BYeaton Samba Member
Joined: November 27, 2007 Posts: 362 Location: El Segundo
Posted: Wed Sep 26, 2018 2:21 pm Post subject: Delrin beam bushings on the street |
I have done LOTS of reading into the needle bearing vs urethane vs delrin argument. I'm looking for some real world feedback or advice please:
I have a 70 Bay with a 4" narrowed beam, which happens to be equipped with the red urethane bushings. I am aware that the needle bearing beams usually ride the best/ are the quietest/are most robust since it is a stock design. The front end of my bus squeaks A LOT. Greasing has done nothing for me so I'm looking for alternatives.
I understand that to install needle bearings, the beam would have to be reamed and fitted, etc which seems costly and very labor intensive. Probably not worth it. In hindsight, I would have loved to buy a needle bearing beam but this is what came in the bus and it is what it is.
The other option I came across was using Delrin (or even UHMW) bushings to replace the urethane. Has anyone ran delrin bushings on their beam on the street? Most of the info I find on this site shows them in offroad scenarios. I know Airkewld uses them in their beams, anyone from that camp give feedback?
I'd love to find a solution to make the ride smoother and quieter.
Any opinions on this would help. Thanks in advance. |
VWsArent4Hippies Samba Member
Joined: April 13, 2005 Posts: 3079 Location: The Bull City
Posted: Wed Sep 26, 2018 2:29 pm Post subject: Re: Delrin beam bushings on the street |
I don’t believe anyone is making delrin balljoint bus bushings _________________
aeromech wrote: |
in my opinion you don't know shit |
Posted: Wed Sep 26, 2018 2:38 pm Post subject: Re: Delrin beam bushings on the street |
VWsArent4Hippies wrote: |
I don’t believe anyone is making delrin ball joint bus bushings |
You may be right. If they aren't available, I guess I'm chasing whether it would be worth it to make a set out of Delrin or UHMW to replace the urethane?
Any thoughts on the comparison of the materials themselves as a bushing? |
Posted: Wed Sep 26, 2018 2:40 pm Post subject: Re: Delrin beam bushings on the street |
I’ve used delrin in beetles before, it works fine. Are the ones you have actually urethane? What brand are they?
Wagens West uses their own blend and they work well _________________
aeromech wrote: |
Posted: Wed Sep 26, 2018 2:45 pm Post subject: Re: Delrin beam bushings on the street |
Wagens West uses their own blend and they work well |
The bushings are from Wagens West, but the beam is not theirs. The beam builder sourced the bushings from Nate. |
Posted: Wed Sep 26, 2018 3:29 pm Post subject: Re: Delrin beam bushings on the street |
BYeaton wrote: |
How old are they? Are they just worn out? Grease zerk holes drilled through the bushings? _________________
aeromech wrote: |
Posted: Wed Sep 26, 2018 3:34 pm Post subject: Re: Delrin beam bushings on the street |
BYeaton wrote: |
How old are they? Are they just worn out? Grease zerk holes drilled through the bushings? |
New beam installed in March as I understand. I haven't disassembled to see but I hope there are through holes in the bushings. |
Posted: Thu Sep 27, 2018 8:23 am Post subject: Re: Delrin beam bushings on the street |
Anyone else have experience with this? Maybe I should post in the type 1 forum where people may have used delrin more often? |
framed Samba Member
Posted: Thu Sep 27, 2018 11:40 am Post subject: Re: Delrin beam bushings on the street |
I made my own narrowed beam last year of orig bay beam.
Because year 2017 we had new bearing solutions
(and I am mechanical engineer)
had to try something I used on my work related designs.
SKF filament wound bearings. Maintenance free.
Inner diam = bearing surface was standard, outer diam. needed some
lathe work to fit beam.
5000 miles now testdrive behind. Quiet and smooth. |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Thu Sep 27, 2018 11:52 am Post subject: Re: Delrin beam bushings on the street |
I know it isn't a Bus, but years ago I installed the red urethane bushings in the front suspension of my VW Corrado.
It squeaked and was kind of annoying for a while, but they "wore in" or whatever and after a little while, for whatever reason, they did stop squeaking.
Perhaps all you need to do is turn the radio up for a couple months of driving and they'll quiet down, too! _________________ Dave Cook
1973 Wild Westerner
My Thing |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Thu Sep 27, 2018 1:34 pm Post subject: Re: Delrin beam bushings on the street |
I just replaced the beam bushings in my '78 double cab with delrin ones, but there are 0 miles on these so far. Maybe check back with me in a year or so.... _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Posted: Thu Sep 27, 2018 1:35 pm Post subject: Re: Delrin beam bushings on the street |
framed wrote: |
5000 miles now test drive behind. Quiet and smooth. |
Very interesting and cool to play around with new materials like that. A quick google image search showed me the material resembles a woven polymer resembling graphite almost? Is this material harder than delrin? So if I understand, the ID of the bushings matched the OD of the arms, and the OD of the bushings need to be press fit into the beam tube correct? Any pictures by chance? Thanks for the reply! |
Posted: Thu Sep 27, 2018 1:36 pm Post subject: Re: Delrin beam bushings on the street |
vwwestyman wrote: |
Perhaps all you need to do is turn the radio up for a couple months of driving and they'll quiet down, too! |
Right, that is a very different animal as those cars have a A-arm style suspension correct? I can't stand the squeaking, I'll have to solve the problem! |
Posted: Thu Sep 27, 2018 1:37 pm Post subject: Re: Delrin beam bushings on the street |
jtauxe wrote: |
I just replaced the beam bushings in my '78 double cab with delrin ones, but there are 0 miles on these so far. Maybe check back with me in a year or so.... |
Ha! Very good, I will. Did you make them yourself or source them? Care to share any info on the install? Thanks for the reply! |
Posted: Thu Sep 27, 2018 1:40 pm Post subject: Re: Delrin beam bushings on the street |
BYeaton wrote: |
vwwestyman wrote: |
Correct, A-arm style. My thought was that just as mine quieted down after a little time, yours might too! _________________ Dave Cook
1973 Wild Westerner
My Thing |
framed Samba Member
Posted: Fri Sep 28, 2018 6:33 am Post subject: Re: Delrin beam bushings on the street |
BYeaton wrote: |
SKF Bushing was size 50x58x40wide. 50mm iis OD on ARM. Beam ID is about 56mm. |
raygreenwood Samba Member
Posted: Fri Sep 28, 2018 7:16 am Post subject: Re: Delrin beam bushings on the street |
Delrin....or more specifically glass filled Delrin would be good. But....in the long term Delrin has some issues with some of the by-products of grease break down. But for the more readily available materials....it should do ok.
Bear in mind that Delrin is not actually a bearibg material.....so if it gets dry before you can get around to greasing it....it will wear. Its also brittle and crack prone is very cold weather. The glass filled variety....less so.
Urethane.....is not useful for this area. In roughly 5 years it will have increased hardneas by about 15-20% and will shrink about 3% and will at this point start being attacked by grease by-products. As hard as these parts are to reach.....do you want to be doing this again in 5-7 years?
The SKF filament wound bearings are glass fiber with a PTFE cast inner surface.....and epoxy resin (there are some carbon fiber variants on thr market but that is not needed here).
While these would be excellent.....I would be wary of anything using epoxy as the resin. All of them can have age issues and issues with oils that leach out of the grease. I have used this type of bearing in numerous printing presses as precision rod guide bearinga. Very nice....but they do wear out.
UHMW would be very nice but make sure its the harder, cast machineable variety.
If your budget is good....the ideal material would be Torlon 4301.....which is bearing grade. This has a constant temp range of a little over 500°F....is chemically inert up to nitric acid.....is graphite filled....has a coefficent of friction only a few percent lower than Teflon and is about 10-15% harder than delrin. Very machineable.
This is the material Igus uses for bearings. I use them to replace the needle bearings on the coujyer shaft in 004 transmissions. But its pricey.
A piece of rod stock big enough to make about 8 bushings this large would be in the $330 range.
A company like Igus may have some pre-made bushings close to size that can be turned down. Ray |
