID’ing an Oval body-possibly a split turned oval? |
Also no ribs on the doors, curved shifter, smooth door handles, etc. Definitely an oval.
Love the accessory passenger-side sun visor. _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
jason Samba Member
Posted: Tue Sep 25, 2018 11:03 am Post subject: Re: I need help ID’ing an Oval body-possibly a split turned oval? |
Bullet fenders with non ribbed doors is definitely 56-57. Look for date on back of speedo. |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Tue Sep 25, 2018 11:32 am Post subject: ID’ing an Oval body-possibly a split turned oval? |
A couple more items that would be seen on a late ('56-'57) oval . . .
Front, footwell heater outlets (in the heater channels) are louvered . . . not screen-covered "holes" as found in an early Oval.
Door latch strikers similar to '60s era Beetles (in the "B" pillars) . . . NOT interchangeable between early Ovals and late Ovals.
This is a 1956, "non-adjustable" striker plate (photo from TheSamba Gallery) . . .
Here's a later (1957-up) "adjustable" striker plate . . . (photo from TheSamba Gallery) . . .
Look at these "early Oval"/Split strikers and you will see that they cannot be easily swapped . . . https://www.thesamba.com/vw/classifieds/pix/3310641.jpg _________________ Jesucristo es mi Señor y Salvador!
Posted: Tue Sep 25, 2018 12:04 pm Post subject: ID’ing an Oval body-possibly a split turned oval? |
Found a couple more photos in TheSamba Gallery showing the differences between "Early Oval" and "Late Oval" heater channels . . .
EARLY Oval (pre-1956)
1956 & very-early1957 (note the position of the louvered opening: forward towards the front panel)
late 1957 & later (note the position: back towards the hinge pillar)
_________________ Jesucristo es mi Señor y Salvador! |
h~moto Samba Member
Joined: November 19, 2008 Posts: 317 Location: Northern Virginia
Posted: Tue Sep 25, 2018 5:51 pm Post subject: Re: I need help ID’ing an Oval body-possibly a split turned oval? |
Quote: |
I was taking a stab at trying to interpret the body and engine numbers |
If you look at the numbers chart, you can see that the body numbers reset to 000001 in July of 1955. So body number 141811 can fall into two different time periods. People are concluding that it is the later time period by looking at the details in the pics. |
Posted: Tue Sep 25, 2018 6:16 pm Post subject: Re: I need help ID’ing an Oval body-possibly a split turned oval? |
h~moto wrote: |
I can understand the reasoning and information shared would seem confirmatory of a later oval. _________________ '62 VW Bug Sedan (Ruby Red)
Busstom Samba Member
Joined: November 23, 2014 Posts: 3853 Location: San Jose, CA
Posted: Sat Oct 13, 2018 9:46 pm Post subject: Re: I need help ID’ing an Oval body-possibly a split turned oval? |
hemifalcon wrote: |
...where do I find the info to confirm what you’re telling me-and to possibly prove to the current owner? |
In case you hadn't discovered it yet, right here: https://www.thesamba.com/vw/archives/info/bugchassisdating.php |
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 1326 Location: Norway
Posted: Sun Oct 14, 2018 12:59 am Post subject: Re: I need help ID’ing an Oval body-possibly a split turned oval? |
The body is produced in January 1956, according to theSamba's list. _________________ I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438 |
