veeweeman Samba Member
Joined: December 20, 2009 Posts: 940 Location: New Port Richey, FL
Posted: Tue Sep 25, 2018 1:00 pm Post subject: Kellison T Roadster? T Bucket buggy?...not sure? |
Hey! ...I'm so damn excited to share my new project I just scored!
I got this buggy from the same guy that I purchased the Fiat from...it has a 1959 title and it still uses the stock VW heater so cold winter driving is still available, how cool!
So, if you follow my Fiat buggy build then you know that I built a really nice 2234 aluminum block engine with dual Dellorto's and since going to a TDI power plant with the Fiat, I had no home to shove the 2234 into until now!...it's a Kellison T Roadster I believe but not 100% sure. ..I couldn't find anything on the DBA site that looks like mine. ...it is a PITA to get in and out of cuz the steering wheel doesn't come off...so I have a lot of plans to make this T-Roadster more enjoyable to drive...with out further a due.
So, my plans for the 175 HP wheelie machine;
Strictly only street
New rims with wide street tires on all 4 corners
4" narrowed front balljoint front beam
Raise the rear transaxle 2"s, or maybe a IRS conversion
New adjustable pedals cuz my knee hits the dash reaching for the clutch, the PO was shorter than me.
Now believe this!...this body is sitting on a 1" body lift!...that's how low this car sits on the pan...I may have to redo the seats or lower the floor pan seat area...you sit kinda upright and I want a more laid back seat...also, to get in you have to lift up the top from the rear. ..it's hinged at the front of the windshield and has a funky hydraulic mechanized lever that controls a hydraulic cylinder that holds the top up until you release the lever...don't like it but love the overall look of the car. ..I do like the coverage from the sun with the top though...if the top was fixed in place it would be impossible to get in or out...the top will need a lot of glass work to fix and look right...I just need to find another method to holding it up while entering and existing. ..any thoughts?
Thanks for looking 😆 _________________ Never be a follower...Do your own thing, make it your own! |
Posted: Wed Sep 26, 2018 3:52 pm Post subject: Re: Kellison T Roadster? T Bucket buggy?...not sure? |
So no one here knows this body from Kellison? _________________ Never be a follower...Do your own thing, make it your own! |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Wed Sep 26, 2018 4:54 pm Post subject: Re: Kellison T Roadster? T Bucket buggy?...not sure? |
Try search for "Kellison Super T", seems possible...
https://www.google.com/search?q=kellison+super+t&a...G7P-jiN0M:
Posted: Thu Sep 27, 2018 3:38 pm Post subject: Re: Kellison T Roadster? T Bucket buggy?...not sure? |
Thanks Dale but my DBA search didn't find any matches with a dash that looks like mine
From what I can find on Google, the company started up in 1969 (ball joint Era) which is why the kingpin front end was shortened to clear the body. ..it has huge spider cracks where the body has been rubbing on the LP front end, my plan is to install a BJ for better clearance and maybe narrowed a few inches for wider front tires. _________________ Never be a follower...Do your own thing, make it your own! |
Posted: Thu Sep 27, 2018 3:44 pm Post subject: Re: Kellison T Roadster? T Bucket buggy?...not sure? |
Dale, you rock!
I clicked on the link you provided and I now know what Kellison I have. ..it's called a "Super T"
Thanks
VeeWeeman _________________ Never be a follower...Do your own thing, make it your own! |
Posted: Sat Sep 29, 2018 6:26 am Post subject: Re: Kellison T Roadster? T Bucket buggy?...not sure? |
If you look at the third pic you can see a boat style filler cap...when you open it to fuel up the cap hits the luggage rack and this makes it difficult to fuel up...so my thoughts are to relocate the fuel tank (probably custom made over and along the tunnel length) and relocate the filler to the nose of the car...my ideal is to make it look like a radiator fill and maybe a small ornament on the cap cuz I believe that the front of the T looks a little plain and boring...I was thinking about using aluminum along with walled baffling for fuel sloshing during take off. ..the tank dimensions would be the same width as the tunnel and just tall enough to fit under the body.
By removing the tank in the rear it would allow me to raise the swingaxle up in the rear to lower the car without getting negative camber, win, win!
Thanks for following _________________ Never be a follower...Do your own thing, make it your own! |
Posted: Sat Jan 12, 2019 7:37 am Post subject: Re: Kellison T Roadster? T Bucket buggy?...not sure? |
Life always gets in the way. ..now I have to sell my buggy to help finance my other projects. ..the good news is that I get to build another motor. ..my best friend has a older single relief case that is in excellent condition, tight end play on the crank and very little side play on the rods...I'm going to build a Amazon 1641, meaning that I will be sourcing all my parts through Amazon. ..supplier's are empi, Appletree, AA and a few others. ..I will be also installing a set of 34 dual carbs to help with a little more power and maybe it will help me attract the right buyers that doesn't want a boring stock looking motor. ..as much as I really wanted to keep the car I already have too many. ..I will be back home around the first week of March. ..until then, keep driving those buggy's. _________________ Never be a follower...Do your own thing, make it your own! |
mark tucker Samba Member
Posted: Wed Jan 30, 2019 1:59 pm Post subject: Re: Kellison T Roadster? T Bucket buggy?...not sure? |
I kinda like it!! |
