Jason37 Samba Member
Posted: Mon Jan 07, 2019 7:01 pm Post subject: Re: 63 Birchgreen notch |
KTPhil wrote: |
What are the odds?
What would be the odds of having three Birchgreen titles threads at the top of the Samba... |
Posted: Fri Jan 18, 2019 11:16 pm Post subject: Re: 63 Birchgreen notch |
Not really anything exciting going on, just the drudgery of getting years of grime cleaned off.
First the transmission
The inspection cover weighed in at about 5lbs
Yes that is about 3/4” of grime on the top of the transmission.
After it was partially cleaned...at least clean enough to remove the axle tubes
With it all cleaned I probably had about a ten pound weight reduction, which means my top speed will likely be close to 300😂😂😂
And some brake action
And a little request for some help. I am desperately in need of both pinwheel rear drums. Mine are out of spec, and I need to have the car inspected prior to getting it registered. I have posted a wanted ad, but can’t hurt to ask here as well. |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7537 Location: Santa Cruz
Posted: Sat Jan 19, 2019 8:34 am Post subject: Re: 63 Birchgreen notch |
Archaeology!
Let's hope someone can dig deep into their treasure stash and come through for you...!
You know there has to be a guy reading this who has a couple of pinwheel drums that is never going to use them. _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Sat Jan 19, 2019 9:05 am Post subject: Re: 63 Birchgreen notch |
Clatter wrote: |
Archaeology!
You know there has to be a guy reading this who has a couple of pinwheel drums that is never going to use them. |
A guy? There is probably a couple using them as a door stop and a paperweight! But I have a plan in place if I can’t find them...
Plan A - find them
Plan B - find someone to reline them (356 guys do it, but they are aluminum) has to be a certified shop as the receipt has to be included with the inspection.
Plan C - use 64-65 parts
Plan D - four lug conversion or disc brakes all around.
Plan E - sell it to the guy who has been using them for a doorstop and paperweight!!
I should mention I have tried the usual suspects, ISP West, The Samba, Instagram (both mine and VW trader) Joel and reached out to host of SoCal club guys. As for the web, things get very dark at 1:30 and about forty pages back in the google machine when you think you’ve found them in a German site, after a half hour translating finding out they don’t. 😢 |
bally Samba Member
Joined: April 29, 2006 Posts: 1182 Location: Melbourne, Australia
Posted: Tue Jan 22, 2019 12:29 am Post subject: Re: 63 Birchgreen notch |
What's a pinwheel rear drum? Clearly a rear drum, but why pinwheel? |
Posted: Tue Jan 22, 2019 7:39 am Post subject: Re: 63 Birchgreen notch |
bally wrote: |
Pinwheel refers to the center section of the drum. On early cars 61-63 they used pinwheel drums, on 64-65 cars they used a star center. Another neat fact, is the early rears are smaller, (230mm vs 248mn) so swapping just drums over doesn’t work.
Here are some pics that show the difference.
Pinwheel
Star
bally Samba Member
Posted: Tue Jan 22, 2019 2:40 pm Post subject: Re: 63 Birchgreen notch |
Thanks for the education 😊 I have the pinwheel drums on my 63 , which I knew was correct, but I was unfamiliar wth the name. Now I know. Every day is a school day! Thanks, Dave |
Posted: Sat Feb 02, 2019 11:02 pm Post subject: Re: 63 Birchgreen notch |
So drums have been located and should be here this week. More parts have arrived at the border, so Friday I will make the trip south to retrieve it. The wheel cylinders have arrived from Sweden and the first batch of powder coating is done.
Lost a couple weeks due to the flu and a chest infection, but managed to get the axle tubes prepped and the rear subframe out, they will go to the powder coaters on Monday. Going to let them blast the subframe as it’s finally decided it was winter here and got real cold, so the ublast place is down.
With luck the next update will have some reassembly pics. |
Posted: Sat Apr 06, 2019 10:07 am Post subject: Re: 63 Birchgreen notch |
Sorry for my laziness in keeping this thread updated, but work has been commencing and soon it will be ready for the road.
Transmission cleaned.
Nosecone machined for later bushing
Case painted and axle tubes installed
And how do I love original hardware!🥰
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sat Apr 06, 2019 11:50 am Post subject: Re: 63 Birchgreen notch |
DORN could be short for DORMAN? _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22413 Location: Kimball, Mi
Posted: Tue Apr 09, 2019 8:38 pm Post subject: Re: 63 Birchgreen notch |
Bobnotch wrote: |
That trans cleaned up real nice. Looks good. Keep up the good work. |
Thank you sir. Trying to build the bottom as clean as I can. |
Posted: Tue Apr 09, 2019 8:48 pm Post subject: Re: 63 Birchgreen notch |
Front brakes and beam are in. Too bad I got the shock colours reversed and ordered red oil filled for the front and black gas adjusts for the rear.🤦♂️
The brake assembly went together well, used NOS aftermarket cylinders that I sourced from Sweden and refurbished the hardware
Luckily the front drums are within spec, don’t worry, bearings weren’t adjusted yet, so that is why the tabs aren’t bent over.
Was going to machine a longer M12 stud to mount my dial gauge to, just like the factory tool, but then realized my center caps are a pain to remove. Instead I used a piece of 2” angle iron the same width as the tire bolted to the drum to check wheel bearing play. Which of course I didn’t get a picture of, so you get this one of the dial indicator and magnetic base attached to the drum.
notchboy Samba Member
Joined: April 27, 2002 Posts: 22450 Location: Escondido CA
Posted: Wed Apr 10, 2019 2:38 pm Post subject: Re: 63 Birchgreen notch |
Love this build..
Gotta feel good to get all of that stuff sorted and together.
Do i detect a preemptive undercoating removal job started?
Looks like you cleaned out all of that stuff where the beam might interfere.. _________________ Bus Motor Build
Posted: Wed Apr 10, 2019 8:56 pm Post subject: Re: 63 Birchgreen notch |
Clatter wrote: |
Love this build..
Looks like you cleaned out all of that stuff where the beam might interfere.. |
Not at all by me. That’s where is had just fallen off over time! My main goal is to get it on the road this year and tackle the undercoating, small rust issues and fender repaints next year. Summer up here is short, and I think if I turn it into another long term project, my wife will kill or divorce me...
Which leads to an interesting bit of history, I have managed to track the last four owners, and three of them have had to move the car due to divorce. So I am treading carefully. |
Posted: Wed Apr 10, 2019 8:57 pm Post subject: Re: 63 Birchgreen notch |
notchboy wrote: |
Good to see you found brake components. Looks good. |
It was Mario at T3HQ that came to the rescue! His mate had an NOS set that he was will to pass on. |
Posted: Wed Apr 10, 2019 9:04 pm Post subject: Re: 63 Birchgreen notch |
Jason37 wrote: |
notchboy wrote: |
Good. Keep his info _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Wed Apr 10, 2019 9:19 pm Post subject: Re: 63 Birchgreen notch |
notchboy wrote: |
Jason37 wrote: |
notchboy wrote: |
Good. Keep his info |
Yes! I need one piece of trunk liner, that I’ve been meaning to hit him up for. |
pitargue Samba Member
Posted: Thu Apr 11, 2019 8:45 am Post subject: Re: 63 Birchgreen notch |
Nice! Damn, I should of clear coated my transmission while it was out... |
