Burlyhammer Samba Member
Joined: March 07, 2002 Posts: 1693 Location: Great north woods Maine
Posted: Mon Jan 07, 2019 10:33 am Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
Wow, you are showing no fear, and tackling some very intimidating areas. I hope no one ever has to detach the cross member, top hat, and outriggers to relocate. I am sure I will never do it again...
How is the spot welder? I want to get myself one some day (hopefully sooner than later!)
Keep up the great work. Your bus appreciates you! |
Navydave73 Samba Member
Joined: March 09, 2017 Posts: 414 Location: Alta Loma/Los Angeles
Posted: Mon Jan 07, 2019 7:16 pm Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
schnidlee wrote: |
You're doing a great job mate. Considering you are doing this all at home and your time is free I would highly recommend stripping all the KF green primer off and priming the new panels with a quality primer, I even paint the insides of any cavities with some rattle can enamel to prevent future rust. The KF primer is apparently just for shipping and not meant to be left on. I have stripped parts previously and found surface rust under the paint so definitely worth doing. Keep up the good work. |
Thanks for the advice. Roger, Wilco!!! |
Posted: Mon Jan 07, 2019 7:18 pm Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
Burlyhammer wrote: |
I read every word of your thread, that looked like a royal pain having to cut out all those welds....thanks again.
I like the spot welder, it is the 110v version. We used it on the bug pan jack points also. I think the weatherstrip channel looks really close to factory. I though about getting a couple of ground rods and making longer copper rods for big reach......but just thinking. |
Posted: Wed Jan 16, 2019 9:44 am Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
This is what’s left of the long wall vertical reinforcement pillars.
Again, i tried to leave as much OG metal as possible for a guide to make sure that i got them in the right place.
Replacement Auto Craft pieces from WW
Cutting out, trying to take my time with the cutoff wheel and plasma torch
Reference picture of the little L-shaped piece that goes from the vertical pillar to the top of the new floor. I thought i read somewhere that this was an early bus thing or 59 only??? There is no trace of the first pillar...is it only the rear or both? Or all 3????
Posted: Wed Jan 16, 2019 9:48 am Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
I ran out of SEM Copper Weld, bough another brand at the paint shop. I cant tell the difference, this one is pink...that’s the only difference i can tell. Mastercoat on all the non-weld surfaces and copper weld on the weld surfaces.
The screws that held the latch plate had been replaced by 4” screws that went all the way through the B pillar so i bought these from WW. The heads were too large for the recesses in the latch plate so i made a Hill Billy Lathe. Chucked the screws up in my drill and spun the drill while grinding with my cutoff wheel. Good enough for government work.
Posted: Wed Jan 16, 2019 9:50 am Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
Final fit of screws
Ready for the long wall next!! I will be replacing the top hats at the rear of the bus, the OG ones are too nasty.
Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
Posted: Wed Jan 16, 2019 12:27 pm Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
Nice build.
Way to dig right in.
I keep seeing this video playing in my head when I look at all of that.
Don't they just make it look so easy?
_________________ Bus Motor Build
What’s That Noise?!? |
Posted: Wed Jan 16, 2019 12:31 pm Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
Clatter wrote: |
Nice build.
Yeah, i looked into that...it ain’t cheap. They wanted $1500 for Soda Blasting with me taking it in. Ive heard the mobile wet blast is more than that. But i can buy a wet blaster for $5,000!!!! |
Posted: Wed Jan 16, 2019 12:40 pm Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
Ya, have seen so many ads about buying the equipment or a franchise, even..
It's kind of like vapor blasting,
There's been three people come and go in that arena in the last couple of years.
It seems like it would be fun/rewarding,
And maybe on your own project it might be,
But,
Dag,
After about three cars how bad would you hate it?
Maybe you could buy the rig, do a car or two, then sell it on?
Maybe even buy a used one to start with?
How sweet would it be if we had an official Samba wet-blasting rig you could either buy and sell on for close to what you paid,
or maybe rent it?
Group buy?
Posted: Mon Jan 21, 2019 6:52 pm Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
A couple reference photos for how far the shifter tube sticks out... 1/2” or 12.7mm according to my metric tape measure
Another pile of rusted metal cut out. The rear top hats.
Posted: Mon Jan 21, 2019 6:55 pm Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
The left over sheet metal that i used for the divider wall was almost a perfect fit for the rear tophat middle section.
Posted: Mon Jan 21, 2019 7:00 pm Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
The bottom two reinforcement pillars are completely rotten. I think i can save the top, smaller profile reinforcement, but not the bottom two. WW sells an Auto Craft replacement for these but it looks like a lot of work. They need to be clearanced around each of the vertical reinforcement pillars, not to mention the 1/2” crimp every so often. Doesn’t there need to be a short vertical for the door panel to slip over for the rear seat armrests?
I have searched and didn’t find anyone replacing the entire long wall like i plan to. Surely someone has done this before. I will take a lot of pictures if there isnt any documentation yet.
Any suggestions for removing the top of the long wall without trashing the inner structure? My spot welder wont reach, so i plan to plug weld. |
Posted: Mon Jan 21, 2019 8:06 pm Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
This is the stamping I’m talking about, how do i recreate this?
Looks to be about 1/2” |
Posted: Mon Feb 25, 2019 4:42 pm Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
Peeling away the remainder of the long wall at the top where it is spot welded to the window panel.
Posted: Mon Feb 25, 2019 4:45 pm Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
Long wall reinforcement pieces from WW (AutoCraft UK) don’t have the cutouts for the vertical pillars. I measured the one that was removed and came up with a cardboard template. Not the most beautiful thing, but good enough to hide with door panels. The cuts where with simple hand shears.
Posted: Mon Feb 25, 2019 4:50 pm Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
The old, handy dandy Harbor Freight hole punch/panel flange tool helped me get the reinforcement rails to sit flush to the wall
Everything mocked up and looking beautiful
Welded in place. We used the hole punch on the reinforcement pillars and did plug welds. My son pushed on the outside while i plug welded on the inside.
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9790 Location: Exit 7, New Jersey
Posted: Mon Feb 25, 2019 9:56 pm Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
I have to comment here.
When I saw this thread months ago, you posted this photo of the first thing you did when you got this bus home:
And I thought: "This bus is a HUGE rust restoration project, and THIS is what he does first?"
I just saw this project as a potential disaster!
But! Boy was I wrong!!!
You are killing it, congrats on all the fine work you are doing.
Easy to see you're gonna do this rustbucket justice!!!
Keep it up! _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Posted: Mon Feb 25, 2019 10:54 pm Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
j.pickens wrote: |
Keep it up! |
Now that’s funny! Same thing my wife said, polishing a turd. Long way to go but I hope to be in paint by the end of the year. |
type2rescuemaine Samba Member
Posted: Tue Feb 26, 2019 5:27 am Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
Way to go. That long panel looks amazing!!! |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14266 Location: Casa de Oro, California
Posted: Tue Feb 26, 2019 12:28 pm Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
Yeah ^^^^. I think that's the first time someone has posted up the whole enchilada side attachment. What a feat. |
