Vanagon Nut Samba Member
Posted: Fri Sep 28, 2018 11:15 am Post subject: Dealership Servicing VR EVC? |
Hi folks.
In general, have folks with VR6 EV or EVC's found that VW dealerships were willing, able and competent regarding servicing these vans?
I'm assuming that like the Vanagon, a dealership might be quite hesitant to work on an early model EV. No dis those models!
Thanks
1988 West DIY 50º ABA
VE7TBN |
Zeitgeist 13 Samba Member
Posted: Fri Sep 28, 2018 12:03 pm Post subject: Re: Dealership Servicing VR EVC? |
I can't speak for my own personal experience, but I bought mine from the original owners and they had always had it serviced by the dealer in Seattle. I believe VAG still produces versions of the VR6 in VWs, Audis and Porsches. Given that it's an OB2 vehicle, the dealer should be quite happy to service them. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2541 Location: Ocean Beach in Beautiful BLUE California
Posted: Fri Sep 28, 2018 12:07 pm Post subject: Re: Dealership Servicing VR EVC? |
We are considering the purchase of a Eurovan. I called the closest San Diego VW dealer and said they were happy to service it. The only negatives comments were (a) everything you have done will be expensive, and (b) they do NOT make keys anymore! _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
Posted: Fri Sep 28, 2018 12:14 pm Post subject: Re: Dealership Servicing VR EVC? |
Thanks.
Ya, I've long considered the EV as a future camp mobile. I rent my residence, it has shop space but as a renter, I can foresee a time when I won't have a place to work on my van(s). Want to stay with the VW camper platform so if a dealership was a viable option, that would help. _________________ 1981 Westy DIY 15º ABA
VE7TBN |
e&m_ghia Samba Member
Posted: Sun Sep 30, 2018 7:36 am Post subject: Re: Dealership Servicing VR EVC? |
Our local dealership has a few technicians that can service EVCs - they even have a few who know their way around (actually some that own) aircooled VWs. The issue is that you need to get to those technicians, by name, and the front desk of the service department won't necessarily connect you to them.
If you can't get through to the right individuals, you end up with poor/incomplete repairs,. And then you have to go back several times, to finally get it right.
Also, be warned that dealerships now-days replace components, with other catalog components. Many of the EVC-specific components, we've found, are no longer available. Sometimes a similar component can be found for other VW vehicles, but needs a slight "adjustment" to fit the EVC application - the dealer won't do that.
So, really, you'd be better off finding a good independent mechanic, that knows the vehicle and can be more responsive & adaptable. Just be sure they have a lift that can handle the EVC! |
Posted: Sun Sep 30, 2018 1:23 pm Post subject: Re: Dealership Servicing VR EVC? |
Thanks e&m_ghia
Ok, well, after reading some more about the VR, work space around it (front clip still installed obviously), timing chain stuff, fridge design etc., I'm now, again, leaning towards a Weekender pop top with 5 cyl 5 speed. I'd do a "Blue Highway" kind of set up with that. (ARB fridge, minimalist were that possible. LOL)
This is OT but generally speaking, do all Eurovan fridge/sink equipped camper layouts (Winnie and Westfalia) have about the same amount of interior space or floor space?
VE7TBN |
wildenbeast Samba Member
Posted: Mon Oct 01, 2018 8:59 am Post subject: Re: Dealership Servicing VR EVC? |
Hi Neil- Each model of Eurovan basically has the same interior layout across the 10+ years of production. The trim level and rear AC in the MV tin top vans are the two interior differences that I can think of. The main change over the years was the engine. The '96 and older vans with the 2.5L 5 speed AAF/ACU engines are called "short nose" vans. When they went to the VR6 in 1997, they needed more space for the engine and these later model vans are called "long nose vans". I have switched out many later model van amenities into my early model van such as the bench seat cover that has access doors on the front, the cupholder console between the front seats, and some flooring / trim pieces from a European T4. Anyway, since you're coming from a Vanagon, you'll be happy with the 2.5L engine. However, the later model vans definitely feel more modern and quiet with the VR6 engine.
Vanagon Nut wrote: |
Neil. |
_________________ - Bill, '93 Eurovan Syncro Weekender (2.5 manual ACU) |
Posted: Mon Oct 01, 2018 10:47 am Post subject: Re: Dealership Servicing VR EVC? |
Thanks Bill.
Ok, so when the EV started using the VR engine, the resulting body length is what is some times referred to as a "long wheel base" camper? I'm sure that info is here somewhere......
The jury is still out for me. As with Vanagons, it seems the early EV is getting, or has gotten, long in the tooth. A recent general discussion with my local VW/Audi specialist parts guy indicated that in general, getting parts for the later 24v VR engined EV, was not an issue per se. IOW, it doesn't have as many NLA parts as earlier EV's do? Anyhow.......
VE7TBN |
Posted: Mon Oct 01, 2018 11:13 am Post subject: Re: Dealership Servicing VR EVC? |
Sorry if I threw you off with the short nose, long nose reference. All the Winnebago Campers have a longer wheelbase than the MV or GLS models, whether made in 1995 or 2003. I believe they are approx. 17" longer but that extra space is taken up by the stove, sink, and cabinets.
A 1995 Winnebago Camper (2.5L-I5 engine) has a shorter nose than a 2003 Winnebago Camper (VR6 engine). There is a Westfalia Camper as well made between 1990-1992 that were imported to Canada and these are built on the shorter wheelbase and are all short nose vans as well.
I would agree with the assessment that earlier vans have more NLA parts, especially as it relates to engine and emissions components compared to the later 1997+ vans. Also, compared to a Vanagon, there are way less aftermarket parts for Eurovans as there were way less Eurovans sold in North America.
Thanks Bill.
Neil. |
Posted: Mon Oct 01, 2018 11:38 am Post subject: Re: Dealership Servicing VR EVC? |
wildenbeast wrote: |
Thanks Bill.
Oh no problem at all. Thanks for that clarification.
Indeed I see a few Westfalia EV campers for sale locally, some even with a 5 speed.
I've read opinions that the Westy camper (mainly cabinet construction?) quality is better than the Winnie. However. I just recently learned that the Westfalia Dometic fridge is a compressor type that may run off an inverter in 12 volt mode? i.e. 12 volts is converted to 110VAC? It appears to be rated at 60 Watts.
here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=631503&highlight=fridge
I like my beer cold and food unspoiled, even if interior temps rise about 90º F, but given its location, maybe the Westy fridge cabinet hole could be made to accommodate a top loader Engle or similar?
Neil.
Westfalia Dometic rating and possible inverter
VE7TBN |
Posted: Mon Oct 01, 2018 12:08 pm Post subject: Re: Dealership Servicing VR EVC? |
The Westfalia fibreglass top is also superior. The Winnebago tops are their Achilles Heel, as they're plastic and prone to cracking. The five+five combo is pretty bulletproof, but the later models have a lot of nice features (bigger brakes, fr/rr swaybars, 16" wheels, etc.). _________________ Casey--
y u rune klassik? |
Posted: Mon Oct 01, 2018 12:23 pm Post subject: Re: Dealership Servicing VR EVC? |
Zeitgeist 13 wrote: |
The Westfalia fibreglass top is also superior. The Winnebago tops are their Achilles Heel, as they're plastic and prone to cracking. The five+five combo is pretty bulletproof, but the later models have a lot of nice features (bigger brakes, fr/rr swaybars, 16" wheels, etc.). |
I wondered about the top. Thanks for that Casey! _________________ 1981 Westy DIY 15º ABA
VE7TBN |
Posted: Mon Oct 01, 2018 12:47 pm Post subject: Re: Dealership Servicing VR EVC? |
The Westfalia fibreglass top is also superior. The Winnebago tops are their Achilles Heel, as they're plastic and prone to cracking. The five+five combo is pretty bulletproof, .... |
So viewing for sale ads here, if the pop top has the "Westfalia" logo, its a Westfalia top? The better type?
Neil.
you can *just* see the Westfalia logo on this 1993 California Weekender 5 speed for sale in US:
looks like a 5 speed. 1992. Camper? Weekender? for sale in Quebec
1993 "Westfalia" Weekender 5 speed in Colorado
1993 automatic Weekender US
This 1999, with "aromatic" transmission has a clearly different top. Looks like it has a Winnie logo
VE7TBN |
Broseph Stalin Samba Member
Posted: Mon Oct 01, 2018 2:56 pm Post subject: Re: Dealership Servicing VR EVC? |
Thanks Bill.
Neil. |
I'm pretty sure all T4 LWB vans (used for Winnebago conversions) are short-nose, be they 5-cyl or VR6. I just measured my '95 and '03 Winnebago noses, both are ~24 inches from front tire to the furthest point of the front bumper. I read the long-nose is 100mm longer overhang, that's 4 inches, so quite noticeable.
Also, the extra 16" length LWB isn't used up by the sink, stove, fridge, cabinets. They take up WIDTH in the cargo area, not LENGTH in the cargo area. _________________ '68 Bus in West Germany, 1977-1979
'67 Riviera poptop conversion in the US, 1984-1990
'95 EVC Winnie, 2018, Sold
'03 EVC Winnie, 2018, Sold |
Posted: Mon Oct 01, 2018 3:52 pm Post subject: Re: Dealership Servicing VR EVC? |
You cannot fit a VR6 in a short nose van. All VR6 equipped vans are long nose vans. In the USA, you can tell the difference by seeing the "gills" or air vents on the passenger side of the long nose. I do feel that Winnebago chose the longer wheel base commercial vans for their conversions so that they could fit a 2 burner stove, sink, and small counter space within this extra LENGTH.
Quote: |
Built at VW’s factory in Hannover, it was available in SWB or LWB and in different roof heights.
A facelift in 1996 introduced a longer, re-shaped nose to accommodate the optional VR6 engine; the short nose were known as T4a, the long nose T4b. The bumpers evolved also, going from three-piece affairs to single items part way through the T4’s production lifespan. |
As for the tops from Neil's photos, the last one is a Winnebago top. They are a bit taller than the Westfalia tops and they also have a luggage rack similar to the T3 Vanagons. The Westfalia tops do not have a luggage rack. _________________ - Bill, '93 Eurovan Syncro Weekender (2.5 manual ACU) |
Posted: Mon Oct 01, 2018 4:08 pm Post subject: Re: Dealership Servicing VR EVC? |
Neil.
I think the bottom lines are:
* T4 Westfalia conversion, sold new in Canada for a few years with the I5. Poptop SWB, sleeps four with upper/lower double beds, has sink, stove, cabinets, large 12VDC compressor fridge, onboard water, interior propane bottle for the stove, no furnace. https://www.campersales.co.uk/camper-guide/westfalia/t4/
* T4 Weekender. Poptop SWB, sleeps four with upper double bed, lower Queen bed. No sink, no stove, no furnace, no cabinets, no onboard water, small underseat cooler.
* T4 Winnebago conversion. Poptop LWB, sleeps four with upper/lower double beds, has sink, stove, cabinets, large 3-way fridge, 12g onboard water, exterior 20lb propane bottle, builtin furnace, outside shower.
I liked the Winnebago for the furnace to go along with the other amenities. Seems to me the Winnie is the most versatile. The rear seat is easily removed to haul 4x8 sheets of drywall or whatever.
The extra interior length is nice to have. The Winnebago conversion has an exterior 115VAC plug for campgrounds or a generator, big coach battery, outside shower (rear hatch has to be open). _________________ '68 Bus in West Germany, 1977-1979
Posted: Mon Oct 01, 2018 4:58 pm Post subject: Re: Dealership Servicing VR EVC? |
As for the tops from Neil's photos, the last one is a Winnebago top. They are a bit taller than the Westfalia tops and they also have a luggage rack similar to the T3 Vanagons. The Westfalia tops do not have a luggage rack. |
For some reason the LWB VR6 vans are short nose. Here's the pics I took ten minutes ago. '95 black bumper, '03 white bumper with gill. I don't know how VW did it, but the overhang is the same 24 inches. I Googled about it and found European versions are the same way, some SWB VR6's are short nose, some are long nose, all LWB VR6's are short nose.
Another thing about the LWB is a wider turning circle. The '95 is about 40 feet, the '03 is about 44 feet. Big difference between the '95 and the '03, easily noticed. Must be the 16" wheels on the '01+. But the '01+ also had bigger disc brakes on them, finally good braking on these heavy vans. _________________ '68 Bus in West Germany, 1977-1979
Posted: Mon Oct 01, 2018 5:26 pm Post subject: Re: Dealership Servicing VR EVC? |
I think you may want to measure from the firewall to the tip of the front hood. _________________ Casey--
y u rune klassik? |
Posted: Mon Oct 01, 2018 5:46 pm Post subject: Re: Dealership Servicing VR EVC? |
I think you may want to measure from the firewall to the tip of the front hood. |
Yep, I was wondering about that. Frankly, all I care about is the front overhang. _________________ '68 Bus in West Germany, 1977-1979
IdeaNerd Samba Member
Joined: May 24, 2016 Posts: 598 Location: Central California
Posted: Mon Oct 01, 2018 5:47 pm Post subject: Re: Dealership Servicing VR EVC? |
Broseph Stalin wrote: |
Not flat though, right? Given that bottom of the rear gate opening of the EV is just a little over 48", I've always assumed the cabinets on the left side of the EVC took up too much space for a stack of full 4' x 8' sheets to lay flat on the floor. Am I incorrect on that?
If I'm not, I'd love to know how wide the floor space is in back not taken up by cabinets, when the rear and middle seats are pulled out. I'm curious. |
